I hope someone can give me a hint for the following problem:
I have installed UCS and imported some users/hosts from a legacy ldap server. Now I got a small hiccup: dns forwarding doesn’t work. I followed this guide and verified my settings as follows:
root@ucs-master:~# ucr search --brief ^nameserv dns/forward
dns/forwarder1: 1.1.1.1
dns/forwarder2: 8.8.8.8
dns/forwarder3: 9.9.9.9
nameserver/external: false
nameserver/option/timeout: 2
nameserver1: 1.2.3.4
nameserver2: <empty>
nameserver3: <empty>
where 1.2.3.4 is the ip of the ucs server. When I test from another server:
dig @1.2.3.4 somehost.mydomain.com
it works (mydomain.com is domain on the ucs server and somehost entry exists)
but
dig @1.2.3.4 google.com
does not (empty response).
I have been pulling my hair for a while now, since I also installed another UCS server in the past using the same procedure, and dns forwarding works fine on that server.
What am I missing, or what can I try to troubleshoot the problem?
Edit: on ucs server the following commands work
dig somehost.mydomain.com
dig google.com
Edit2: dns/backend is ldap:
root@ucs-master:/etc/bind# ucr search --brief dns/backend
dns/backend: ldap
Regards,
Tony
