Thanks for your work!
Using a private UCS over years very stable to sync 3 Androids and 2 Outlooks at home.
Thank you for the info.
Thanks for keeping us informed. Hope for a solution soon.
Do I remember correctly that Kopano will no longer be available on UCS5 without a subscription?
Hi All,
I know that kopano is not availaible for moment for UCS 5.
But I also have warning for :
GitLab Enterprise Edition (Beta) (no update available yet)
Component âcool-solutionsâ is not yet available for newer release versions.
do you know when gitlab will be availaible ? and cool-solutions ?
Thanks,
Vincent
the Kopano team seems to work hard on the issue and they are responsive if they are asked gently. Maybe the final breakthrough happened yesterday and we wonât be stuck in one or two weeks from now:
good news concerning kopano4ucs => Kopano Core - Univention App Center
The system can not be updated to UCS 5.0 due to the following reasons:
default_master_packages:
The Kopano App is or was installed in your domain.
A newer version of the Kopano App is needed in order to update to UCS 5.0.
Kopano and Univention are currently working on providing this new version
as soon a possible.
If the Kopano App is no longer used and has already been removed from the domain
the package kopano4ucs-udm can be removed from this server
in order to update to UCS 5.0: univention-remove --purge kopano4ucs-udm
This check can be disabled by setting the UCR variable âupdate50/ignore_default_master_packages_appsâ to âyesâ.
Error: Update aborted by pre-update script of release 5.0-0
Have just upgraded the system.
First Kopano Core/WebApp/Sync, then UCS 5.
The first part went through fine, the second one stopped at one point because the coturn server wouldnât restart.
After manual de-installation of it, the upgrade went through.
Letâs see if it runs stable but I donât have real doubts.
Thank you very much!
Is the Kopano Server installed on the Master DC or Backup DC ?
at my installation it is on Backup DC and so got the error i posted above - seems only upgrade path with kopano on master to work for now
rg
Christian
As this is a private installation I only have one server, so master.
We also get the same error above when trying to upgrade our Kopano servers or Master DCâs to UCS 5.0.
Our Kopano servers are on member servers and are never on the Master DC.
i uninstalled kopano4ucs-udm package on the master - then the upgrade worked
Ok, and were you able to reinstall the package? Because now you didânt have an graphical interface for the kopano configuration, right?
no this package is no more needed - it seems to be replaced by another package maybe kopano4ucs-app package - the management is still possible in the UCS Web Gui
I was also able to upgrade the master to 5.0 after removal of kopano4ucs-udm. Package notes:
This is a transitional package. It can safely be removed.
the kopano updates went fine! THX to everybody!
Upgrade to 5.0.2 is still not possible, because I get the following errors in log.
Can s.b. please help me.
22.07.22 07:09:22.058 DEBUG_INIT
**** Starting univention-updater with parameter=['/usr/share/univention-updater/univention-updater', 'net', '--updateto', '5.0-2', '--ignoressh', '--ignoreterm']
Version=4.4
Patchlevel=9
starting net mode
--->DBG:update_available(mode=net, cdrom_mount_point=/media/cdrom, iso=None)
Checking network repository
Update to = 5.0-0
**** Downloading scripts at Fri Jul 22 07:09:32 2022
**** Starting actual update at Fri Jul 22 07:09:40 2022
Starting /tmp/tmpmTym0O/preupEWNquo.sh (Fr 22. Jul 07:09:40 CEST 2022):
HINT:
Please check the release notes carefully BEFORE updating to UCS 5.0-0:
English version: https://docs.software-univention.de/release-notes-5.0-0-en.html
German version: https://docs.software-univention.de/release-notes-5.0-0-de.html
3rd party components.
Do you want to continue [Y/n]?
Custom preupdate script /var/lib/local-preup.sh not found
Checking adc_mapping ... OK
Checking adc_multiinstance_mapping ... OK
Checking architecture ... OK
Checking blocking_apps ... Unable to cache apps
OK
Checking default_master_packages ... OK
Checking disk_space ... OK
Checking failed_ldif ... OK
Checking for_postgresql94 ... OK
Checking hold_packages ... OK
Checking kernel ... OK
Checking kolab_schema ... OK
Checking ldap_connection ... OK
Checking ldap_schema ... 62da3128 /etc/ldap/slapd.conf: line 201: rootdn is always granted unlimited privileges.
OK
Checking legacy_objects ... OK
Checking master_version ... OK
Checking md5_signature_is_used ... OK
Checking min_version ... OK
Checking minimum_ucs_version_of_all_systems_in_domain ... FAIL
Checking old_packages ... FAIL
Checking overwritten_umc_templates ... OK
Checking ox_schema ... OK
Checking package_status ... OK
Checking python_ucr_template_compatibility ... OK
Checking python_ucsschool_hooks_compatibility ... OK
Checking role_package_removed ... OK
Checking samba_server_schannel ... OK
Checking samba_tdb_size ... OK
Checking sha1_signature_is_used ... OK
Checking slapd_on_member ... OK
Checking ssh ... OK
Checking system_date_too_old ... OK
Checking system_role ... OK
Checking term ... OK
Checking tls_public_key_size ... OK
Checking tls_public_key_size_ucs-sso ... OK
Checking ucsschool_computerroom_compatibility ... OK
Checking usr_mountpoint ... OK
Checking valid_machine_credentials ... OK
old_packages:
WARNING: The following packages from UCS-4 are still installed, which are no longer supported with UCS-5:
univention-nagios-server
univention-kde Mark KDE as manually installed "apt-mark manual kde-standard" to keep KDE
univention-kdm
univention-mozilla-firefox
univention-x-core
Use "univention-remove --purge" with the packages as following arguments to remove them
minimum_ucs_version_of_all_systems_in_domain:
The following extensions are incompatible with UCS 5.0:
cn=guacamole,cn=udm_syntax,cn=univention,: [unspecified..unspecified)
cn=guacamole/config,cn=udm_module,cn=univention,: [unspecified..unspecified)
cn=58openid-connect-provider.ldapacl,cn=ldapacl,cn=univention,: [unspecified..unspecified)
cn=oidc/rpservice,cn=udm_module,cn=univention,: [unspecified..unspecified)
Starting univention-upgrade. Current UCS version is 4.4-9 errata1272
Checking for package updates: none
Checking for app updates: found
Please rerun command without --check argument to install.
Nagios and Guacamole have been removed some time ago.
How can I savely remove the other packages?
Best regards,
Stefan
Slowly, things are getting serious⊠
The removal of âleftoversâ of Apps to prepare the update to UCS 5.0 is described i.e. here Upgrade to UCS 5 fail - #18 by stone1978
Best,
Ingo
After 6hours work, and so many tests, i give up to upgrade Kopano.
Die folgenden Pakete haben unerfĂŒllte AbhĂ€ngigkeiten:
kopano-webapp : HĂ€ngt ab von: php7-mapi soll aber nicht installiert werden
univention-appcenter : HĂ€ngt ab von: python-univention-appcenter (= 9.0.2-45A~5.0.0.202105171344) soll aber nicht installiert werden
Empfiehlt: univention-appcenter-docker soll aber nicht installiert werden
E: Fehler: Unterbrechungen durch pkgProblemResolver::Resolve hervorgerufen; dies könnte durch zurĂŒckgehaltene Pakete verursacht worden sein.
Error: Failed to execute "apt-get -o DPkg::Options::=--force-confold -o DPkg::Options::=--force-overwrite -o DPkg::Options::=--force-overwrite-dir --trivial-only=no --assume-yes --quiet=1 -u dist-upgrade"
