Nextcloud 18.0.4 Maintenance mode
Thanks, should not occur anymore with future updates.
Have the same Problem.
After upgrading Nextcloud via Appcenter from V17 --> V18.0.4 --> V18.0.6
Nextcloud.log stop with this message.
ā€œmessageā€:ā€œMemcache \OC\Memcache\APCu not available for distributed cacheā€,ā€œuserAgentā€:"–",ā€œversionā€:ā€œ18.0.6.0ā€}
ā€œmessageā€:ā€œWe are in maintenance mode, skipping cronā€,ā€œuserAgentā€:"–",ā€œversionā€:ā€œ18.0.6.0ā€}
What does that mean.
P.S. I changed in config.php the command to ā€˜maintenance’ => false,
Thanks for help.
greetings.
Ralph
Did you try to turn off maintenance mode as described above?
In Nextcloud help-forum I found this thread concerning the message (Nextcloud 13).
@KRalph : Hi, I think this won’t be any help for you: my upgrade V18.0.4 --> V18.0.6 worked like a charme. Maybe my workaround described here: My initial Workaround helps.
@blizzz : As the described above V18.0.4 --> V18.0.6 worked without any failure. Maybe you could have a look to KRalph’s problem ?
greetings mangrovenjazz
