Use parted for resize space with owncloud appliance
Hi. How can I use parted with the resizepart command? Which partition should I indicate? Primary, extended or logical? Risk of losing data? Thank you so much
you have searched and found this article?
Any reasons why you want to use parted?
/CV
Hi, and thanks for your answer.
Yes, I see article.
Parted seems simpler to me.
I’m not an expert.
again. In the article it is describe step-by-step. You expect it to be simpler by using a different tool?
Anyways, of course it is up to you.
/CV
Hi Christian.
Thank you again. I’m not expert: the parted tool seems simpler with one step.
I do not know what to do: How to extend ownCloud storage
In this article speaks of parted, but don’t understend if it’s right.
In fact, afterwards the article you propose is posted.
