When I updated my Nextcloud trough Univention App Center from 18.0.3 to 18.0.4 Nextcloud got stuck in maintenance mode.
Here is what I did to get out of maintenance mode and finish the update manually in a webbrowser:
Login in Univention via SSH by using for example Putty as administrator.
In console:
$ sudo su
to switch to root user
$ univention-app shell nextcloud
to get in the docker container where nextcloud is installed
$ cd /var/www/html
there should be a file occ
$ sudo -u www-data php occ maintenance:mode --off
Console tells you
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
Maintenance mode disabled
I finished to update Nextcloud by clicking update in browser window.
Since this the second time my installation of Nextcloud on Univention did this (18.0.2->18.0.3 and 18.0.3->18.0.4) I wanted to share the way I solved the problem.
As I’m a beginner in Linux terminal all hints, critics and overall better ways to solve the problem are welcome. I would prefer update driven by Univention App center.
@SirTux: Thank you, with your help I was able to investigate the archives of the log files. @blizzz: Hello again
As I don’t know exactly what I should look for find bellow what the command $ zcat appcenter.log.4.gz | less gives me from the file mentioning 18.0.3. The next one is already talking about 18.0.4. Maybe it’s talking to you:
Hi @mangrovenjazz this is not the correct file, as of the date – April 19th. Univention put 18.0.4 live on 29th of April. You opened this topic on May first. So the potential log file(s) should cover that range.
gives me about that period. I’m struggling with zcat command and copying piece by piece. Hope it contains the information you’re interessted in (note that domain has been replaced by xxx.xxx.xx). As the post is limited me to 32000 caracters here are just some portions. For further information contact me.
14963 actions.upgrade 20-05-01 17:12:39 [ INFO]: Going to upgrade Nextcloud Hub (18.0.4-0)
14963 actions.upgrade 20-05-01 17:12:40 [ DEBUG]: Calling prescript (preinst)
14963 actions.upgrade 20-05-01 17:12:40 [ DEBUG]: Calling /var/cache/univention-appcenter/appcenter.software-univention.de/4.1/nextcloud_20200422233313.preinst --binddn uid=Administrator,cn=users,dc=xxxxx,dc=xx --locale de --old-version 18.0.3-0 --error-file /tmp/tmpNFudNm --version 18.0.4-0 --bindpwdfile /tmp/tmpF6EmPs
14963 actions.upgrade 20-05-01 17:12:40 [ DEBUG]: /var/cache/univention-appcenter/appcenter.software-univention.de/4.1/nextcloud_20200422233313.preinst returned with 0
14963 packages 20-05-01 17:12:40 [ DEBUG]: Holding LOCK
14963 actions.start 20-05-01 17:12:40 [ DEBUG]: Calling start
14963 actions.start.progress 20-05-01 17:12:40 [ DEBUG]: 0
14963 actions.start 20-05-01 17:12:40 [ DEBUG]: Calling /etc/init.d/docker-app-nextcloud start
14963 actions.start 20-05-01 17:12:40 [ INFO]: Starting docker-app-nextcloud (via systemctl): docker-app-nextcloud.service.
14963 actions.start 20-05-01 17:12:41 [ DEBUG]: /etc/init.d/docker-app-nextcloud returned with 0
14963 actions.start.progress 20-05-01 17:12:41 [ DEBUG]: 100
14963 actions.configure 20-05-01 17:12:41 [ WARNING]: Cannot write settings while 4.1/nextcloud=18.0.4-0 is not running
14963 actions.upgrade 20-05-01 17:12:41 [ INFO]: Executing interface update_available for nextcloud
14963 actions.upgrade 20-05-01 17:12:41 [ INFO]: No interface defined
14963 actions.upgrade 20-05-01 17:12:41 [ INFO]: Upgrading image (u'docker.software-univention.de/nextcloud:18.0.4-0')
14963 actions.upgrade 20-05-01 17:12:41 [ INFO]: Verifying Docker registry manifest for app image docker.software-univention.de/nextcloud:18.0.4-0
14963 actions.upgrade 20-05-01 17:12:41 [ INFO]: Pulling Docker image docker.software-univention.de/nextcloud:18.0.4-0
14963 actions.upgrade 20-05-01 17:12:41 [ INFO]: Downloading app image docker.software-univention.de/nextcloud:18.0.4-0
14963 docker 20-05-01 17:12:41 [ INFO]: Running command: docker pull docker.software-univention.de/nextcloud:18.0.4-0
14963 actions.stop 20-05-01 17:14:06 [ INFO]: Stopping docker-app-nextcloud (via systemctl): docker-app-nextcloud.service.
14963 actions.stop 20-05-01 17:14:06 [ DEBUG]: /etc/init.d/docker-app-nextcloud returned with 0
14963 actions.stop.progress 20-05-01 17:14:06 [ DEBUG]: 100
14963 actions.upgrade 20-05-01 17:14:06 [ INFO]: Removing old container
14963 actions.upgrade 20-05-01 17:14:06 [ INFO]: Setting up new container (4.1/nextcloud=18.0.4-0)
14963 actions.upgrade 20-05-01 17:14:06 [ INFO]: Creating data directories for nextcloud...
14963 actions.upgrade 20-05-01 17:14:06 [ INFO]: Copying /var/cache/univention-appcenter/appcenter.software-univention.de/4.1/nextcloud_20200422233313.schema
14963 actions.upgrade.progress 20-05-01 17:14:06 [ DEBUG]: 5
14963 actions.upgrade 20-05-01 17:14:06 [ INFO]: Registering UCR for nextcloud
14963 actions.upgrade 20-05-01 17:14:06 [ INFO]: Marking 4.1/nextcloud=18.0.4-0 as installed
14963 actions.upgrade 20-05-01 17:14:10 [ INFO]: Setting ports for apache proxy
14963 actions.upgrade 20-05-01 17:14:10 [ INFO]: Creating /etc/init.d/docker-app-nextcloud
14963 actions.upgrade 20-05-01 17:14:10 [ DEBUG]: Calling /usr/sbin/update-rc.d docker-app-nextcloud defaults 41 14
14963 actions.upgrade 20-05-01 17:14:10 [ DEBUG]: /usr/sbin/update-rc.d returned with 0
14963 actions.upgrade 20-05-01 17:14:10 [ DEBUG]: Calling /bin/systemctl daemon-reload
14963 actions.upgrade 20-05-01 17:14:10 [ DEBUG]: /bin/systemctl returned with 0
14963 actions.upgrade 20-05-01 17:14:10 [ INFO]: Adding localhost to LDAP object
14963 actions.upgrade 20-05-01 17:14:11 [ INFO]: Setting overview variables
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Changed: set(['nextcloud'])
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Local hosts are: ['xxx.xxx.xx', 'XXX.XXX.XX.XX']
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Matched 'ucs/web/overview/entries/service/nextcloud/label/de' -> 'Nextcloud'
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Matched 'ucs/web/overview/entries/service/nextcloud/link' -> '/nextcloud'
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Matched 'ucs/web/overview/entries/service/nextcloud/description' -> 'Secure data storage & digital collaboration in and outside your organization'
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Matched 'ucs/web/overview/entries/service/nextcloud/label' -> 'Nextcloud'
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Matched 'ucs/web/overview/entries/service/nextcloud/port_https' -> '443'
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Matched 'ucs/web/overview/entries/service/nextcloud/description/de' -> 'Daten sicher speichern, synchronisieren & teilen in und au\xc3\x9ferhalb Ihrer Organisation'
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Matched 'ucs/web/overview/entries/service/nextcloud/port_http' -> ''
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Matched 'ucs/web/overview/entries/service/nextcloud/icon' -> u'/univention/js/dijit/themes/umc/icons/scalable/apps-nextcloud_20200422233313.svg'
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Processing cn=nextcloud,cn=portal,cn=univention,dc=xxxxx,dc=xx
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Attrs: {'category': 'service', 'displayName': [('de_DE', 'Nextcloud'), ('en_US', 'Nextcloud')], 'name': 'nextcloud', 'description': [('en_US', 'Secure data storage & digital collaboration in and outside your organization'), ('de_DE', 'Daten sicher speichern, synchronisieren & teilen in und au\xc3\x9ferhalb Ihrer Organisation')], 'icon': u'x:
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Links: ['https://XXX.XXX.XX.XX/nextcloud', 'https://xxx.xxx.xx/nextcloud']
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Existing links: ['https://XXX.XXX.XX.XX/nextcloud', 'https://xxx.xxx.xx/nextcloud']
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: New links: ['https://XXX.XXX.XX.XX/nextcloud', 'https://xxx.xxx.xx/nextcloud']
14963 portalentries 20-05-01 17:14:11 [ DEBUG]: Modifying DN
14963 actions.upgrade 20-05-01 17:14:11 [ DEBUG]: Calling /etc/init.d/apache2 reload
14963 actions.upgrade 20-05-01 17:14:11 [ INFO]: Reloading apache2 configuration (via systemctl): apache2.service.
14963 actions.upgrade 20-05-01 17:14:11 [ DEBUG]: /etc/init.d/apache2 returned with 0
14963 actions.upgrade.progress 20-05-01 17:14:11 [ DEBUG]: 10
14963 database 20-05-01 17:14:11 [ DEBUG]: 4.1/nextcloud=18.0.4-0 uses PostgreSQL
14963 packages 20-05-01 17:14:12 [ DEBUG]: Calling /usr/bin/apt-mark manual univention-postgresql
14963 packages 20-05-01 17:14:12 [ INFO]: univention-postgresql wurde bereits auf manuell installiert gesetzt.
14963 database 20-05-01 17:14:12 [ DEBUG]: Calling service postgresql start
14963 database 20-05-01 17:14:13 [ DEBUG]: Password already exists
14963 database 20-05-01 17:14:14 [ INFO]: Checking if database nextcloud exists (postgresql implementation)
14963 database 20-05-01 17:14:15 [ INFO]: Database nextcloud already exists
14963 database 20-05-01 17:14:15 [ DEBUG]: Database and User already exist
14963 database 20-05-01 17:14:15 [ INFO]: 4.1/nextcloud=18.0.4-0 already has its database
14963 actions.upgrade.progress 20-05-01 17:14:15 [ DEBUG]: 15
14963 actions.upgrade 20-05-01 17:14:15 [ INFO]: Registering schema /usr/share/univention-appcenter/apps/nextcloud/nextcloud.schema
14963 actions.upgrade.progress 20-05-01 17:14:17 [ DEBUG]: 25
14963 actions.upgrade 20-05-01 17:14:17 [ INFO]: Already found cn=nextc-59181308,cn=memberserver,cn=computers,dc=xxxxx,dc=eu as a host for nextcloud. Trying to retrieve machine secret.
14963 actions.upgrade.progress 20-05-01 17:14:17 [ DEBUG]: 30
14963 actions.upgrade 20-05-01 17:14:17 [ INFO]: Verifying Docker registry manifest for app image docker.software-univention.de/nextcloud:18.0.4-0
14963 actions.upgrade 20-05-01 17:14:17 [ INFO]: Downloading app image docker.software-univention.de/nextcloud:18.0.4-0
14963 docker 20-05-01 17:14:17 [ INFO]: Running command: docker pull docker.software-univention.de/nextcloud:18.0.4-0
14963 docker 20-05-01 17:14:18 [ INFO]: Digest: sha256:8a8b1ae5eb3113d0804e2dbd2a97a25ccc91885c97507af023955e8f083aa793
14963 docker 20-05-01 17:14:18 [ INFO]: Status: Image is up to date for docker.software-univention.de/nextcloud:18.0.4-0
14963 actions.upgrade 20-05-01 17:14:18 [ INFO]: Initializing app image
14963 database 20-05-01 17:14:18 [ DEBUG]: 4.1/nextcloud=18.0.4-0 uses PostgreSQL
14963 utils 20-05-01 17:14:18 [ INFO]: Running command: docker create --hostname nextc-59181308 --env-file /var/lib/univention-appcenter/apps/nextcloud/nextcloud.env -p 40000:80/tcp -v /var/lib/univention-appcenter/apps/nextcloud/data:/var/lib/univention-appcenter/apps/nextcloud/data -v /etc/apt/apt.conf.d/80proxy:/etc/apt/apt.conf.d/80proxy:ro -v /var/lib/univention-appcenter/apps/nextcloud/conf:/var/lib/univention-appcenter/apps/nextcloud/conf -v /sys/fs/cgroup:/sys/fs/cgroup:ro --tmpfs /run --tmpfs /run/lock --security-opt seccomp:/etc/docker/seccomp-systemd.json -e container=docker docker.software-univention.de/nextcloud:18.0.4-0 /usr/sbin/entrypoint.sh
14963 utils 20-05-01 17:14:18 [ INFO]: 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54
14963 actions.upgrade 20-05-01 17:14:19 [ INFO]: Preconfiguring container 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54
14963 actions.start 20-05-01 17:14:19 [ DEBUG]: Calling start
14963 actions.start.progress 20-05-01 17:14:19 [ DEBUG]: 0
14963 actions.start 20-05-01 17:14:19 [ DEBUG]: Calling /etc/init.d/docker-app-nextcloud start
24385 cache 20-05-01 17:14:19 [ DEBUG]: Cache outdated. Need to rebuild
24385 cache 20-05-01 17:14:20 [ DEBUG]: Loaded 142 apps from cache
24385 cache 20-05-01 17:14:20 [ DEBUG]: Cache outdated. Need to rebuild
24385 cache 20-05-01 17:14:20 [ DEBUG]: Loaded 243 apps from cache
24385 cache 20-05-01 17:14:20 [ DEBUG]: Loaded 219 apps from cache
24385 cache 20-05-01 17:14:21 [ DEBUG]: Loaded 399 apps from cache
24385 actions.get 20-05-01 17:14:21 [ DEBUG]: Calling get
24385 actions.get.progress 20-05-01 17:14:21 [ DEBUG]: 0
24385 actions.get 20-05-01 17:14:21 [ INFO]: appcenter/apps/nextcloud/container
24385 actions.get.progress 20-05-01 17:14:21 [ DEBUG]: 100
24599 cache 20-05-01 17:14:22 [ DEBUG]: Cache outdated. Need to rebuild
24599 cache 20-05-01 17:14:23 [ DEBUG]: Loaded 142 apps from cache
24599 cache 20-05-01 17:14:23 [ DEBUG]: Cache outdated. Need to rebuild
24599 cache 20-05-01 17:14:23 [ DEBUG]: Loaded 243 apps from cache
24599 cache 20-05-01 17:14:23 [ DEBUG]: Loaded 219 apps from cache
24599 cache 20-05-01 17:14:24 [ DEBUG]: Loaded 399 apps from cache
24599 actions.get 20-05-01 17:14:24 [ DEBUG]: Calling get
24599 actions.get.progress 20-05-01 17:14:24 [ DEBUG]: 0
24599 actions.get 20-05-01 17:14:24 [ INFO]: appcenter/apps/nextcloud/ip
24599 actions.get.progress 20-05-01 17:14:24 [ DEBUG]: 100
14963 actions.start 20-05-01 17:14:24 [ INFO]: Starting docker-app-nextcloud (via systemctl): docker-app-nextcloud.service.
14963 actions.start 20-05-01 17:14:24 [ DEBUG]: /etc/init.d/docker-app-nextcloud returned with 0
14963 actions.start.progress 20-05-01 17:14:24 [ DEBUG]: 100
14963 actions.upgrade 20-05-01 17:14:27 [ INFO]: Running command: docker cp /etc/postgresql-nextcloud.secret 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54:/etc/postgresql-nextcloud.secret
14963 docker.base.container.2522 20-05-01 17:14:28 [ DEBUG]: Using container.2522 for container 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54
14963 docker.base.container.2522 20-05-01 17:14:28 [ DEBUG]: Calling docker exec -u root 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54 rm -f /etc/timezone /etc/localtime
14963 docker.base 20-05-01 17:14:28 [ INFO]: Running command: docker cp /etc/timezone 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54:/etc/timezone
14963 docker.base 20-05-01 17:14:29 [ INFO]: Running command: docker cp /etc/localtime 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54:/etc/localtime
14963 actions.configure 20-05-01 17:14:30 [ DEBUG]: Calling configure
14963 actions.configure.progress 20-05-01 17:14:30 [ DEBUG]: 0
14963 actions.configure 20-05-01 17:14:30 [ INFO]: Configuring 4.1/nextcloud=18.0.4-0
14963 docker.configure.container.2522 20-05-01 17:14:30 [ DEBUG]: Using container.2522 for container 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54
14963 docker.configure.container.2522 20-05-01 17:14:30 [ DEBUG]: Calling docker exec -u root 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54 which ucr
14963 actions.configure 20-05-01 17:14:30 [ WARNING]: ucr cannot be found, falling back to changing the database file directly
14963 actions.configure.progress 20-05-01 17:14:30 [ DEBUG]: 100
14963 actions.upgrade.progress 20-05-01 17:14:30 [ DEBUG]: 50
14963 actions.upgrade 20-05-01 17:14:30 [ INFO]: Executing interface restore_data_before_setup for nextcloud
14963 actions.upgrade 20-05-01 17:14:30 [ INFO]: Copying App Center's restore_data_before_setup to container's /usr/share/univention-docker-container-mode/restore_data_before_setup_custom
14963 actions.upgrade.container.2522 20-05-01 17:14:30 [ DEBUG]: Using container.2522 for container 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54
14963 actions.upgrade.container.2522 20-05-01 17:14:30 [ DEBUG]: Calling docker exec -u root 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54 /usr/share/univention-docker-container-mode/restore_data_before_setup_custom --app nextcloud --app-version 18.0.4-0 --error-file /var/univention/tmp/tmpEk2ksQ
14963 actions.upgrade 20-05-01 17:14:31 [ INFO]: Executing interface setup for nextcloud
14963 actions.upgrade 20-05-01 17:14:31 [ INFO]: Copying App Center's setup to container's /usr/share/univention-docker-container-mode/setup_custom
14963 actions.upgrade.container.2522 20-05-01 17:14:31 [ DEBUG]: Using container.2522 for container 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54
14963 actions.upgrade.container.2522 20-05-01 17:14:31 [ DEBUG]: Calling docker exec -u root 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54 /usr/share/univention-docker-container-mode/setup_custom --username Administrator --app nextcloud --error-file /var/univention/tmp/tmprc5CYb --password-file /var/univention/tmp/tmpJgAl4F --app-version 18.0.4-0
14963 actions.upgrade.container.2522 20-05-01 17:14:31 [ WARNING]:
14963 actions.upgrade.container.2522 20-05-01 17:14:31 [ WARNING]: Updating certificates in /etc/ssl/certs...
14963 actions.upgrade.container.2522 20-05-01 17:14:33 [ INFO]: Nextcloud or one of the apps require upgrade - only a limited number of commands are available
14963 actions.upgrade.container.2522 20-05-01 17:14:33 [ INFO]: You may use your browser or the occ upgrade command to do the upgrade
14963 actions.upgrade.container.2522 20-05-01 17:14:34 [ INFO]: No such app enabled: updatenotification
14963 actions.upgrade.container.2522 20-05-01 17:14:34 [ INFO]: Nextcloud or one of the apps require upgrade - only a limited number of commands are available
14963 actions.upgrade.container.2522 20-05-01 17:14:34 [ INFO]: You may use your browser or the occ upgrade command to do the upgrade
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: Nextcloud or one of the apps require upgrade - only a limited number of commands are available
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: You may use your browser or the occ upgrade command to do the upgrade
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - installed: true
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - version: 18.0.4.2
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - versionstring: 18.0.4
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - edition:
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: Enabled:
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - accessibility: 1.4.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - activity: 2.11.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - cloud_federation_api: 1.1.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - comments: 1.8.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - dav: 1.14.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - federatedfilesharing: 1.8.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - federation: 1.8.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - files: 1.13.1
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - files_pdfviewer: 1.7.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - files_rightclick: 0.15.2
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - files_sharing: 1.10.1
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - files_trashbin: 1.8.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - files_versions: 1.11.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - files_videoplayer: 1.7.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - firstrunwizard: 2.7.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - logreader: 2.3.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - lookup_server_connector: 1.6.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - nextcloud_announcements: 1.7.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - notifications: 2.6.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - oauth2: 1.6.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - onlyoffice: 4.1.4
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - password_policy: 1.8.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - photos: 1.0.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - privacy: 1.2.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - provisioning_api: 1.8.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - recommendations: 0.6.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - serverinfo: 1.8.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - settings: 1.0.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - sharebymail: 1.8.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - support: 1.1.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - survey_client: 1.6.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - systemtags: 1.8.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - text: 2.0.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - theming: 1.9.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - twofactor_backupcodes: 1.7.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - user_ldap: 1.8.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - viewer: 1.2.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - workflowengine: 2.0.0
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: Disabled:
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - admin_audit
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - encryption
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - files_external
14963 actions.upgrade.container.2522 20-05-01 17:14:35 [ INFO]: - richdocuments
14963 actions.upgrade.container.2522 20-05-01 17:14:58 [ INFO]: PHP Fatal error: Cannot declare class OCA\Talk\Migration\Version8000Date20200407073807, because the name is already in use in /var/www/html/apps/spreed/lib/Migration/Version8000Date20200407073807.php on line 46
14963 actions.upgrade.container.2522 20-05-01 17:14:58 [ WARNING]: The upgrade log is written to /var/log/nextcloud-upgrade_20_05_01.log within the nextcloud container
14963 actions.upgrade.container.2522 20-05-01 17:14:58 [ INFO]: Nextcloud or one of the apps require upgrade - only a limited number of commands are available
14963 actions.upgrade.container.2522 20-05-01 17:14:58 [ INFO]: You may use your browser or the occ upgrade command to do the upgrade
14963 actions.upgrade.container.2522 20-05-01 17:15:00 [ INFO]: calendar enabled
14963 actions.upgrade.container.2522 20-05-01 17:15:00 [ INFO]: Nextcloud or one of the apps require upgrade - only a limited number of commands are available
14963 actions.upgrade.container.2522 20-05-01 17:15:00 [ INFO]: You may use your browser or the occ upgrade command to do the upgrade
14963 actions.upgrade.container.2522 20-05-01 17:15:02 [ INFO]: contacts enabled
14963 actions.upgrade.container.2522 20-05-01 17:15:02 [ INFO]: Nextcloud or one of the apps require upgrade - only a limited number of commands are available
14963 actions.upgrade.container.2522 20-05-01 17:15:02 [ INFO]: You may use your browser or the occ upgrade command to do the upgrade
14963 actions.upgrade.container.2522 20-05-01 17:15:04 [ INFO]: drawio enabled
14963 actions.upgrade.container.2522 20-05-01 17:15:04 [ INFO]: Nextcloud or one of the apps require upgrade - only a limited number of commands are available
14963 actions.upgrade.container.2522 20-05-01 17:15:04 [ INFO]: You may use your browser or the occ upgrade command to do the upgrade
14963 actions.upgrade.container.2522 20-05-01 17:15:10 [ INFO]: spreed enabled
14963 actions.upgrade.container.2522 20-05-01 17:15:11 [ INFO]: Nextcloud or one of the apps require upgrade - only a limited number of commands are available
14963 actions.upgrade.container.2522 20-05-01 17:15:11 [ INFO]: You may use your browser or the occ upgrade command to do the upgrade
14963 actions.upgrade.container.2522 20-05-01 17:15:15 [ INFO]: user_saml enabled
14963 actions.upgrade.container.2522 20-05-01 17:15:16 [ INFO]: Nextcloud or one of the apps require upgrade - only a limited number of commands are available
14963 actions.upgrade.container.2522 20-05-01 17:15:16 [ INFO]: You may use your browser or the occ upgrade command to do the upgrade
14963 actions.upgrade.container.2522 20-05-01 17:15:16 [ INFO]: .htaccess has been updated
14963 actions.upgrade 20-05-01 17:15:16 [ INFO]: Executing interface restore_data_after_setup for nextcloud
14963 actions.upgrade 20-05-01 17:15:16 [ INFO]: Copying App Center's restore_data_after_setup to container's /usr/share/univention-docker-container-mode/restore_data_after_setup_custom
14963 actions.upgrade.container.2522 20-05-01 17:15:16 [ DEBUG]: Using container.2522 for container 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54
14963 actions.upgrade.container.2522 20-05-01 17:15:16 [ DEBUG]: Calling docker exec -u root 25222bb82ee150a36c12fd1b9380a2d995d98887628f55b1c7bb198650d6ef54 /usr/share/univention-docker-container-mode/restore_data_after_setup_custom --app nextcloud --app-version 18.0.4-0 --error-file /var/univention/tmp/tmp85h637
14963 actions.update-certificates 20-05-01 17:15:17 [ DEBUG]: Calling update-certificates
@Mornsgrans
I was convinced the add-missing-incidices was just indicated if upgrade from version 13 (I think I read this somewhere when the upgrade finished). Nethertheless I did: $ univention-app shell nextcloud sudo -u www-data /var/www/html/occ db:add-missing-indices
which gave me:
Check indices of the share table.
Check indices of the filecache table.
Check indices of the twofactor_providers table.
Check indices of the login_flow_v2 table.
Check indices of the whats_new table.
Check indices of the cards table.
Check indices of the cards_properties table.
Check indices of the calendarobjects_props table.
Adding calendarobject_calid_index index to the calendarobjects_props table, this can take some time...
calendarobjects_props table updated successfully.
Check indices of the schedulingobjects table.
Adding schedulobj_principuri_index index to the schedulingobjects table, this can take some time...
schedulingobjects table updated successfully.
It found some items to update, do you think this could have blocked the upgrade from appcenter?
Concerning the 2 other steps: I first turned off maintenance mode as described above and the browser window to nextcloud allowed me to finish the upgrade.
It may be possible, that missing indices may block the updates from appcenter.
My last three Nextcloud - updates ended with getting stuck in maintenance mode.
I always could finish the upgrade with the three instructions I posted above. After that procedure my Nextcloud started and ran properly. At every update new indices had been added.
I recommend to run the updates first and then finally turn off the maintenance mode to prevent from client logins, which may lead to inconsistency. - I believe, that there is a special reason, why these updates are done in Nextcloud while maintenance mode is on.
Hint:
Please also check the Nextcloud logfile:
If Nextcloud gets stuck in maintenance mode, the loglevel might be in the wrong mode and the logfile becomes flooded by messages (several GBytes per hour).
> Deprecated event type for OCA\User_LDAP\User\User::postLDAPBackendAdded: null
Yes, there are a lot of these. May be this was the reason why some clients should reconnect multiple times after arbitrairy deconnection by the system? Hope loglevel=>2, will solve the problem.
Could you also post the output of univention-app shell nextcloud cat /var/log/nextcloud-upgrade_20_05_01.log?
But there is also PHP Fatal error: Cannot declare class OCA\Talk\Migration\Version8000Date20200407073807, because the name is already in use in /var/www/html/apps/spreed/lib/Migration/Version8000Date20200407073807.php on line 46 (which is known but properly fixed for 19 only iirc) thrown within the upgrade command, which is most likely to made Nextcloud enter maintenance mode. Interesting that this app is not showing up in the list previously, probably due to the same circumstances.
The upgrade has not finished then either (app updates missing i bet) and this is why @Mornsgrans upgrade step helped, and turning off the maintenace mode.
I have an idea how to fix it so Nc does not stay in maintenance mode. Oddly enough this isn’t easy to reproduce/force – it never happened on my upgrade tests.
Hi @blizzz,
Here is what # univention-app shell nextcloud cat /var/log/nextcloud-upgrade_20_05_01.log
gives me:
Set log level to debug
Turned on maintenance mode
Updating database schema
Updated database
Disabled incompatible app: calendar
Disabled incompatible app: contacts
Disabled incompatible app: drawio
Disabled incompatible app: spreed
Disabled incompatible app: user_saml
Checking for update of app accessibility in appstore
Checked for update of app "accessibility" in appstore
Checking for update of app activity in appstore
Checked for update of app "activity" in appstore
Checking for update of app cloud_federation_api in appstore
Checked for update of app "cloud_federation_api" in appstore
Checking for update of app comments in appstore
Checked for update of app "comments" in appstore
Checking for update of app dav in appstore
Checked for update of app "dav" in appstore
Checking for update of app federatedfilesharing in appstore
Checked for update of app "federatedfilesharing" in appstore
Checking for update of app federation in appstore
Checked for update of app "federation" in appstore
Checking for update of app files in appstore
Checked for update of app "files" in appstore
Checking for update of app files_pdfviewer in appstore
Checked for update of app "files_pdfviewer" in appstore
Checking for update of app files_rightclick in appstore
Checked for update of app "files_rightclick" in appstore
Checking for update of app files_sharing in appstore
Checked for update of app "files_sharing" in appstore
Checking for update of app files_trashbin in appstore
Checked for update of app "files_trashbin" in appstore
Checking for update of app files_versions in appstore
Checked for update of app "files_versions" in appstore
Checking for update of app files_videoplayer in appstore
Checked for update of app "files_videoplayer" in appstore
Checking for update of app firstrunwizard in appstore
Checked for update of app "firstrunwizard" in appstore
Checking for update of app logreader in appstore
Checked for update of app "logreader" in appstore
Checking for update of app lookup_server_connector in appstore
Checked for update of app "lookup_server_connector" in appstore
Checking for update of app nextcloud_announcements in appstore
Checked for update of app "nextcloud_announcements" in appstore
Checking for update of app notifications in appstore
Checked for update of app "notifications" in appstore
Checking for update of app oauth2 in appstore
Checked for update of app "oauth2" in appstore
Checking for update of app onlyoffice in appstore
Checked for update of app "onlyoffice" in appstore
Checking for update of app password_policy in appstore
Checked for update of app "password_policy" in appstore
Checking for update of app photos in appstore
Checked for update of app "photos" in appstore
Checking for update of app privacy in appstore
Checked for update of app "privacy" in appstore
Checking for update of app provisioning_api in appstore
Checked for update of app "provisioning_api" in appstore
Checking for update of app recommendations in appstore
Checked for update of app "recommendations" in appstore
Checking for update of app serverinfo in appstore
Checked for update of app "serverinfo" in appstore
Checking for update of app settings in appstore
Checked for update of app "settings" in appstore
Checking for update of app sharebymail in appstore
Checked for update of app "sharebymail" in appstore
Checking for update of app support in appstore
Checked for update of app "support" in appstore
Checking for update of app survey_client in appstore
Checked for update of app "survey_client" in appstore
Checking for update of app systemtags in appstore
Checked for update of app "systemtags" in appstore
Checking for update of app text in appstore
Checked for update of app "text" in appstore
Checking for update of app theming in appstore
Checked for update of app "theming" in appstore
Checking for update of app twofactor_backupcodes in appstore
Checked for update of app "twofactor_backupcodes" in appstore
Checking for update of app user_ldap in appstore
Checked for update of app "user_ldap" in appstore
Checking for update of app viewer in appstore
Checked for update of app "viewer" in appstore
Checking for update of app workflowengine in appstore
Checked for update of app "workflowengine" in appstore
Checking for update of app calendar in appstore
Checked for update of app "calendar" in appstore
Checking for update of app contacts in appstore
Checked for update of app "contacts" in appstore
Checking for update of app drawio in appstore
Checked for update of app "drawio" in appstore
Checking for update of app spreed in appstore
Checked for update of app "spreed" in appstore
Repair error: Repair step 'OCA\Talk\Migration\FixNamespaceInDatabaseTables' is unknown
Note that I installed a turn server trough Package Management of UCS ->
coturn TURN and STUN server for VoIP installed
in order to use video conferencing in talk (which did not work). As log file above has entrys about Talk I thought there could maybe a relationship?
@blizzz
sorry, didn’t pay attention to this detail PHP Fatal error: Cannot declare class OCA\Talk\Migration\Version8000Date20200407073807, because the name is already in use in /var/www/html/apps/spreed/lib/Migration/Version8000Date20200407073807.php on line 46 -> could there be a relationship to copano meet? (see posting bellow)
greetings
I don’t know. In my opinion the update could not create te file, because it was just existing. - That is the reason, why I did not comment that error message.
