Problem:UCS@school - Import ServerError: Received status_code=502 with reason='Proxy Error'
It is not possible to successfully complete an import for students via the UMC. Instead, the following error occurs and you receive this traceback.
Interner Server-Fehler in "schoolimport/dry-run/progress".
Request: schoolimport/dry-run/progress
  File "/usr/lib/python3/dist-packages/univention/management/console/base.py", line 387, in __error_handling
    six.reraise(etype, exc, etraceback)
  File "/usr/lib/python3/dist-packages/six.py", line 693, in reraise
    raise value
  File "/usr/lib/python3/dist-packages/univention/management/console/base.py", line 285, in execute
    function.__func__(self, request, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/univention/management/console/modules/decorators.py", line 805, in _decorated
    return function(self, request, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/univention/management/console/modules/decorators.py", line 478, in _response
    result = _multi_response(self, request)
  File "/usr/lib/python3/dist-packages/univention/management/console/modules/decorators.py", line 189, in _response
    return function(self, request)
  File "/usr/lib/python3/dist-packages/univention/management/console/modules/decorators.py", line 602, in _response
    return list(function(self, iterator, *nones))
  File "/usr/lib/python3/dist-packages/univention/management/console/modules/decorators.py", line 444, in _fake_func
    yield function(self, *args)
  File "/usr/lib/python3/dist-packages/univention/management/console/modules/schoolimport/__init__.py", line 245, in poll_dry_run
    return progress.poll()
  File "/usr/lib/python3/dist-packages/univention/management/console/modules/mixins.py", line 105, in poll
    six.reraise(*self.exc_info)
  File "/usr/lib/python3/dist-packages/six.py", line 692, in reraise
    raise value.with_traceback(tb)
ucsschool.http_api.client.ServerError: Received status_code=502 with reason='Proxy Error' for requests.post(**url='https://ucs01.univention-schule.de/api/v1/imports/users/', data={'dryrun': True, 'school': 'https://ucs01.univention-schule.de/api/v1/schools/UniventionUCS/', 'user_role': 'student'}, files={'input_file': 'Univention-Schüler-Import.csv'}, params=None, auth=('admin-import', '****************'), headers={'Accept': 'application/json'}, verify=False).
In my case the auth user admin-import showing in the traceback was missing in the rabbitmq, so the user don’t have the authorization to perfom the import.
To get the user admin-import into the rabbitmq db you could use the following join-script, in my case that solve the issue.
univention-run-join-scripts --run-scripts 40ucs-school-import-http-api.inst --force
If the join-script failed, check the status and whether if the RabbitMQ-Server is running.
systemctl status rabbitmq-server.service
You will also get more informations in the less /var/log/rabbitmq/rabbit@hostname.log
Log file(s) (may contain more information):
   /var/log/rabbitmq/rabbit@master.log
   /var/log/rabbitmq/rabbit@master_upgrade.log
2025-03-12 11:38:51.114 [info] <0.8.0> Log file opened with Lager
2025-03-12 11:38:51.900 [info] <0.8.0> Feature flags: list of feature flags found:
2025-03-12 11:38:51.900 [info] <0.8.0> Feature flags:   [ ] implicit_default_bindings
2025-03-12 11:38:51.900 [info] <0.8.0> Feature flags:   [ ] quorum_queue
2025-03-12 11:38:51.900 [info] <0.8.0> Feature flags:   [ ] virtual_host_metadata
2025-03-12 11:38:51.900 [info] <0.8.0> Feature flags: feature flag states written to disk: yes
2025-03-12 11:38:51.945 [info] <0.315.0> ra: meta data store initialised. 0 record(s) recovered
2025-03-12 11:38:51.945 [info] <0.320.0> WAL: recovering ["/var/lib/rabbitmq/mnesia/rabbit@master/quorum/rabbit@master/00000031.wal"]
2025-03-12 11:38:51.945 [error] <0.320.0> CRASH REPORT Process <0.320.0> with 0 neighbours exited with reason: no case clause matching {ok,<<>>} in ra_log_wal:open_existing/1 line 646 in gen_batch_server:init_it
/6 line 165
RabbitMQ crashes because the write-ahead log (WAL) file is corrupted.
CRASH REPORT Process <0.320.0> with 0 neighbours exited with reason: no case clause matching {ok,<<>>} in ra_log_wal:open_existing/1 line 646 shows that RabbitMQ encountered an unexpected state while trying to load the WAL file (/var/lib/rabbitmq/mnesia/rabbit@master/quorum/rabbit@master/00000031.wal).
Reset WAL files to delete the corrupted WAL files and get RabbitMQ running again.
  1. rm -rf /var/lib/rabbitmq/mnesia/rabbit@hostname/quorum/rabbit@hostname/*
  2. systemctl start rabbitmq-server
  3. systemctl status rabbitmq-server
  4. rabbitmqctl status
rabbitmqctl status output:
Status of node rabbit@master ...
ESC[1mRuntimeESC[0m
OS PID: 30514
OS: Linux
Uptime (seconds): 2489
RabbitMQ version: 3.8.2
Node name: rabbit@master
Erlang configuration: Erlang/OTP 22 [erts-10.6.4] [source] [64-bit] [smp:4:4] [ds:4:4:10] [async-threads:64]
Erlang processes: 357 used, 1048576 limit
Scheduler run queue: 1
Cluster heartbeat timeout (net_ticktime): 60
ESC[1mPluginsESC[0m
Enabled plugin file: /etc/rabbitmq/enabled_plugins
Enabled plugins:
ESC[1mData directoryESC[0m
Node data directory: /var/lib/rabbitmq/mnesia/rabbit@master
ESC[1mConfig filesESC[0m
 * /etc/rabbitmq/rabbitmq.config
ESC[1mLog file(s)ESC[0m
 * /var/log/rabbitmq/rabbit@master.log
 * /var/log/rabbitmq/rabbit@master_upgrade.log
ESC[1mAlarmsESC[0m
(none)
ESC[1mMemoryESC[0m
Calculation strategy: rss
Memory high watermark setting: 0.4 of available memory, computed to: 6.711 gb
code: 0.0268 gb (26.51 %)
other_proc: 0.0238 gb (23.59 %)
reserved_unallocated: 0.0152 gb (15.07 %)
other_system: 0.0127 gb (12.54 %)
binary: 0.0106 gb (10.51 %)
allocated_unused: 0.0062 gb (6.18 %)
other_ets: 0.0027 gb (2.67 %)
atom: 0.0014 gb (1.42 %)
connection_other: 0.0005 gb (0.48 %)
queue_procs: 0.0004 gb (0.36 %)
metrics: 0.0002 gb (0.21 %)
connection_channels: 0.0001 gb (0.13 %)
mnesia: 0.0001 gb (0.1 %)
connection_readers: 0.0001 gb (0.09 %)
msg_index: 0.0001 gb (0.06 %)
connection_writers: 0.0 gb (0.05 %)
quorum_ets: 0.0 gb (0.04 %)
plugins: 0.0 gb (0.01 %)
mgmt_db: 0.0 gb (0.0 %)
queue_slave_procs: 0.0 gb (0.0 %)
quorum_queue_procs: 0.0 gb (0.0 %)
ESC[1mFile DescriptorsESC[0m
Total: 10, limit: 65439
Sockets: 4, limit: 58893
ESC[1mFree Disk SpaceESC[0m
Low free disk space watermark: 0.05 gb
Free disk space: 193.0677 gb
ESC[1mTotalsESC[0m
Connection count: 4
Queue count: 6
Virtual host count: 2
ESC[1mListenersESC[0m
Interface: [::], port: 25672, protocol: clustering, purpose: inter-node and CLI tool communication
Interface: 127.0.0.1, port: 5672, protocol: amqp, purpose: AMQP 0-9-1 and AMQP 1.0
Interface: [::1], port: 5672, protocol: amqp, purpose: AMQP 0-9-1 and AMQP 1.0
● rabbitmq-server.service - RabbitMQ Messaging Server
   Loaded: loaded (/lib/systemd/system/rabbitmq-server.service; enabled; vendor preset: enabled)
   Active: active (running) since Wed 2025-03-12 12:07:13 CET; 40min ago
 Main PID: 30514 (beam.smp)
   Status: "Initialized"
    Tasks: 91 (limit: 4915)
   Memory: 93.3M
   CGroup: /system.slice/rabbitmq-server.service
           ├─30510 /bin/sh /usr/sbin/rabbitmq-server
           ├─30514 /usr/lib/erlang/erts-10.6.4/bin/beam.smp -W w -A 64 -MBas ageffcbf -MHas ageffcbf -MBlmbcs 512 -MHlmbcs 512 -MMmcs 30 -P 1048576 -t 5000000 -stbt db -zdbbl 128000 -K true -- -root /usr/lib/erl
           ├─30789 erl_child_setup 65536
           ├─30847 inet_gethost 4
           └─30848 inet_gethost 4
Mär 12 12:07:13 master systemd[1]: rabbitmq-server.service: Supervising process 30514 which is not our child. We'll most likely not notice when it exits.
Mär 12 12:07:13 master systemd[1]: Started RabbitMQ Messaging Server.
Mär 12 12:08:21 master systemd[1]: rabbitmq-server.service: Supervising process 30514 which is not our child. We'll most likely not notice when it exits.
Mär 12 12:08:22 master systemd[1]: rabbitmq-server.service: Supervising process 30514 which is not our child. We'll most likely not notice when it exits.
lines 1-24/24 (END)
Investigation
Check the status of services for the import and if necessary, restart them.
  1. systemctl status apache2.service ucs-school-import-http-api.service postgresql.service rabbitmq-server.service
  2. systemctl restart apache2.service ucs-school-import-http-api.service postgresql.service rabbitmq-server.service
In my case, the service for the rabbitmq was not running and would not start correctly, because the permissions from the rabbitmq dir was not set correct, like shown in the following outputs.
root@dc0:~/univention-support# systemctl status rabbitmq-server.service
   Active: activating (auto-restart) (Result: exit-code) since Thu 2024-09-26 05:04:24 CEST; 6s ago
  Process: 497 ExecStart=/usr/sbin/rabbitmq-server (code=exited, status=200/CHDIR)
 Main PID: 497 (code=exited, status=200/CHDIR)
root@dc0:~/univention-support# ls -lah /var/lib/rabbitmq/
insgesamt 16K
dr--r--r--  3 rabbitmq rabbitmq 4,0K Jun 24  2022 .
drwxr-xr-x 86 root     root     4,0K Sep  4 20:55 ..
-r--------  1 rabbitmq rabbitmq   20 Jun 24  2022 .erlang.cookie
dr--r-----  4 rabbitmq rabbitmq 4,0K Sep 19 15:55 mnesia
I was able to get the service running again by setting the correct permissions under /var/lib/rabbitmq/ and running a diagnostic rabbitmq-diagnostics status.
  1. chmod -R 750 /var/lib/rabbitmq/
  2. chmod 100 /var/lib/rabbitmq/.erlang.cookie
insgesamt 16K
drwxr-x---  3 rabbitmq rabbitmq 4,0K Jun 24  2022 .
drwxr-x---  4 rabbitmq rabbitmq 4,0K Sep 26 05:14 mnesia
  1. rabbitmq-diagnostics status
root@dc0:~/univention-support# rabbitmq-diagnostics status
Status of node rabbit@dc0 ...
Runtime
OS PID: 8637
OS: Linux
Uptime (seconds): 13
Node name: rabbit@dc0
Erlang configuration: Erlang/OTP 22 [erts-10.6.4] [source] [64-bit] [smp:2:2] [ds:2:2:10] [async-threads:64]
Erlang processes: 286 used, 1048576 limit
Plugins
Enabled plugins:
Data directory
Node data directory: /var/lib/rabbitmq/mnesia/rabbit@dc0
Config files
Log file(s)
 * /var/log/rabbitmq/rabbit@dc0.log
 * /var/log/rabbitmq/rabbit@dc0_upgrade.log
Alarms
(none)
Memory
Memory high watermark setting: 0.4 of available memory, computed to: 3.334 gb
other_proc: 0.0273 gb (29.56 %)
code: 0.0268 gb (29.03 %)
reserved_unallocated: 0.0134 gb (14.58 %)
other_system: 0.0116 gb (12.59 %)
allocated_unused: 0.0085 gb (9.19 %)
other_ets: 0.0027 gb (2.91 %)
atom: 0.0014 gb (1.56 %)
binary: 0.0001 gb (0.11 %)
queue_procs: 0.0 gb (0.05 %)
quorum_ets: 0.0 gb (0.05 %)
connection_channels: 0.0 gb (0.0 %)
connection_other: 0.0 gb (0.0 %)
connection_readers: 0.0 gb (0.0 %)
connection_writers: 0.0 gb (0.0 %)
File Descriptors
Total: 6, limit: 65439
Sockets: 0, limit: 58893
Free Disk Space
Free disk space: 19.6606 gb
Totals
Connection count: 0
Queue count: 2
Listeners
  1. systemctl stop rabbitmq-server.service
  2. systemctl start rabbitmq-server.service
  3. systemctl status rabbitmq-server.service
   Active: active (running) since Thu 2024-09-26 05:21:37 CEST; 11s ago
 Main PID: 10250 (beam.smp)
    Tasks: 87 (limit: 4915)
   Memory: 76.1M
           ├─10246 /bin/sh /usr/sbin/rabbitmq-server
           ├─10250 /usr/lib/erlang/erts-10.6.4/bin/beam.smp -W w -A 64 -MBas ageffcbf -MHas ageffcbf -MBlmbcs 512 -MHlmbcs 512 -MMmcs 30 -P 1048576 -t 5000000 -stbt db -zdbbl 128000 -K true -- -root /usr/lib/erl
           ├─10507 erl_child_setup 65536
           ├─10553 inet_gethost 4
           └─10554 inet_gethost 4
Sep 26 05:21:30 dc0 systemd[1]: Starting RabbitMQ Messaging Server...
Sep 26 05:21:37 dc0 systemd[1]: rabbitmq-server.service: Supervising process 10250 which is not our child. We'll most likely not notice when it exits.
Sep 26 05:21:37 dc0 systemd[1]: Started RabbitMQ Messaging Server.
