Join script failed: Could not create LDAP Config at Nextcloud
Hello. Сan anyone help me?
-----END CERTIFICATE-----
Config value type for app user_saml set to saml
Config value general-require_provisioned_account for app user_saml set to 1
Config value general-allow_multiple_user_back_ends for app user_saml set to 1
Config value general-uid_mapping for app user_saml set to uid
Config value idp-singleLogoutService.url for app user_saml set to https://ucs-sso.rozkrolik.intranet/simplesamlphp/saml2/idp/SingleLogoutService.php
Config value idp-singleSignOnService.url for app user_saml set to https://ucs-sso.rozkrolik.intranet/simplesamlphp/saml2/idp/SSOService.php
Config value idp-entityId for app user_saml set to https://ucs-sso.rozkrolik.intranet/simplesamlphp/saml2/idp/metadata.php
EXITCODE=1
0c11b97a-04b0-4499-90c9-24927c6fbd5e
univention-join-hooks: looking for hook type “join/post-joinscripts” on ucs.rozkrolik.intranet
Found hooks:
hello. no ideas? =(
thanks
Any updates? What is the status of this issue?
It is still broken months later.
I just attempted a fresh install and it fails.
Nextcloud is not installed - only a limited number of commands are available
There are no commands defined in the “config:app” namespace.
EXITCODE=1
3e072e97-5d38-4a3d-a073-30ccdbfed7bc
univention-join-hooks: looking for hook type “join/post-joinscripts” on ovh-ucs.turnsys.net
Found hooks:
Tue Mar 10 06:47:15 CDT 2020
What are steps I can take to troubleshoot?
What additional information is needed?
This is on a fully updated univention system.
Mastodon
