This is the output of strace
# strace /usr/sbin/univention-directory-notifier
execve("/usr/sbin/univention-directory-notifier", ["/usr/sbin/univention-directory-n"...], [/* 18 vars */]) = 0
brk(NULL) = 0x56434b52e000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=49456, ...}) = 0
mmap(NULL, 49456, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f6bd72a5000
close(3) = 0
open("/usr/lib/x86_64-linux-gnu/libuniventiondebug.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\16\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=10424, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f6bd72a3000
mmap(NULL, 2105528, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6bd6e8c000
mprotect(0x7f6bd6e8e000, 2093056, PROT_NONE) = 0
mmap(0x7f6bd708d000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f6bd708d000
close(3) = 0
open("/lib/x86_64-linux-gnu/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0Pa\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=135440, ...}) = 0
mmap(NULL, 2212936, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6bd6c6f000
mprotect(0x7f6bd6c87000, 2093056, PROT_NONE) = 0
mmap(0x7f6bd6e86000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x7f6bd6e86000
mmap(0x7f6bd6e88000, 13384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f6bd6e88000
close(3) = 0
open("/usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\354\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=327088, ...}) = 0
mmap(NULL, 2431720, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6bd6a1d000
mprotect(0x7f6bd6a6a000, 2097152, PROT_NONE) = 0
mmap(0x7f6bd6c6a000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4d000) = 0x7f6bd6c6a000
mmap(0x7f6bd6c6d000, 6888, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f6bd6c6d000
close(3) = 0
open("/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\4\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1689360, ...}) = 0
mmap(NULL, 3795296, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6bd667e000
mprotect(0x7f6bd6813000, 2097152, PROT_NONE) = 0
mmap(0x7f6bd6a13000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x195000) = 0x7f6bd6a13000
mmap(0x7f6bd6a19000, 14688, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f6bd6a19000
close(3) = 0
open("/usr/lib/x86_64-linux-gnu/liblber-2.4.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\3001\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=59576, ...}) = 0
mmap(NULL, 2154920, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6bd646f000
mprotect(0x7f6bd647c000, 2097152, PROT_NONE) = 0
mmap(0x7f6bd667c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x7f6bd667c000
close(3) = 0
open("/lib/x86_64-linux-gnu/libresolv.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0p9\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=84848, ...}) = 0
mmap(NULL, 2189896, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6bd6258000
mprotect(0x7f6bd626c000, 2093056, PROT_NONE) = 0
mmap(0x7f6bd646b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x13000) = 0x7f6bd646b000
mmap(0x7f6bd646d000, 6728, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f6bd646d000
close(3) = 0
open("/usr/lib/x86_64-linux-gnu/libsasl2.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360-\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=109296, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f6bd72a1000
mmap(NULL, 2204648, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6bd603d000
mprotect(0x7f6bd6057000, 2093056, PROT_NONE) = 0
mmap(0x7f6bd6256000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x19000) = 0x7f6bd6256000
close(3) = 0
open("/usr/lib/x86_64-linux-gnu/libssl.so.1.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\212\1\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=442984, ...}) = 0
mmap(NULL, 2538440, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6bd5dd1000
mprotect(0x7f6bd5e34000, 2093056, PROT_NONE) = 0
mmap(0x7f6bd6033000, 40960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x62000) = 0x7f6bd6033000
close(3) = 0
open("/usr/lib/x86_64-linux-gnu/libcrypto.so.1.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\360\7\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=2711616, ...}) = 0
mmap(NULL, 4820864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6bd5938000
mprotect(0x7f6bd5ba2000, 2097152, PROT_NONE) = 0
mmap(0x7f6bd5da2000, 180224, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x26a000) = 0x7f6bd5da2000
mmap(0x7f6bd5dce000, 12160, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f6bd5dce000
close(3) = 0
open("/lib/x86_64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\r\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14640, ...}) = 0
mmap(NULL, 2109680, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f6bd5734000
mprotect(0x7f6bd5737000, 2093056, PROT_NONE) = 0
mmap(0x7f6bd5936000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f6bd5936000
close(3) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f6bd729f000
arch_prctl(ARCH_SET_FS, 0x7f6bd72a0140) = 0
mprotect(0x7f6bd6a13000, 16384, PROT_READ) = 0
mprotect(0x7f6bd5936000, 4096, PROT_READ) = 0
mprotect(0x7f6bd6e86000, 4096, PROT_READ) = 0
mprotect(0x7f6bd5da2000, 122880, PROT_READ) = 0
mprotect(0x7f6bd6033000, 16384, PROT_READ) = 0
mprotect(0x7f6bd646b000, 4096, PROT_READ) = 0
mprotect(0x7f6bd6256000, 4096, PROT_READ) = 0
mprotect(0x7f6bd667c000, 4096, PROT_READ) = 0
mprotect(0x7f6bd6c6a000, 8192, PROT_READ) = 0
mprotect(0x7f6bd708d000, 4096, PROT_READ) = 0
mprotect(0x56434973a000, 4096, PROT_READ) = 0
mprotect(0x7f6bd72b2000, 4096, PROT_READ) = 0
munmap(0x7f6bd72a5000, 49456) = 0
set_tid_address(0x7f6bd72a0410) = 905
set_robust_list(0x7f6bd72a0420, 24) = 0
rt_sigaction(SIGRTMIN, {sa_handler=0x7f6bd6c74bd0, sa_mask=[], sa_flags=SA_RESTORER|SA_SIGINFO, sa_restorer=0x7f6bd6c800e0}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {sa_handler=0x7f6bd6c74c60, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART|SA_SIGINFO, sa_restorer=0x7f6bd6c800e0}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0
semget(0x64, 1, 0666) = -1 ENOENT (No such file or directory)
semctl(-1, 0, SETVAL, 0x7f6b00000001) = -1 EINVAL (Invalid argument)
clone(child_stack=NULL, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7f6bd72a0410) = 907
exit_group(0) = ?
+++ exited with 0 +++
