Problem after Update to 4.4 Join-Script for Appcenter fails
After updating via the WEB interface I got the message that Join Scripts are still pending,
the following was still outstanding
30univention-appcenter.inst
but it can’t be executed, and the log will say
cp: der Aufruf von stat für '' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
So 24. Mär 21:22:00 CET 2019
univention-join-hooks: looking for hook type "join/pre-joinscripts" on ucs01.virea.intranet
Found hooks:
RUNNING 30univention-appcenter.inst
2019-03-24 21:22:01.173588607+01:00 (in joinscript_init)
Object exists: cn=apps,cn=univention,dc=virea,dc=intranet
Object exists: cn=ldapschema,cn=univention,dc=virea,dc=intranet
INFO: No change of core data of object univention-app.
Object exists: cn=ldapacl,cn=univention,dc=virea,dc=intranet
INFO: No change of core data of object 66univention-appcenter_app.
Object exists: cn=udm_syntax,cn=univention,dc=virea,dc=intranet
INFO: No change of core data of object app_syntax.
Object exists: cn=udm_module,cn=univention,dc=virea,dc=intranet
INFO: No change of core data of object appcenter/app.
No modification: cn=univention-app,cn=ldapschema,cn=univention,dc=virea,dc=intranet
No modification: cn=66univention-appcenter_app,cn=ldapacl,cn=univention,dc=virea,dc=intranet
No modification: cn=app_syntax,cn=udm_syntax,cn=univention,dc=virea,dc=intranet
No modification: cn=appcenter/app,cn=udm_module,cn=univention,dc=virea,dc=intranet
Waiting for activation of the extension object univention-app: OK
Waiting for activation of the extension object 66univention-appcenter_app: OK
Waiting for activation of the extension object app_syntax:.......................................................ERROR: Master did not mark the extension object active within 180 seconds.
ERROR
ucs_registerLDAPExtension: registraton of /usr/share/univention-appcenter/app_syntax.py failed.
EXITCODE=1
1a1010aa-8309-491a-b3d3-9bfd19f995ce
univention-join-hooks: looking for hook type "join/post-joinscripts" on ucs01.virea.intranet
Found hooks:
So 24. Mär 21:25:04 CET 2019
Im Listener.log steht folgendes:
Found hooks:
ERROR
EXITCODE=1
Found hooks:
I don’t understand it.
What I noticed when I created a new user is that it is not displayed on the NAS under domain users, the old users already are.
please use English as language for our international users- I translated your post. Falls es damit Probleme gibt, kurz melden.
Please post the output of:
udm settings/udm_syntax list
/CV
Good Morning Christian,
i try it in English, but it could be a little bat gramtical…
Thist ist the output of
root@ucs01:~# udm settings/udm_syntax list
DN: cn=app_syntax,cn=udm_syntax,cn=univention,dc=virea,dc=intranet
  active: FALSE
  data: 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
  filename: app_syntax.py
  package: univention-appcenter
  packageversion: 8.0.11-3A~4.4.0.201903111012
  ucsversionend: None
  ucsversionstart: None
active: FALSE
Here we are.
Activate it by:
udm settings/udm_syntax modify --dn "cn=app_syntax,cn=udm_syntax,cn=univention,dc=virea,dc=intranet" --set active=TRUE
univention-run.join-scripts
/CV
Ok here ist the output
root@ucs01:~# udm settings/udm_syntax modify --dn "cn=app_syntax,cn=udm_syntax,cn=univention,dc=virea,dc=intranet" --set active=TRUE
next Kommando
Output:
Running 30univention-appcenter.inst
failed (exitcode: 1)
just got further information regarding this issue. As the flag we where talking about is only for informational purpose you will have to remove the object so all related tasks will be executed when it gets activated.
So please do:
udm settings/udm_syntax remove --dn="cn=app_syntax,cn=udm_syntax,cn=univention,$(ucr get ldap/base)"
/CV
When I create a new user, I can not log in to a Windows client with this user.
UCS is the DC, it depends again a UCS as a member for Kopano
Logging in with the previously configured users works.
active: TRUE
ucsversionend: None
RUNNING 01univention-ldap-server-init.inst
EXITCODE=already_executed
RUNNING 02univention-directory-notifier.inst
RUNNING 03univention-directory-listener.inst
RUNNING 04univention-ldap-client.inst
RUNNING 05univention-bind.inst
RUNNING 08univention-apache.inst
RUNNING 10univention-ldap-server.inst
RUNNING 11univention-heimdal-init.inst
RUNNING 11univention-pam.inst
RUNNING 15univention-directory-notifier-post.inst
RUNNING 15univention-heimdal-kdc.inst
RUNNING 18python-univention-directory-manager.inst
RUNNING 20univention-directory-policy.inst
RUNNING 20univention-join.inst
RUNNING 25univention-dhcp.inst
RUNNING 26univention-nagios-common.inst
2019-03-25 10:03:31.757465502+01:00 (in joinscript_init)
Waiting for activation of the extension object app_syntax: OK
Waiting for file /usr/share/univention-appcenter/app_syntax.py: OK
Waiting for activation of the extension object appcenter/app:…ERROR: Master did not mark the extension object active within 180 seconds.
ERROR
ucs_registerLDAPExtension: registraton of /usr/share/univention-appcenter/app.py failed.
EXITCODE=1
33c9133a-82aa-4890-9b95-92288104b67c
RUNNING 30univention-nagios-client.inst
RUNNING 31univention-nagios-s4-connector.inst
RUNNING 31univention-nagios-samba.inst
RUNNING 33univention-portal.inst
RUNNING 34univention-management-console-server.inst
RUNNING 34univention-self-service.inst
RUNNING 35univention-appcenter-docker.inst
RUNNING 35univention-management-console-module-appcenter.inst
RUNNING 35univention-management-console-module-diagnostic.inst
RUNNING 35univention-management-console-module-ipchange.inst
RUNNING 35univention-management-console-module-join.inst
RUNNING 35univention-management-console-module-lib.inst
RUNNING 35univention-management-console-module-mrtg.inst
RUNNING 35univention-management-console-module-quota.inst
RUNNING 35univention-management-console-module-reboot.inst
RUNNING 35univention-management-console-module-services.inst
RUNNING 35univention-management-console-module-setup.inst
RUNNING 35univention-management-console-module-sysinfo.inst
RUNNING 35univention-management-console-module-top.inst
RUNNING 35univention-management-console-module-ucr.inst
RUNNING 35univention-management-console-module-udm.inst
RUNNING 35univention-management-console-module-updater.inst
RUNNING 35univention-self-service-passwordreset-umc.inst
RUNNING 35univention-server-overview.inst
RUNNING 36univention-management-console-module-apps.inst
RUNNING 40univention-postgresql.inst
RUNNING 40univention-virtual-machine-manager-schema.inst
RUNNING 70kopano4ucs-udm.inst
RUNNING 81univention-nfs-server.inst
RUNNING 90univention-bind-post.inst
RUNNING 91univention-saml.inst
RUNNING 92univention-fetchmail-schema.inst
RUNNING 92univention-management-console-web-server.inst
RUNNING 97univention-s4-connector.inst
RUNNING 98univention-samba4-saml-kerberos.inst
univention-join-hooks: looking for hook type “join/post-joinscripts” on ucs01.virea.intranet
Found hooks:
Mo 25. Mär 10:06:37 CET 2019
You might not have notived my edit. So again:
OK
root@ucs01:~# udm settings/udm_syntax remove --dn=“cn=app_syntax,cn=udm_syntax,cn=univention,$(ucr get/ldap/base)” univention-run.join-scripts
E: unknown action “get/ldap/base”, see --help
LDAP Error: Invalid DN syntax: invalid DN: cn=app_syntax,cn=udm_syntax,cn=univention,
root@ucs01:~#
sorry my fault. Typo. Today is Monday…
This is it:
then followed by:
PS: Please keep your log entries short and discard the unneeded entries, makes it much more easier to read…
/CV
ok here the output
root@ucs01:~# udm settings/udm_syntax remove --dn=“cn=app_syntax,cn=udm_syntax,cn=univention,$(ucr get ldap/base)”
Object removed: cn=app_syntax,cn=udm_syntax,cn=univention,dc=virea,dc=intranet
root@ucs01:~# univention-run.join-scripts
-bash: univention-run.join-scripts: Kommando nicht gefunden.
root@ucs01:~# univention-run-join-scripts
copyright © 2001-2019 Univention GmbH, Germany
Running 30univention-appcenter.inst failed (exitcode: 1)
output of join.log
2019-03-25 10:33:56.080464946+01:00 (in joinscript_init)
Object created: cn=app_syntax,cn=udm_syntax,cn=univention,dc=virea,dc=intranet
Waiting for activation of the extension object app_syntax:…ERROR: Master did not mark the extension object active within 180 seconds.
ERROR
EXITCODE=1
a320a10c-5334-4f5b-bb4f-566d0218443c
well, as the first attempt did not solve it looks like you have some mor issues on your system. Please post the output of the following commands on your master:
univention-directory-listener-ctrl status
ls -alh /var/lib/univention-ldap/listener/listener
/CV
OK, Output of
root@ucs01:~# univention-directory-listener-ctrl status
Listener status:
 finish: univention-directory-listener: (pid 7920) 6s, normally down
Current Notifier ID on "ucs01.virea.intranet"
 2525
Last Notifier ID processed by local Listener:
 2212
Last transaction processed:
 2525 cn=app_syntax,cn=udm_syntax,cn=univention,dc=virea,dc=intranet a
Modules:
3       bind    /usr/lib/univention-directory-listener/system/bind.py
3       dhcp    /usr/lib/univention-directory-listener/system/dhcp.py
3       faillog /usr/lib/univention-directory-listener/system/faillog.py
3       gencertificate  /usr/lib/univention-directory-listener/system/gencertificate.py
3       hosteddomains   /usr/lib/univention-directory-listener/system/hosteddomains.py
3       keytab-member   /usr/lib/univention-directory-listener/system/keytab-member.py
3       keytab  /usr/lib/univention-directory-listener/system/keytab.py
3       ldap_extension  /usr/lib/univention-directory-listener/system/ldap_extension.py
3       ldap_server     /usr/lib/univention-directory-listener/system/ldap_server.py
3       license_uuid    /usr/lib/univention-directory-listener/system/license_uuid.py
3       nagios-client   /usr/lib/univention-directory-listener/system/nagios-client.py
3       nfs-homes       /usr/lib/univention-directory-listener/system/nfs-homes.py
3       nfs-shares      /usr/lib/univention-directory-listener/system/nfs-shares.py
3       nscd_update     /usr/lib/univention-directory-listener/system/nscd.py
3       nss     /usr/lib/univention-directory-listener/system/nss.py
3       pkgdb-watch     /usr/lib/univention-directory-listener/system/pkgdb-watch.py
3       portal_groups   /usr/lib/univention-directory-listener/system/portal_groups.py
3       portal_server   /usr/lib/univention-directory-listener/system/portal_server.py
3       quota   /usr/lib/univention-directory-listener/system/quota.py
3       s4-connector    /usr/lib/univention-directory-listener/system/s4-connector.py
3       samba4-idmap    /usr/lib/univention-directory-listener/system/samba4-idmap.py
3       samba-shares    /usr/lib/univention-directory-listener/system/samba-shares.py
3       selfservice-invitation  /usr/lib/univention-directory-listener/system/selfservice-invitation.py
3       selfservice     /usr/lib/univention-directory-listener/system/selfservice.py
3       udm_extension   /usr/lib/univention-directory-listener/system/udm_extension.py
3       umc-service-providers   /usr/lib/univention-directory-listener/system/umc-service-providers.py
3       univention-admin-diary-backend  /usr/lib/univention-directory-listener/system/univention-admin-diary-backend.py
3       univention-saml-idp-config      /usr/lib/univention-directory-listener/system/univention-saml-idp-config.py
3       univention-saml-servers /usr/lib/univention-directory-listener/system/univention-saml-servers.py
3       univention-saml-simplesamlphp-configuration     /usr/lib/univention-directory-listener/system/univention-saml-simplesamlphp-configuration.py
3       well-known-sid-name-mapping     /usr/lib/univention-directory-listener/system/well-known-sid-name-mapping.py
root@ucs01:~# ls -alh /var/lib/univention-ldap/listener/listener
-rw-r--r-- 1 listener root 0 Mär 25 10:33 /var/lib/univention-ldap/listener/listener
root@ucs01:~#
you are having an issue with your listener as the IDs are different:
 2525
 2212
Please check this article.
this article ist very difficult, can yout help me.
this part couldnt i do:
How can these mutations be found
The following Python script finds the first mutation in the file. Please note that the file may be affected by multiple error types, that’s why the script should be run again after fixing an issue:
#!/usr/bin/env python
with open('/var/lib/univention-ldap/notify/transaction', 'r') as transaction:
  lc = 1
  for line in transaction:
    (head, tail) = line.strip().split(' ', 1)
    try:
      cur_lc = int(head)
    except ValueError:
      print 'ERROR at line %d: "%s"' % (lc, line)
      break
    if len(tail.rsplit(' ', 1)) != 2:
      print 'ERROR missing third column at line %d: "%s"' % (lc, line)
      break
    if cur_lc != lc:
      break
    lc += 1
This part have i got it and done
How can the file be repaired
1. Missing IDs can be re-generated with the following command
service univention-directory-notifier stop
service univention-directory-listener stop
service slapd stop
# Now re-enumerate the transaction file:
cut -d ' ' -f 2- /var/lib/univention-ldap/notify/transaction | awk '{print NR " " $0}' > /var/lib/univention-ldap/notify/transaction.new
mv /var/lib/univention-ldap/notify/transaction /var/lib/univention-ldap/notify/transaction.bak
mv /var/lib/univention-ldap/notify/transaction.new /var/lib/univention-ldap/notify/transaction
# And set last_id to the last value:
tail -n 1 /var/lib/univention-ldap/notify/transaction | awk '{print $1}' > /var/lib/univention-ldap/last_id
service univention-directory-notifier start
service slapd start
service univention-directory-listener start
but it doesn’t work:
Listener status:
 finish: univention-directory-listener: (pid 7171) 4s, normally down
 2525
 2212
The following article has solved the problem:
