This article describes the re-provision of a Samba 4 DC Master. Please see this article if a UCS@school environment is used.
There is also a scenario for reprovisioning Samba 4 if the system was taken over from a german AD.
Several Samba 4 data is either lost or corrupt
The LDB-Data of Samba 4 (z.B. /var/lib/samba/private/sam.ldb) is corrupted/broken/lost and Samba 4 has to be re-provisioned.
Note:
If still possible, make sure that all of your groups/users have a sambaSID in open LDAP. No offense: some older apps used non-UCS ways adding groups. Therefore a SID was added to the group in samba but not in OpenLDAP. Reprovisioning uses openLDAP Data only, so that these SIDs got lost and ACL problems e.g with shares access may occur, with immense restoration efforts.
Please also make sure you check and backup self created SPNs and the usernames, where these SPNS or UPNs are attached to. SPNs and UPNs are not replicated to openLDAP and got lost.
Samba 4 can be re-provisioned with the help of the existing LDAP data
The following steps will describe the needed procedure:
Note:
Make sure that all of your groups/users have a sambaSID in open LDAP. No offense: some older apps used non-UCS ways adding groups. Therefore a SID was added to the group in samba but not in OpenLDAP. Reprovisioning uses openLDAP Data only, so that these SIDs got lost and ACL problems e.g with shares access may occur, with immense restoration efforts.
1. Stop Samba 4 on all connected systems in the environment
If there are other Samba 4 systems available, samba 4 has to be stopped there - the naming of the init scripts changed to UCS 4 - both variants are explained:
# UCS 4:
invoke-rc.d samba stop
# UCS 3:
invoke-rc.d samba4 stop
2. Sync time on DC Master:
rdate ptbtime1.ptb.de
3. Save RID Pools on DC Master: {#save-rid-pools-on-dc-master .ace-line}
ldbsearch -H /var/lib/samba/private/sam.ldb CN="RID Set" \
-b CN="$(ucr get hostname),OU=Domain Controllers,$(ucr get ldap/base)" > /root/ridpool.ldif
4. Stop Samba 4 and S4-Connector on DC Master
# UCS 4:
invoke-rc.d univention-s4-connector stop
# UCS 3:
5. Move/Delete Samba 4 and S4-Connector data on DC Master
find /etc/univention/connector/ \( -name "s4*.sqlite" -o -name "lockingdb.sqlite" \) -exec mv "{}" "{}.bak_$(date +%s)" \;
rm -rf /var/lib/univention-connector/s4/*
mv /var/lib/samba/private "/var/lib/samba/private.bak_$(date +%s)"
6. Remove Samba 4 and S4-Connector packages on DC Master
univention-remove univention-samba4 univention-s4-connector
7. Set needed UCR-Variables for re-provision on DC Master
Before applying the following step, check and remember your current value of the UCR variable connector/s4/mapping/group/grouptype, so you can set it back in step 9. Then proceed:
ucr set connector/s4/mapping/group/grouptype='false' \
connector/s4/mapping/sid_to_s4='true' \
samba4/provision/primary='true'
Also make sure that you don’t have the legacy DNS setting set (relict from older UCS systems):
ucr unset connector/s4/mapping/dns/position
8. Install Samba 4 and S4-Connector packkages on DC Master
univention-install univention-s4-connector univention-samba4
Hint
After the installation from the S4-Connector is finished, the synchronization have to be fully completed, so you can proceed with the next step. Refer to the following log file to determine when the sync is finished.
tail -f /var/log/univention/connector-s4.log
9. Remove UCR variables which were set for re-provision on DC Master
ucr unset samba4/provision/primary \
Usually the UCR variable connector/s4/mapping/group/grouptype is set to true. We’ve set it to false in step 7, so make sure to also set it back to its original value:
ucr set connector/s4/mapping/group/grouptype='true'
10. Correct newly created RID-Pool with the help of the saved data on DC Master
A new RID-Pool was created by re-provision - it has to be corrected with the help of tha saved data - see pt.3:
ldbedit -H /var/lib/samba/private/sam.ldb CN="RID Set" \
The following attributes has to be corrected:
rIDAllocationPool
rIDPreviousAllocationPool
rIDNextRID
Please also see SDB-Artikel Samba 4 - RID Pool renewal
After the steps 1-10 the (test)-system should be rebooted and tested.
If there were other systems using samba 4 in this environment, all of them have to be re-joined!
