UCS@School contains students and teachers in one group with the same attributes in the LDAP. Moodle, however, expects them to be in different groups or LDAP attributes. This Cool Solution contains a listener that places the users in different attributes depending on their UCS@School role.
Prerequisites
This article is based on a successful installation of Moodle and one authentication method accomplished by following our Cool Solution - Install Moodle and assumes you already have authentication configured either via SAML authentication or LDAP authentication.
Tested with moodle 4.1.2
LDAP Search User
If you are using SAML, you will need to set up a simple authentication account for the LDAP lookups. Follow Cool Solution - LDAP search user / simple authentication account to do so now.
Installing the Cool Solution Listener
Please enable the Cool-Solutions Repository for UCS 5.0 Afterward, you can install the Listener with:
univention-install univention-moodle-group
The listener will now place students in univentionFreeAttribute20 and teachers into univentionFreeAttribute19.
Enabling the LDAP enrollment plugin
After successfully setting up an authentication method, you can now configure LDAP enrolments to enroll your UCS@school users into moodle courses automatically.
First, enable the LDAP enrolment plugin under Site Administration → Plugins → Enrolments. This plugin is already installed and only needs to be activated by pressing the icon in the Enable section.
To log in with the local moodle administrator account after you have set up SAML authentication, use https://<YOUR_MOODLE_SERVER_FQDN>/moodle/login/index.php?saml=off
To open the login page and sign in.
LDAP enrollment settings
After the plugin is enabled, open the plugin-settings.
LDAP Server Settings
| Setting | Value |
| Host URL | ldaps://:7636 |
| Use TLS | No |
| Version | 3 |
| LDAP encoding | utf-8 |
| Page size | 250 |
| Bind settings: | |
| Setting | Value |
| Bind user distinguished name | uid=<Bind/User/Cn>,cn=users,<ldap/base> |
| Password | Password |
| Role Mapping: | |
| Role | LDAP contexts |
| Teacher | ou=<School/OU>,<ldap/base> |
| Student | ou=<School/OU>,<ldap/base> |
| Role Settings: | |
| Setting | Value |
| Search subcontexts | Yes |
| Member attributes uses dn | Yes |
| Contexts | cn=schueler,cn=groups,ou=<School/OU>,<ldap/base>;cn=lehrer,cn=groups,ou=<School/OU>,<ldap/base> |
| User type | Default |
| Dereference aliases | No |
| UD number attribute | uidnumber |
| Course enrolment settings: | |
| Setting | Value |
| Object Class | objectClass=posixGroup |
| ID number | cn |
| Short name | cn |
| Full name | cn |
| Summary | description |
| Ignore hidden courses | No |
| External unenroll action | Unenrol user from course |
| Automatic course creation settings: | |
| Setting | Value |
| Auto create | Yes |
| Category | Miscellaneous |
| Template | |
| Automatic course update settings: | |
| Setting | Value |
| Update short name | Yes |
| Update full name | Yes |
| Update summary | Yes |
| Nested groups settings: | |
| Setting | Value |
| Nested groups | Yes |
| ‘Member of’ attribute | memberof |
Nested groups allow you to assign groups to classes and workgroups instead of adding individual users.
Troubleshooting
If you run into issues regarding permissions or elements of the moodle webpage not loading properly, you can try to solve the issue by executing the following commands from the “Install Moodle” 14 Cool Solution:
chown www-data:www-data /var/www/moodle/config.phpchmod 640 /var/www/moodle/config.phpchown -R www-data:www-data /var/moodledatafind /var/moodledata -type f -exec chmod 600 {} \;find /var/moodledata -type d -exec chmod 700 {} \; -
Having large groups such as “Domain Users”, where attributes like memberUid and uniqueMember already contain a large number of entries, and additionally populating univentionFreeAttribute19 and univentionFreeAttribute20 with a comparable number of values, further increases the amount of data associated with the group object.
As a result, loading the group in the UMC can become considerably slower, and depending on the total amount of data, the group information may not be fully retrieved or displayed.
Further links
Moodle LDAP enrollment documentation: Moodle docs
