When starting the User Import via School Administration the module will not start.
Environment
Check for running services
systemctl status apache2.service \
ucs-school-import-http-api.service \
postgresql.service \
rabbitmq-server.service \
celeryd.service
If a service is not Active: active check for the respective package state
dpkg -l celeryd rabbitmq-server ucs-school-import-http-api univention-celery ucs-school-umc-import
In most of the cases ucs-school-import-http-api was not installed
rc ucs-school-import-http-api 17.0.6-22A~4.4.0 all UCS@school: RESTful API for importing users
This results in the described problem, however ucs-school-umc-import might be installed so the tile for the User Import is visible in the UMC.
Install the missing package(s)
univention-install ucs-school-import-http-api
the installation will also install all dependencies. Now you should be able to start the User Import module
