I installed ucs5 freshly from iso and as first action, i wanted to install nextcloud.
This directly failed with the join script (@55%), giving these errors:
Object exists: SAMLServiceProviderIdentifier=https://server.zoo.box/nextcloud/apps/user_saml/saml/metadata,cn=saml-serviceprovider,cn=univention,dc=zoo,dc=box
Nextcloud is not installed - only a limited number of commands are available
An unhandled exception has been thrown:
Doctrine\DBAL\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[08006] [7] connection to server at “172.17.42.1”, port 5432 failed: Connection refused
Is the server running on that host and accepting TCP/IP connections? in /var/www/html/lib/private/DB/Connection.php:140
Stack trace: #0 /var/www/html/3rdparty/doctrine/dbal/src/Connection.php(1531): OC\DB\Connection->connect() #1 /var/www/html/3rdparty/doctrine/dbal/src/Connection.php(1029): Doctrine\DBAL\Connection->getWrappedConnection() #2 /var/www/html/lib/private/DB/Connection.php(262): Doctrine\DBAL\Connection->executeQuery() #3 /var/www/html/lib/private/DB/ConnectionAdapter.php(65): OC\DB\Connection->executeQuery() #4 /var/www/html/lib/private/legacy/OC_Util.php(743): OC\DB\ConnectionAdapter->executeQuery() #5 /var/www/html/lib/private/legacy/OC_Util.php(719): OC_Util::checkDatabaseVersion() #6 /var/www/html/lib/private/Console/Application.php(160): OC_Util::checkServer() #7 /var/www/html/console.php(99): OC\Console\Application->loadCommands() #8 /var/www/html/occ(11): require_once(‘…’) #9 {main}
I tried to uninstall and reinstall the nextcloud app, but no sucess.
What went wrong and where to check?
● postgresql.service - PostgreSQL RDBMS
Loaded: loaded (/lib/systemd/system/postgresql.service; enabled; vendor preset: enabled)
Active: active (exited) since Mon 2024-01-29 12:39:56 CET; 6h ago
Process: 1220 ExecStart=/bin/true (code=exited, status=0/SUCCESS)
Main PID: 1220 (code=exited, status=0/SUCCESS)
nmap -p5432 172.17.42.1:
Starting Nmap 7.70 ( https://nmap.org ) at 2024-01-29 19:39 CET
Nmap scan report for 172.17.42.1
Host is up (0.00011s latency).
PORT STATE SERVICE
5432/tcp open postgresql
Nmap done: 1 IP address (1 host up) scanned in 0.39 seconds
sudo -u www-data php occ status:
installed: false
version: 27.1.5.1
versionstring: 27.1.5
edition:
maintenance: false
needsDbUpgrade: false
productname: Nextcloud
extendedSupport: false
so it seems to me the install of nextcloud did not finish?
How to complete it?
I can reach the /nextcloud weburl, but also here obviously, i only get the error:
Internal Server Error
The server was unable to complete your request.
If this happens again, please send the technical details below to the server administrator.
→ i bashed into the container and shifted /var/www/html/config/config.php to *.config.php.bak
→ i could then open https://server/nextcloud and got the config wizard of nextcloud
→ i populated the fields with the dbuser and passwd from the config.php.bak contents
now, i can login as admin into nextcloud
still:
→ the join script keeps failing like before
→ the ldap/ucs user accounts do not therefore exist in nextcloud
→ visiting https://server/nextcloud/* keeps redirecting the browser to http
making the domain trusted worked just fine!
…but still does not make the join script running…
it fails like in this post with the same message:
There are no commands defined in the “saml:config” namespace.
Could not create LDAP Config at Nextcloud
EXITCODE=1
bedb271a-ac97-4563-b89a-97832d64c928
univention-join-hooks: looking for hook type “join/post-joinscripts”
any idea?
i tried removing some nextcloud saml service entries, but these are recreated again, until the script fails.
How to figure out, what it is exactly that fails?
i found this post: Nextcloud Join Script failed
also stopping at the SAML… so wondering, if SSO or some domain/DNS stuff is the reason to fail?
I looked also into: https://docs.software-univention.de/manual/5.0/de/domain-ldap/saml.html
an added the ucs-sso cert to my browser and followed the instructions to make the browser accepting things.
I reran the join-script, but nothing changed, still fails.
I also though if running the join from ssh directly without using the browser session would do the magic, but also here, same failure…
I cannot call https://ucs-sso.domain this is not resolved from my browser/server session.
What to do? SSO is the cherry on the cake, but a bit annoying to break initial installations/first steps…
i created host entries, so usc-sso resolves and more.
by coincidence a nextcloud app update arrived, which i could upgrade to.
Also rerun all join scripts with “force” flag.
Still nextcloud join script fails with:
EXITCODE=1
Nextcloud does not integrate into LDAP due to this, so no ucs users.
Das müsste fast einen Fehler werfen. Wäre es dann nicht besser Nextcloud sauber komplett zu deinstallieren und alle UCS Fehlermeldungen und nur bei Bedarf bestehende Nextcloudschnipsel zu beseitigen ?
Siehe: univention-run-diagnostic-checks
und bei der nächsten Installation die install scripte von Anfang an und Schritt für Schritt zu kontrollieren? Meine 50 Cent in Anbetracht der schon geleisteten Handarbeit an der Datenbank, im Docker usw…
→ neuinstallation mit vorheriger Löschung ist nun durchgelaufen. Lediglich der Schritt oben “set trusted domains” musste nochmal ausgeführt werden, jetzt läufts!
