Hallo nochmal,
hab soeben einen zweiten Anlauf im Livesystem hinter mir, nachdem es auf meinem Testsystem einwandfrei klappte.
nun hab ich jedoch die Logs etwas durchgesehen und hier ein Auszug davon:
gateway.logWed Dec 17 21:42:55 2014: [ 7362] Connection closed because of timeout
Wed Dec 17 21:42:55 2014: [ 7409] Connection closed because of timeout
Wed Dec 17 22:13:21 2014: [13583] Connection closed because of timeout
Wed Dec 17 22:18:18 2014: [13568] Connection closed because of timeout
Wed Dec 17 22:31:14 2014: [13576] Client disconnected
Wed Dec 17 22:31:17 2014: [26546] Client disconnected
Wed Dec 17 22:31:51 2014: [26619] Connection error.
Wed Dec 17 22:33:49 2014: [ 2147] POP3/IMAP Gateway will now exit
Wed Dec 17 22:53:23 2014: [ 2083] Starting zarafa-gateway version 7,1,11,46050 (46050), pid 2083
licensed.logWed Dec 17 22:33:50 2014: Exiting
Wed Dec 17 22:53:23 2014: Base serial xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx found, valid for 55 users
Wed Dec 17 22:53:23 2014: Cal xxxxxxxxxxxxxxxxxxxxxx found, valid for 40 users
Wed Dec 17 22:53:23 2014: ZCP license for 95 users
Wed Dec 17 22:53:23 2014: Enabling Professional functions
Wed Dec 17 22:53:23 2014: Starting zarafa-licensed version 7,1,11,46050 (46050), pid 2130
monitor.logWed Dec 17 22:33:50 2014: Previous message logged 5 times
Wed Dec 17 22:33:50 2014: Termination requested, shutting down.
Wed Dec 17 22:53:23 2014: Starting zarafa-monitor version 7,1,11,46050 (46050), pid 2142
Wed Dec 17 23:00:03 2014: Unable to get userlist for company Default, error code 0x8004010F
spooler.logWed Dec 17 21:26:13 2014: [13284] E-mail for user klaus.xxxxxxxx was accepted by SMTP server
Wed Dec 17 22:31:01 2014: [ 2226] Table reload requested, breaking server connection
Wed Dec 17 22:31:06 2014: [ 2226] Server connection lost. Reconnecting in 3 seconds...
Wed Dec 17 22:31:12 2014: [ 2226] Connection to Zarafa server succeeded after 1 retries
Wed Dec 17 22:33:53 2014: [ 2226] Still waiting for 0 threads to exit.
Wed Dec 17 22:33:53 2014: [ 2226] Spooler shutdown complete
Wed Dec 17 22:53:24 2014: [ 2185] Starting zarafa-spooler version 7,1,11,46050 (46050), pid 2185
Wed Dec 17 22:53:24 2014: [ 2185] Using SMTP server: localhost, port 25
Wed Dec 17 22:53:56 2014: [ 2185] Connection to Zarafa server succeeded
search.logWed Dec 17 12:58:35 2014: [0xd6a6e700] Search thread started
Wed Dec 17 22:30:43 2014: [0xd8372700] Previous message logged 59 times
Wed Dec 17 22:30:43 2014: [0xd8372700] Unable to config system exporter: 80040116
Wed Dec 17 22:30:44 2014: [0xd8372700] Change processing failed: 80040116
Wed Dec 17 22:33:50 2014: [0xde0d0760] Termination requested, shutting down.
Wed Dec 17 22:33:50 2014: [0xde0d0760] Stopping Zarafa search...
Wed Dec 17 22:53:24 2014: [0x19980760] Starting zarafa-search version 7,1,11,46050 (46050), pid 2154
Wed Dec 17 22:53:24 2014: [0x13c22700] Unable to contact zarafa server file:///var/run/zarafa: 80040115. Will retry.
Wed Dec 17 22:53:58 2014: [0x1231e700] Search thread started
dagent.logWed Dec 17 23:06:59 2014: [ 7157] Failed to resolve recipient anja.xxxxxxxxxxxxxxxxxx
Wed Dec 17 23:06:59 2014: [ 7157] Requested e-mail address 'anja.xxxxxx@xxx.at' does not resolve a user.
Wed Dec 17 23:06:59 2014: [ 7158] Access denied or Connection failed for user silke.xxxxxxx, using socket: 'file:///var/run/zarafa', error code: 0x80040111
Wed Dec 17 23:06:59 2014: [ 7158] Current uid:0 username:root
Wed Dec 17 23:06:59 2014: [ 7163] Unable to open addressbook
Wed Dec 17 23:06:59 2014: [ 7166] Failed to resolve recipient manuel.xxx@xxx.at
Wed Dec 17 23:06:59 2014: [ 7166] Requested e-mail address 'manuel.xxx@xxx.at' does not resolve a user.
Wed Dec 17 23:07:00 2014: [ 7168] Access denied or Connection failed for user silke.xxxxxxxxx, using socket: 'file:///var/run/zarafa', error code: 0x80040111
Wed Dec 17 23:07:00 2014: [ 7168] Current uid:0 username:root
Wed Dec 17 23:08:16 2014: [ 7244] Access denied or Connection failed for user manuel.xxxxxxxxx, using socket: 'file:///var/run/zarafa', error code: 0x80040111
Wed Dec 17 23:08:16 2014: [ 7244] Current uid:0 username:root
Wed Dec 17 23:08:16 2014: [ 7246] Failed to resolve recipient silke.xxxxxxxxx@xxx.at
Wed Dec 17 23:08:16 2014: [ 7246] Requested e-mail address 'silke.xxxxxxx@xxx.at' does not resolve a user.
Wed Dec 17 23:08:16 2014: [ 7250] Access denied or Connection failed for user xxx.unbekannt, using socket: 'file:///var/run/zarafa', error code: 0x80040111
Wed Dec 17 23:08:16 2014: [ 7250] Current uid:0 username:root
Wed Dec 17 23:08:16 2014: [ 7251] Access denied or Connection failed for user markus.xxxxxxxxx, using socket: 'file:///var/run/zarafa', error code: 0x80040111
Wed Dec 17 23:08:16 2014: [ 7251] Current uid:0 username:root
Wed Dec 17 23:08:16 2014: [ 7261] Access denied or Connection failed for user markus.xxxxxxxxx, using socket: 'file:///var/run/zarafa', error code: 0x80040111
Wed Dec 17 23:08:16 2014: [ 7261] Current uid:0 username:root
Wed Dec 17 23:08:16 2014: [ 7260] Unable to deliver message to 'markus.xxxxxxxxx', error code: 0x8004010F
Wed Dec 17 23:08:16 2014: [ 7260] Unable to deliver all messages for server 'file:///var/run/zarafa'
Wed Dec 17 23:08:16 2014: [ 7264] Access denied or Connection failed for user silke.xxxxxxxxx, using socket: 'file:///var/run/zarafa', error code: 0x80040111
Wed Dec 17 23:08:16 2014: [ 7264] Current uid:0 username:root
Wed Dec 17 23:08:17 2014: [ 7248] Delivered message to 'manuel.xxxxxxxxxx', Subject: "Ticketmail xxxxxx SVN", Message-Id: <49294.101418853720323.JavaMail.root@report-sr$
Wed Dec 17 23:08:18 2014: [ 7261] Client disconnected
Wed Dec 17 23:08:18 2014: [ 7260] Client disconnected
Wed Dec 17 23:08:18 2014: [ 7264] Client disconnected
server.logWed Dec 17 22:33:50 2014: Previous message logged 19 times
Wed Dec 17 22:33:50 2014: Shutting down.
Wed Dec 17 22:33:51 2014: Still waiting for 8 threads to exit
Wed Dec 17 22:33:53 2014: Server shutdown complete.
Wed Dec 17 22:53:24 2014: Starting zarafa-server version 7,1,11,46050, pid 2168
Wed Dec 17 22:53:24 2014: Listening for priority pipe connections on /var/run/zarafa-prio
Wed Dec 17 22:53:24 2014: Listening for pipe connections on /var/run/zarafa
Wed Dec 17 22:53:24 2014: Listening for TCP connections on port 236
Wed Dec 17 22:53:24 2014: Listening for SSL connections on port 237
Wed Dec 17 22:53:24 2014: Connection to database 'zarafa' succeeded
Wed Dec 17 22:53:24 2014: Using commercial license serial xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Wed Dec 17 22:53:25 2014: Loading searchfolders
Wed Dec 17 22:53:56 2014: Startup succeeded on pid 2172
Wed Dec 17 22:53:56 2014: ldap query failed: dc=ec,dc=intra (&(&(zarafaAccount=1)(|(objectClass=posixAccount)))(|(uid=michael\2Eputzinger))) (result=0x01)
als Laie würde ich sagen, da stimmt was mit dem LDAP nicht, bloß was? Ich hab mittlerweile wieder auf mein zuvoriges Backup zurückgeswitcht. Leider hab ich am Livesystem nur noch knapp 3,5GB HDD frei. Schön langsam wirds also knapp mit dem HDD Speicher. Ich sollte also bis zum Wochenende die Vergrößerung irgendwie hinbekommen, leider kann ich am Livesystem immer nur um diese Zeit arbeiten um den Betrieb nicht zu stören
Naja, Vielleicht kann mir ja jemand helfen aufgrund dieser LOG Einträge?
Lg,
Michael Putzinger
