How-To: Set Correct Nameserver and Forwarder Entries for UCS Servers
How to set correct nameserver and forwarder entries for UCS servers
UCS (and ActiveDirectory) relies on reliable DNS resolving. It is very important to have DNS up and running correctly.
Foreword
You can fix the UCS-domain and forward DNS servers by running the following script:
/usr/share/univention-server/univention-fix-ucr-dns
Step 1: Set forwarder
The forwarder will resolve all non-local domains so you will be able to access Internet services. You have to decide if you use the DNS server of your Internet provider or if you use some public available servers.
Ideally, you should set at least a second forwarder as fallback in case of failure. If you have a choice, use the DNS servers close to your geographical location.
Note: Usually this is NOT a UCS server!
ucr set dns/forwarder1=45.33.97.5 \
        dns/forwarder2=51.15.98.97 \
        dns/forwarder3=208.67.222.222
Step 2: Set nameserver for your local network
On each UCS server (except member server) you should set it’s own IP as first nameserver and then add the IP addresses of other UCS hosts in order to get some load balancing and fallback in case of failure. You should NOT use the localhost address (127.0.0.1) here:
ucr set nameserver1=<IP of this UCS server> \
        nameserver2=<IP of other UCS server> \
        nameserver3=<IP of third UCS server>
For UCS systems with the role “Member server” use the IP addresses of a UCS Master, Backup and/or Slave of your domain.
Step 3: Define the nameserver for your clients
No matter if you assign IP-adresses to your clients by DHCP (even a non-UCS DHCP server) or manually. Your clients should use the UCS servers as DNS server (“nameserver”).
Check for Windows:
C:\Users\foo@multi.ucs>ipconfig /all
Windows-IP-Konfiguration
   Hostname  . . . . . . . . . . . . : bar
   Primäres DNS-Suffix . . . . . . . : multi.ucs     <-- UCS domain
   Knotentyp . . . . . . . . . . . . : Hybrid
   IP-Routing aktiviert  . . . . . . : Nein
   WINS-Proxy aktiviert  . . . . . . : Nein
   DNS-Suffixsuchliste . . . . . . . : multi.ucs     <-- UCS domain
Ethernet-Adapter Ethernet:
   Verbindungsspezifisches DNS-Suffix: multi.ucs     <-- UCS domain
   DHCP-Server . . . . . . . . . . . : 192.168.9.10    <--- UCS server!
Check for Ubuntu-Linux:
foo@bar:~$ systemd-resolve --status
Link 6 (tun1)
      Current Scopes: DNS
       LLMNR setting: yes
MulticastDNS setting: no
      DNSSEC setting: no
    DNSSEC supported: no
         DNS Servers: 192.168.9.10 # Should be a UCS server!
                      192.168.9.100 # Should be a UCS server!
                      192.168.1.10 # Should be a UCS server!
          DNS Domain: multi.ucs # Should be your UCS domain!
