Using ZFS with UCS
Anyone here with experience from using ZFS filesystem with UCS. Planning on using a ZFS filer for my KVM VM’s.
Would it be possible to install UCS on top of ZFS.
Feedback would be appreciated.
as UCS is (more or less) Debian you could try this link.
But I am not aware someone has tried this. I know from my own experience having UCS with BTRFS for data. So just using ZFS for data should be much easier than putting the complete system (incl /) on ZFS.
/CV
i am using zfs with proxmox and running ucs as a guest
the trick is to share the files with nfs and pickup with ucs as a dc
you can find a example here
Thats great, however I’m not using Proxmox and not planning to.
My ambition is to stay with UCS for servers and Ubuntu for clients, possibly a single Windows10 laptop.
I was hoping for a scenario where I can set up a UCS file server on top of ZFS one way or another.
My box has 16 GB RAM, 3x1Tb HDD, 2x250GB SSD (SATA 3). The motherboard has a RAID controller and I have added 1XSATA3 PCI RAID controller. The HDD’s are on the motherboard and the SSD’s on the PCI controller
I have a UCS domain with two UCS-KVM servers in production. I was hoping for a more flexible solution for storing my VM’s and a better solution for snapshots. Currently I’m using local storage for my VM’s and that’s a bit cumbersome. As I’m understanding it, is iSCSI not supported on Linux with ZFS so I guess I have to do with NFS, will 1Gb Nics be sufficient for data transfer? Currently I have a light load on all servers both virtual and physical.
I have an idea but I dont know if it’s viable.
  1. Set up a 40 GB partition on as mirror on the SSD. leaving the remainder (210 GB) for ZFS intent log and possibly L2ARC.
  2. Install UCS file/printserver on the 40 GB partition.
  3. Install ZFS on the file/printserver
    4 Configure the rest of the storage with ZFS
I understand that FreeNAS could be a solution but that means I no longer have a consistent serverplatform.
Any suggestion.
I GOT IT ! host on SSD RAID1 (ext4) and the rest of the storage as ZFS Raidz.
However I haven’t made any performance test yet.
I haven’t figured out yet how to set up ZFS as Univention boot and root yet. What I did is a Univention setup master DC onto a software RAID 1 on my SSD drives. Leaving the 3 hard-drives not configured.
Using https://linuxhint.com/install-zfs-debian/ the installation was a breeze no hiccups at all, only difference was that the hard-drives were already set up as a ZFS pool from my previous experiment with FreeNas. Using “zpool import -f tank1” solved the problem.
My first Univention server is a primary DC with file/print, KVM and UVMM.
  1. First I changed the KVM default pool to /tank1/iocage/images (the folder structure came from my FreeNas experience. I first destroyed the /var/lib/libvirt/images pool and created /tank1/iocage/images pool only to realize that there was a UCR variable that I needed to change. my guess is that I only had to change the UCR variable.
  2. Created a Univention share on /tank1/iocage/images as Images and it worked perfectly from my WIN10 laptop.
  3. Created a KVM guest using without problem. Default settings could not be used “No host caching, no forced sync (none)”, I used “Hypervisor default”. You need to save the VM configuration and then edit the Caching variable. I have yet to figure out the other caching methods.
Anyway my Univention VM is working as it should. Could be a different thing when loaded.
Snapshot’s are working. Whats bugging me is that I cannot snapshot my host :frowning: but that’s comes from the setup, my SSD’s are still ext4.
With the easy setup and snapshot’s, and easy management/configuration I can only wish that it will be a future option for UCS.
Regards Bengt-Åke
So now I have it finally running
Proxmox 6.2
Open Media Vault under Debian 9 running on LXC
Joined to Windows or UCS
Bildschirmfoto 2020-06-09 um 18.14.19 Bildschirmfoto 2020-06-09 um 18.30.56Bildschirmfoto 2020-06-09 um 18.32.13 Bildschirmfoto 2020-06-09 um 18.31.53
