Kudos @knebb
Note: There is a video available which is based on this article.
Check the steps (these steps are valid for a Owncloud image downloaded just recently, some numbers might change in later or earlier editions); Nextcloud should be similar.
Step 1: Extend the HDD of the virtual machine (VM) itself
- Power off the VM
- Take a snapshot for rollback in case something goes wrong
- Edit Settings and extend from 50GB to the desired size
- Power on the VM
Step 2: Edit partition table
- Login on the command line as root
fdisk /dev/sda- Print current partition table, note the “start” values of
/dev/sda2and/dev/sda5
Command (m for help): p
Disk /dev/sda: 150 GiB, 161061273600 bytes, 314572800 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x1ed9986f
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 999423 997376 487M 83 Linux
/dev/sda2 1001470 104855551 103854082 49,5G 5 Extended
/dev/sda5 1001472 104855551 103854080 49,5G 8e Linux LVM
- Delete (yes!) partition 5 and 2 (in that order!)
Command (m for help): d
Partition number (1,2,5, default 5): 5
Partition 5 has been deleted.
Partition number (1,2, default 2): 2
Partition 2 has been deleted.
- Re-Create the logical partition
/dev/sda2with the starting block as noted above (usually 1001470)
Command (m for help): n
Partition type
p primary (1 primary, 0 extended, 3 free)
e extended (container for logical partitions)
Select (default p): e
Partition number (2-4, default 2):
First sector (999424-314572799, default 999424): 1001470
Last sector, +sectors or +size{K,M,G,T,P} (1001470-314572799, default 314572799):
Created a new partition 2 of type 'Extended' and of size 149,5 GiB.
- Re-create the extended partition
/dev/sda5with a whatever starting point (just press enter both times!). Take care NOT to remove the ext4 signature!
All space for primary partitions is in use.
Adding logical partition 5
First sector (1003518-314572799, default 1003520):
Last sector, +sectors or +size{K,M,G,T,P} (1003520-314572799, default 314572799):
Created a new partition 5 of type 'Linux' and of size 149,5 GiB.
Partition #5 contains a ext4 signature.
Do you want to remove the signature? [Y]es/[N]o: n
- Change into the Expert menu and set the beginning of your new
/dev/sda5to the previously noted value (usually 1001472):
Command (m for help): x
Expert command (m for help): b
New beginning of data (1001471-314572799, default 1003520): 1001472
- Verify starting numbers of
/dev/sda2and/dev/sda5 are the same as noted above in step 2-2.
Expert command (m for help): p
Disklabel type: dos
Device Boot Start End Sectors Id Type Start-C/H/S End-C/H/S Attrs
/dev/sda1 * 2048 999423 997376 83 Linux 0/32/33 62/53/55 80
/dev/sda2 1001470 314572799 313571330 5 Extended 62/86/23 125/64/3
/dev/sda5 1001472 314572799 313571328 83 Linux 62/118/57 125/64/3
- Leave the expert menu and write the partition table to disk, leave fdisk
Expert command (m for help): r
Command (m for help): w
The partition table has been altered.
Calling ioctl() to re-read partition table.
Re-reading the partition table failed.: Das Gerät oder die Ressource ist belegt
The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8).
- Reboot the VM; it should come up properly
Step 3: Resize LVM and filesystem
- Login again to the VM as in previous steps
- Resize physical volume:
pvresize /dev/sda5
root@owncloud:~# pvresize /dev/sda5
Physical volume "/dev/sda5" changed
1 physical volume(s) resized / 0 physical volume(s) not resized
- Verify it has been resized, the line “Free PE” should NOT be zero!
root@owncloud:~# pvdisplay -v
Wiping internal VG cache
Wiping cache of LVM-capable devices
--- Physical volume ---
PV Name /dev/sda5
VG Name vg_ucs
PV Size 149,52 GiB / not usable 2,00 MiB
Allocatable yes
PE Size 4,00 MiB
Total PE 38277
Free PE 25600
Allocated PE 12677
PV UUID eEOcDZ-x27e-ivIp-HAUf-Um67-t5MP-Pzbdp2
- Resize the logical volume and use the number of FreePE from Step 3-3 (here: 25600).
root@owncloud:~# lvresize /dev/vg_ucs/root -l +25600
Size of logical volume vg_ucs/root changed from 47,52 GiB (12165 extents) to 147,52 GiB (37765 extents).
Logical volume vg_ucs/root successfully resized.
- Resize the filesystem itself
root@owncloud:~# resize2fs /dev/vg_ucs/root
resize2fs 1.43.4 (31-Jan-2017)
Dateisystem bei /dev/vg_ucs/root ist auf / eingehängt; Online-Größenänderung ist
erforderlich
old_desc_blocks = 10, new_desc_blocks = 19
Das Dateisystem auf /dev/vg_ucs/root is nun 38671360 (4k) Blöcke lang.
- Verify by df:
root@owncloud:~# df -h
Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
udev 10M 0 10M 0% /dev
tmpfs 292M 17M 276M 6% /run
/dev/mapper/vg_ucs-root 143G 3,6G 133G 3% /
tmpfs 730M 0 730M 0% /dev/shm
tmpfs 5,0M 0 5,0M 0% /run/lock
tmpfs 730M 0 730M 0% /sys/fs/cgroup
/dev/sda1 472M 61M 387M 14% /boot
overlay 143G 3,6G 133G 3% /var/lib/docker/overlay/662d4e26b808c849850c03b569052b578f311fde1afce09df1bcc9bfd9d63227/merged
shm 64M 0 64M 0% /var/lib/docker/containers/332300a8c307b732a76bf22720b5585a14b53aab5fc969783253add8c8543109/shm
All done now. You Owncloud appliance now has more disk space available.
Note: It would be much easier to do if Own-/ Nextcloud had mounted /var on a separate disk!
