Upgrade failure
When I try to upgrade to 4.4.7, I receive the following error message.
(Reading database ... 111177 files and directories currently installed.)
Preparing to unpack .../univention-errata-level_4.4.7-863_all.deb ...
Unpacking univention-errata-level (4.4.7-863) over (4.4.7-862) ...
Setting up univention-errata-level (4.4.7-863) ...
Setting version/erratalevel
Module: kopano-cfg
File: /etc/lsb-release
File: /etc/apt/apt.conf.d/55user_agent
The update has been finished successfully at Tue Jan 12 21:08:47 CET 2021.
Starting univention-upgrade. Current UCS version is 4.4-6 errata863
Checking for package updates:
none
Checking for app updates:                               found
Please rerun command without --check argument to install.
Hopefully one of you can tell me how I can solve this issue.
Hello, is there nobody, that can put me in the right direction?
Currently I receive the message: “The currently used UCS version is out of maintenance.”
I just try it again to install the upgrade, and this is what I found in the log
Starting update process, this may take a while.
Check /var/log/univention/updater.log for more information.
Sat Jan 16 21:11:47 CET 2021
Hit:1 https://repo.z-hub.io/z-push:/final/Univention_4.3  InRelease
Ign:2 https://updates.software-univention.de/4.4/maintained 4.4-7/all/ InRelease
Ign:3 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component kopano-core_20191114105932/all/ InRelease
Ign:4 https://updates.software-univention.de/4.4/maintained 4.4-7/amd64/ InRelease
Ign:5 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component kopano-core_20191114105932/amd64/ InRelease
Ign:6 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component kopano-webapp_20200618121103/all/ InRelease
Ign:7 https://updates.software-univention.de/4.4/unmaintained 4.4-7/all/ InRelease
Ign:8 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component kopano-webapp_20200618121103/amd64/ InRelease
Ign:9 https://updates.software-univention.de/4.4/unmaintained 4.4-7/amd64/ InRelease
Ign:10 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component ucc_20160811170611/all/ InRelease
Ign:11 https://updates.software-univention.de/4.4/maintained/component 4.4-6-errata/all/ InRelease
Ign:12 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component ucc_20160811170611/amd64/ InRelease
Ign:13 https://updates.software-univention.de/4.4/maintained/component 4.4-6-errata/amd64/ InRelease
Ign:14 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component z-push-kopano_20190426122615/all/ InRelease
Ign:15 https://updates.software-univention.de/4.4/unmaintained/component 4.4-6-errata/all/ InRelease
Ign:16 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component z-push-kopano_20190426122615/amd64/ InRelease
Ign:17 https://updates.software-univention.de/4.0/maintained 4.0-0/all/ InRelease
Ign:18 https://appcenter.software-univention.de/univention-repository/4.3/maintained/component kopano-core_20191114105932/all/ InRelease
Ign:19 https://updates.software-univention.de/4.0/maintained 4.0-0/amd64/ InRelease
Ign:20 https://appcenter.software-univention.de/univention-repository/4.3/maintained/component kopano-core_20191114105932/amd64/ InRelease
Ign:21 https://appcenter.software-univention.de/univention-repository/4.3/maintained/component ucc_20160811170611/all/ InRelease
Ign:22 https://updates.software-univention.de/4.0/unmaintained 4.0-0/all/ InRelease
Ign:23 https://appcenter.software-univention.de/univention-repository/4.3/maintained/component ucc_20160811170611/amd64/ InRelease
Ign:24 https://updates.software-univention.de/4.0/unmaintained 4.0-0/amd64/ InRelease
Ign:25 https://appcenter.software-univention.de/univention-repository/4.2/maintained/component ucc_20160811170611/all/ InRelease
Ign:26 https://updates.software-univention.de/4.0/maintained 4.0-1/all/ InRelease
Ign:27 https://appcenter.software-univention.de/univention-repository/4.2/maintained/component ucc_20160811170611/amd64/ InRelease
Ign:28 https://updates.software-univention.de/4.0/maintained 4.0-1/amd64/ InRelease
Ign:29 https://appcenter.software-univention.de/univention-repository/4.1/maintained/component ucc_20160811170611/all/ InRelease
Ign:30 https://updates.software-univention.de/4.0/unmaintained 4.0-1/all/ InRelease
Ign:31 https://appcenter.software-univention.de/univention-repository/4.1/maintained/component ucc_20160811170611/amd64/ InRelease
Ign:32 https://updates.software-univention.de/4.0/unmaintained 4.0-1/amd64/ InRelease
Hit:33 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component kopano-core_20191114105932/all/ Release
Ign:34 https://updates.software-univention.de/4.0/maintained 4.0-2/all/ InRelease
Hit:35 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component kopano-core_20191114105932/amd64/ Release
Ign:36 https://updates.software-univention.de/4.0/maintained 4.0-2/amd64/ InRelease
Hit:37 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component kopano-webapp_20200618121103/all/ Release
Ign:38 https://updates.software-univention.de/4.0/unmaintained 4.0-2/all/ InRelease
Hit:39 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component kopano-webapp_20200618121103/amd64/ Release
Ign:41 https://updates.software-univention.de/4.0/unmaintained 4.0-2/amd64/ InRelease
Hit:42 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component ucc_20160811170611/all/ Release
Ign:43 https://updates.software-univention.de/4.0/maintained 4.0-3/all/ InRelease
Hit:44 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component ucc_20160811170611/amd64/ Release
Ign:45 https://updates.software-univention.de/4.0/maintained 4.0-3/amd64/ InRelease
Hit:46 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component z-push-kopano_20190426122615/all/ Release
Ign:47 https://updates.software-univention.de/4.0/unmaintained 4.0-3/all/ InRelease
Hit:48 https://appcenter.software-univention.de/univention-repository/4.4/maintained/component z-push-kopano_20190426122615/amd64/ Release
Ign:50 https://updates.software-univention.de/4.0/unmaintained 4.0-3/amd64/ InRelease
Hit:51 https://appcenter.software-univention.de/univention-repository/4.3/maintained/component kopano-core_20191114105932/all/ Release
Ign:52 https://updates.software-univention.de/4.0/maintained 4.0-4/all/ InRelease
Hit:53 https://appcenter.software-univention.de/univention-repository/4.3/maintained/component kopano-core_20191114105932/amd64/ Release
Ign:54 https://updates.software-univention.de/4.0/maintained 4.0-4/amd64/ InRelease
Hit:55 https://appcenter.software-univention.de/univention-repository/4.3/maintained/component ucc_20160811170611/all/ Release
Ign:57 https://updates.software-univention.de/4.0/unmaintained 4.0-4/all/ InRelease
Hit:58 https://appcenter.software-univention.de/univention-repository/4.3/maintained/component ucc_20160811170611/amd64/ Release
Ign:59 https://updates.software-univention.de/4.0/unmaintained 4.0-4/amd64/ InRelease
Hit:60 https://appcenter.software-univention.de/univention-repository/4.2/maintained/component ucc_20160811170611/all/ Release
Ign:61 https://updates.software-univention.de/4.0/maintained 4.0-5/all/ InRelease
Hit:62 https://appcenter.software-univention.de/univention-repository/4.2/maintained/component ucc_20160811170611/amd64/ Release
Ign:63 https://updates.software-univention.de/4.0/maintained 4.0-5/amd64/ InRelease
Hit:65 https://appcenter.software-univention.de/univention-repository/4.1/maintained/component ucc_20160811170611/all/ Release
Ign:66 https://updates.software-univention.de/4.0/unmaintained 4.0-5/all/ InRelease
Hit:67 https://appcenter.software-univention.de/univention-repository/4.1/maintained/component ucc_20160811170611/amd64/ Release
Ign:68 https://updates.software-univention.de/4.1/maintained 4.1-0/all/ InRelease
Ign:69 https://updates.software-univention.de/4.1/maintained 4.1-0/amd64/ InRelease
Ign:71 https://updates.software-univention.de/4.1/unmaintained 4.1-0/all/ InRelease
Ign:72 https://updates.software-univention.de/4.1/unmaintained 4.1-0/amd64/ InRelease
Ign:73 https://updates.software-univention.de/4.1/maintained 4.1-1/all/ InRelease
Ign:74 https://updates.software-univention.de/4.1/maintained 4.1-1/amd64/ InRelease
Ign:76 https://updates.software-univention.de/4.1/unmaintained 4.1-1/all/ InRelease
Ign:77 https://updates.software-univention.de/4.1/unmaintained 4.1-1/amd64/ InRelease
Ign:78 https://updates.software-univention.de/4.1/maintained 4.1-2/all/ InRelease
Ign:80 https://updates.software-univention.de/4.1/maintained 4.1-2/amd64/ InRelease
Ign:81 https://updates.software-univention.de/4.1/unmaintained 4.1-2/all/ InRelease
Ign:82 https://updates.software-univention.de/4.1/unmaintained 4.1-2/amd64/ InRelease
Ign:84 https://updates.software-univention.de/4.1/maintained 4.1-3/all/ InRelease
Ign:85 https://updates.software-univention.de/4.1/maintained 4.1-3/amd64/ InRelease
Ign:86 https://updates.software-univention.de/4.1/unmaintained 4.1-3/all/ InRelease
Ign:87 https://updates.software-univention.de/4.1/unmaintained 4.1-3/amd64/ InRelease
Ign:89 https://updates.software-univention.de/4.1/maintained 4.1-4/all/ InRelease
Ign:90 https://updates.software-univention.de/4.1/maintained 4.1-4/amd64/ InRelease
Ign:91 https://updates.software-univention.de/4.1/unmaintained 4.1-4/all/ InRelease
Ign:93 https://updates.software-univention.de/4.1/unmaintained 4.1-4/amd64/ InRelease
Ign:94 https://updates.software-univention.de/4.1/maintained 4.1-5/all/ InRelease
Ign:95 https://updates.software-univention.de/4.1/maintained 4.1-5/amd64/ InRelease
Ign:96 https://updates.software-univention.de/4.1/unmaintained 4.1-5/all/ InRelease
Ign:98 https://updates.software-univention.de/4.1/unmaintained 4.1-5/amd64/ InRelease
Ign:99 https://updates.software-univention.de/4.2/maintained 4.2-0/all/ InRelease
Ign:100 https://updates.software-univention.de/4.2/maintained 4.2-0/amd64/ InRelease
Ign:102 https://updates.software-univention.de/4.2/unmaintained 4.2-0/all/ InRelease
Ign:103 https://updates.software-univention.de/4.2/unmaintained 4.2-0/amd64/ InRelease
Ign:104 https://updates.software-univention.de/4.2/maintained 4.2-1/all/ InRelease
Ign:106 https://updates.software-univention.de/4.2/maintained 4.2-1/amd64/ InRelease
Ign:107 https://updates.software-univention.de/4.2/unmaintained 4.2-1/all/ InRelease
Ign:108 https://updates.software-univention.de/4.2/unmaintained 4.2-1/amd64/ InRelease
Ign:110 https://updates.software-univention.de/4.2/maintained 4.2-2/all/ InRelease
Ign:111 https://updates.software-univention.de/4.2/maintained 4.2-2/amd64/ InRelease
Ign:112 https://updates.software-univention.de/4.2/unmaintained 4.2-2/all/ InRelease
Ign:113 https://updates.software-univention.de/4.2/unmaintained 4.2-2/amd64/ InRelease
Ign:115 https://updates.software-univention.de/4.2/maintained 4.2-3/all/ InRelease
Ign:116 https://updates.software-univention.de/4.2/maintained 4.2-3/amd64/ InRelease
Ign:117 https://updates.software-univention.de/4.2/unmaintained 4.2-3/all/ InRelease
Ign:119 https://updates.software-univention.de/4.2/unmaintained 4.2-3/amd64/ InRelease
Ign:120 https://updates.software-univention.de/4.2/maintained 4.2-4/all/ InRelease
Ign:121 https://updates.software-univention.de/4.2/maintained 4.2-4/amd64/ InRelease
Ign:122 https://updates.software-univention.de/4.2/unmaintained 4.2-4/all/ InRelease
Ign:123 https://updates.software-univention.de/4.2/unmaintained 4.2-4/amd64/ InRelease
Ign:124 https://updates.software-univention.de/4.2/maintained 4.2-5/all/ InRelease
Ign:125 https://updates.software-univention.de/4.2/maintained 4.2-5/amd64/ InRelease
Ign:126 https://updates.software-univention.de/4.2/unmaintained 4.2-5/all/ InRelease
Ign:127 https://updates.software-univention.de/4.2/unmaintained 4.2-5/amd64/ InRelease
Ign:128 https://updates.software-univention.de/4.3/maintained 4.3-0/all/ InRelease
Ign:129 https://updates.software-univention.de/4.3/maintained 4.3-0/amd64/ InRelease
Ign:130 https://updates.software-univention.de/4.3/unmaintained 4.3-0/all/ InRelease
Ign:131 https://updates.software-univention.de/4.3/unmaintained 4.3-0/amd64/ InRelease
Ign:132 https://updates.software-univention.de/4.3/maintained 4.3-1/all/ InRelease
Ign:133 https://updates.software-univention.de/4.3/maintained 4.3-1/amd64/ InRelease
Ign:134 https://updates.software-univention.de/4.3/unmaintained 4.3-1/all/ InRelease
Ign:135 https://updates.software-univention.de/4.3/unmaintained 4.3-1/amd64/ InRelease
Ign:136 https://updates.software-univention.de/4.3/maintained 4.3-2/all/ InRelease
Ign:137 https://updates.software-univention.de/4.3/maintained 4.3-2/amd64/ InRelease
Ign:138 https://updates.software-univention.de/4.3/unmaintained 4.3-2/all/ InRelease
Ign:139 https://updates.software-univention.de/4.3/unmaintained 4.3-2/amd64/ InRelease
Ign:140 https://updates.software-univention.de/4.3/maintained 4.3-3/all/ InRelease
Ign:141 https://updates.software-univention.de/4.3/maintained 4.3-3/amd64/ InRelease
Ign:142 https://updates.software-univention.de/4.3/unmaintained 4.3-3/all/ InRelease
Ign:143 https://updates.software-univention.de/4.3/unmaintained 4.3-3/amd64/ InRelease
Ign:144 https://updates.software-univention.de/4.3/maintained 4.3-4/all/ InRelease
Ign:145 https://updates.software-univention.de/4.3/maintained 4.3-4/amd64/ InRelease
Ign:146 https://updates.software-univention.de/4.3/unmaintained 4.3-4/all/ InRelease
Ign:147 https://updates.software-univention.de/4.3/unmaintained 4.3-4/amd64/ InRelease
Ign:148 https://updates.software-univention.de/4.3/maintained 4.3-5/all/ InRelease
Ign:149 https://updates.software-univention.de/4.3/maintained 4.3-5/amd64/ InRelease
Ign:150 https://updates.software-univention.de/4.3/unmaintained 4.3-5/all/ InRelease
Ign:151 https://updates.software-univention.de/4.3/unmaintained 4.3-5/amd64/ InRelease
Ign:152 https://updates.software-univention.de/4.4/maintained 4.4-0/all/ InRelease
Ign:153 https://updates.software-univention.de/4.4/maintained 4.4-0/amd64/ InRelease
Ign:154 https://updates.software-univention.de/4.4/unmaintained 4.4-0/all/ InRelease
Ign:155 https://updates.software-univention.de/4.4/unmaintained 4.4-0/amd64/ InRelease
Ign:156 https://updates.software-univention.de/4.4/maintained 4.4-1/all/ InRelease
Ign:157 https://updates.software-univention.de/4.4/maintained 4.4-1/amd64/ InRelease
Ign:158 https://updates.software-univention.de/4.4/unmaintained 4.4-1/all/ InRelease
Ign:159 https://updates.software-univention.de/4.4/unmaintained 4.4-1/amd64/ InRelease
Ign:160 https://updates.software-univention.de/4.4/maintained 4.4-2/all/ InRelease
Ign:161 https://updates.software-univention.de/4.4/maintained 4.4-2/amd64/ InRelease
Ign:162 https://updates.software-univention.de/4.4/unmaintained 4.4-2/all/ InRelease
Ign:163 https://updates.software-univention.de/4.4/unmaintained 4.4-2/amd64/ InRelease
Ign:164 https://updates.software-univention.de/4.4/maintained 4.4-3/all/ InRelease
Ign:165 https://updates.software-univention.de/4.4/maintained 4.4-3/amd64/ InRelease
Ign:166 https://updates.software-univention.de/4.4/unmaintained 4.4-3/all/ InRelease
Ign:167 https://updates.software-univention.de/4.4/unmaintained 4.4-3/amd64/ InRelease
Ign:168 https://updates.software-univention.de/4.4/maintained 4.4-4/all/ InRelease
Ign:169 https://updates.software-univention.de/4.4/maintained 4.4-4/amd64/ InRelease
Ign:170 https://updates.software-univention.de/4.4/unmaintained 4.4-4/all/ InRelease
Ign:171 https://updates.software-univention.de/4.4/unmaintained 4.4-4/amd64/ InRelease
Ign:172 https://updates.software-univention.de/4.4/maintained 4.4-5/all/ InRelease
Ign:173 https://updates.software-univention.de/4.4/maintained 4.4-5/amd64/ InRelease
Ign:174 https://updates.software-univention.de/4.4/unmaintained 4.4-5/all/ InRelease
Ign:175 https://updates.software-univention.de/4.4/unmaintained 4.4-5/amd64/ InRelease
Ign:176 https://updates.software-univention.de/4.4/maintained 4.4-6/all/ InRelease
Ign:177 https://updates.software-univention.de/4.4/maintained 4.4-6/amd64/ InRelease
Ign:178 https://updates.software-univention.de/4.4/unmaintained 4.4-6/all/ InRelease
Ign:179 https://updates.software-univention.de/4.4/unmaintained 4.4-6/amd64/ InRelease
Ign:180 https://updates.software-univention.de/4.2/maintained/component 4.2-4-errata/all/ InRelease
Ign:181 https://updates.software-univention.de/4.2/maintained/component 4.2-4-errata/amd64/ InRelease
Hit:182 https://updates.software-univention.de/4.4/maintained 4.4-7/all/ Release
Hit:183 https://updates.software-univention.de/4.4/maintained 4.4-7/amd64/ Release
Hit:184 https://updates.software-univention.de/4.4/unmaintained 4.4-7/all/ Release
Hit:185 https://updates.software-univention.de/4.4/unmaintained 4.4-7/amd64/ Release
Hit:186 https://updates.software-univention.de/4.4/maintained/component 4.4-6-errata/all/ Release
Hit:188 https://updates.software-univention.de/4.4/maintained/component 4.4-6-errata/amd64/ Release
Hit:189 https://updates.software-univention.de/4.4/unmaintained/component 4.4-6-errata/all/ Release
Hit:190 https://updates.software-univention.de/4.0/maintained 4.0-0/all/ Release
Hit:191 https://updates.software-univention.de/4.0/maintained 4.0-0/amd64/ Release
Hit:193 https://updates.software-univention.de/4.0/unmaintained 4.0-0/all/ Release
Hit:194 https://updates.software-univention.de/4.0/unmaintained 4.0-0/amd64/ Release
Hit:195 https://updates.software-univention.de/4.0/maintained 4.0-1/all/ Release
Hit:196 https://updates.software-univention.de/4.0/maintained 4.0-1/amd64/ Release
Hit:198 https://updates.software-univention.de/4.0/unmaintained 4.0-1/all/ Release
Hit:199 https://updates.software-univention.de/4.0/unmaintained 4.0-1/amd64/ Release
Hit:200 https://updates.software-univention.de/4.0/maintained 4.0-2/all/ Release
Hit:201 https://updates.software-univention.de/4.0/maintained 4.0-2/amd64/ Release
Hit:203 https://updates.software-univention.de/4.0/unmaintained 4.0-2/all/ Release
Hit:204 https://updates.software-univention.de/4.0/unmaintained 4.0-2/amd64/ Release
Hit:205 https://updates.software-univention.de/4.0/maintained 4.0-3/all/ Release
Hit:207 https://updates.software-univention.de/4.0/maintained 4.0-3/amd64/ Release
Hit:208 https://updates.software-univention.de/4.0/unmaintained 4.0-3/all/ Release
Hit:209 https://updates.software-univention.de/4.0/unmaintained 4.0-3/amd64/ Release
Hit:210 https://updates.software-univention.de/4.0/maintained 4.0-4/all/ Release
Hit:212 https://updates.software-univention.de/4.0/maintained 4.0-4/amd64/ Release
Hit:213 https://updates.software-univention.de/4.0/unmaintained 4.0-4/all/ Release
Hit:214 https://updates.software-univention.de/4.0/unmaintained 4.0-4/amd64/ Release
Hit:216 https://updates.software-univention.de/4.0/maintained 4.0-5/all/ Release
Hit:217 https://updates.software-univention.de/4.0/maintained 4.0-5/amd64/ Release
Hit:218 https://updates.software-univention.de/4.0/unmaintained 4.0-5/all/ Release
Hit:220 https://updates.software-univention.de/4.1/maintained 4.1-0/all/ Release
Hit:221 https://updates.software-univention.de/4.1/maintained 4.1-0/amd64/ Release
Hit:222 https://updates.software-univention.de/4.1/unmaintained 4.1-0/all/ Release
Hit:223 https://updates.software-univention.de/4.1/unmaintained 4.1-0/amd64/ Release
Ign:225 https://download.kopano.io/supported/core:/final/Univention_4.3  InRelease
Hit:226 https://updates.software-univention.de/4.1/maintained 4.1-1/all/ Release
Hit:227 https://updates.software-univention.de/4.1/maintained 4.1-1/amd64/ Release
Hit:228 https://updates.software-univention.de/4.1/unmaintained 4.1-1/all/ Release
Hit:230 https://updates.software-univention.de/4.1/unmaintained 4.1-1/amd64/ Release
Hit:231 https://updates.software-univention.de/4.1/maintained 4.1-2/all/ Release
Hit:232 https://updates.software-univention.de/4.1/maintained 4.1-2/amd64/ Release
Hit:233 https://updates.software-univention.de/4.1/unmaintained 4.1-2/all/ Release
Hit:235 https://updates.software-univention.de/4.1/unmaintained 4.1-2/amd64/ Release
Hit:236 https://updates.software-univention.de/4.1/maintained 4.1-3/all/ Release
Hit:237 https://updates.software-univention.de/4.1/maintained 4.1-3/amd64/ Release
Hit:239 https://updates.software-univention.de/4.1/unmaintained 4.1-3/all/ Release
Hit:240 https://updates.software-univention.de/4.1/unmaintained 4.1-3/amd64/ Release
Hit:241 https://updates.software-univention.de/4.1/maintained 4.1-4/all/ Release
Hit:242 https://updates.software-univention.de/4.1/maintained 4.1-4/amd64/ Release
Hit:244 https://updates.software-univention.de/4.1/unmaintained 4.1-4/all/ Release
Hit:245 https://updates.software-univention.de/4.1/unmaintained 4.1-4/amd64/ Release
Hit:246 https://updates.software-univention.de/4.1/maintained 4.1-5/all/ Release
Hit:247 https://updates.software-univention.de/4.1/maintained 4.1-5/amd64/ Release
Hit:249 https://updates.software-univention.de/4.1/unmaintained 4.1-5/all/ Release
Hit:250 https://updates.software-univention.de/4.1/unmaintained 4.1-5/amd64/ Release
Hit:251 https://updates.software-univention.de/4.2/maintained 4.2-0/all/ Release
Hit:253 https://updates.software-univention.de/4.2/maintained 4.2-0/amd64/ Release
Hit:254 https://updates.software-univention.de/4.2/unmaintained 4.2-0/all/ Release
Hit:255 https://updates.software-univention.de/4.2/unmaintained 4.2-0/amd64/ Release
Hit:256 https://updates.software-univention.de/4.2/maintained 4.2-1/all/ Release
Hit:258 https://updates.software-univention.de/4.2/maintained 4.2-1/amd64/ Release
Hit:259 https://updates.software-univention.de/4.2/unmaintained 4.2-1/all/ Release
Hit:260 https://updates.software-univention.de/4.2/unmaintained 4.2-1/amd64/ Release
Hit:262 https://updates.software-univention.de/4.2/maintained 4.2-2/all/ Release
Hit:263 https://updates.software-univention.de/4.2/maintained 4.2-2/amd64/ Release
Hit:264 https://updates.software-univention.de/4.2/unmaintained 4.2-2/all/ Release
Hit:265 https://updates.software-univention.de/4.2/unmaintained 4.2-2/amd64/ Release
Hit:267 https://updates.software-univention.de/4.2/maintained 4.2-3/all/ Release
Hit:268 https://updates.software-univention.de/4.2/maintained 4.2-3/amd64/ Release
Hit:269 https://updates.software-univention.de/4.2/unmaintained 4.2-3/all/ Release
Hit:271 https://updates.software-univention.de/4.2/unmaintained 4.2-3/amd64/ Release
Hit:280 https://updates.software-univention.de/4.2/maintained 4.2-4/all/ Release
Hit:281 https://updates.software-univention.de/4.2/maintained 4.2-4/amd64/ Release
Hit:282 https://updates.software-univention.de/4.2/unmaintained 4.2-4/all/ Release
Hit:283 https://updates.software-univention.de/4.2/unmaintained 4.2-4/amd64/ Release
Hit:285 https://updates.software-univention.de/4.2/maintained 4.2-5/all/ Release
Hit:286 https://updates.software-univention.de/4.2/maintained 4.2-5/amd64/ Release
Hit:287 https://updates.software-univention.de/4.2/unmaintained 4.2-5/all/ Release
Hit:289 https://updates.software-univention.de/4.2/unmaintained 4.2-5/amd64/ Release
Hit:290 https://updates.software-univention.de/4.3/maintained 4.3-0/all/ Release
Hit:291 https://updates.software-univention.de/4.3/maintained 4.3-0/amd64/ Release
Hit:292 https://updates.software-univention.de/4.3/unmaintained 4.3-0/all/ Release
Hit:294 https://updates.software-univention.de/4.3/unmaintained 4.3-0/amd64/ Release
Hit:295 https://updates.software-univention.de/4.3/maintained 4.3-1/all/ Release
Hit:296 https://updates.software-univention.de/4.3/maintained 4.3-1/amd64/ Release
Hit:298 https://updates.software-univention.de/4.3/unmaintained 4.3-1/all/ Release
Hit:299 https://updates.software-univention.de/4.3/unmaintained 4.3-1/amd64/ Release
Hit:300 https://updates.software-univention.de/4.3/maintained 4.3-2/all/ Release
Hit:301 https://updates.software-univention.de/4.3/maintained 4.3-2/amd64/ Release
Hit:303 https://updates.software-univention.de/4.3/unmaintained 4.3-2/all/ Release
Hit:304 https://updates.software-univention.de/4.3/unmaintained 4.3-2/amd64/ Release
Hit:305 https://updates.software-univention.de/4.3/maintained 4.3-3/all/ Release
Hit:306 https://updates.software-univention.de/4.3/maintained 4.3-3/amd64/ Release
Hit:308 https://updates.software-univention.de/4.3/unmaintained 4.3-3/all/ Release
Hit:309 https://updates.software-univention.de/4.3/unmaintained 4.3-3/amd64/ Release
Hit:310 https://updates.software-univention.de/4.3/maintained 4.3-4/all/ Release
Hit:312 https://updates.software-univention.de/4.3/maintained 4.3-4/amd64/ Release
Hit:313 https://updates.software-univention.de/4.3/unmaintained 4.3-4/all/ Release
Hit:314 https://updates.software-univention.de/4.3/unmaintained 4.3-4/amd64/ Release
Hit:315 https://updates.software-univention.de/4.3/maintained 4.3-5/all/ Release
Hit:317 https://updates.software-univention.de/4.3/maintained 4.3-5/amd64/ Release
Hit:318 https://updates.software-univention.de/4.3/unmaintained 4.3-5/all/ Release
Hit:319 https://updates.software-univention.de/4.3/unmaintained 4.3-5/amd64/ Release
Hit:320 https://updates.software-univention.de/4.4/maintained 4.4-0/all/ Release
Hit:322 https://updates.software-univention.de/4.4/maintained 4.4-0/amd64/ Release
Hit:323 https://updates.software-univention.de/4.4/unmaintained 4.4-0/all/ Release
Hit:324 https://updates.software-univention.de/4.4/unmaintained 4.4-0/amd64/ Release
Hit:326 https://updates.software-univention.de/4.4/maintained 4.4-1/all/ Release
Hit:327 https://updates.software-univention.de/4.4/maintained 4.4-1/amd64/ Release
Hit:328 https://updates.software-univention.de/4.4/unmaintained 4.4-1/all/ Release
Hit:329 https://updates.software-univention.de/4.4/unmaintained 4.4-1/amd64/ Release
Hit:331 https://updates.software-univention.de/4.4/maintained 4.4-2/all/ Release
Hit:332 https://updates.software-univention.de/4.4/maintained 4.4-2/amd64/ Release
Hit:333 https://updates.software-univention.de/4.4/unmaintained 4.4-2/all/ Release
Hit:335 https://updates.software-univention.de/4.4/unmaintained 4.4-2/amd64/ Release
Hit:336 https://updates.software-univention.de/4.4/maintained 4.4-3/all/ Release
Hit:337 https://updates.software-univention.de/4.4/maintained 4.4-3/amd64/ Release
Hit:338 https://updates.software-univention.de/4.4/unmaintained 4.4-3/all/ Release
Hit:340 https://updates.software-univention.de/4.4/unmaintained 4.4-3/amd64/ Release
Hit:341 https://updates.software-univention.de/4.4/maintained 4.4-4/all/ Release
Hit:342 https://updates.software-univention.de/4.4/maintained 4.4-4/amd64/ Release
Hit:344 https://updates.software-univention.de/4.4/unmaintained 4.4-4/all/ Release
Hit:345 https://updates.software-univention.de/4.4/unmaintained 4.4-4/amd64/ Release
Hit:346 https://updates.software-univention.de/4.4/maintained 4.4-5/all/ Release
Hit:347 https://updates.software-univention.de/4.4/maintained 4.4-5/amd64/ Release
Hit:349 https://updates.software-univention.de/4.4/unmaintained 4.4-5/all/ Release
Hit:350 https://updates.software-univention.de/4.4/unmaintained 4.4-5/amd64/ Release
Hit:351 https://updates.software-univention.de/4.4/maintained 4.4-6/all/ Release
Hit:352 https://updates.software-univention.de/4.4/maintained 4.4-6/amd64/ Release
Hit:354 https://updates.software-univention.de/4.4/unmaintained 4.4-6/all/ Release
Hit:355 https://updates.software-univention.de/4.4/unmaintained 4.4-6/amd64/ Release
Hit:356 https://updates.software-univention.de/4.2/maintained/component 4.2-4-errata/all/ Release
Hit:358 https://updates.software-univention.de/4.2/maintained/component 4.2-4-errata/amd64/ Release
Ign:379 https://download.kopano.io/supported/archiver:/final/Univention_4.3  InRelease
Ign:437 https://download.kopano.io/supported/webapp:/final/Univention_4.3  InRelease
Ign:449 https://download.kopano.io/supported/files:/final/Univention_4.3  InRelease
Ign:450 https://download.kopano.io/supported/mdm:/final/Univention_4.3  InRelease
Ign:451 https://download.kopano.io/supported/smime:/final/Univention_4.3  InRelease
Err:452 https://download.kopano.io/supported/core:/final/Univention_4.3  Release
  401  Unauthorized
Err:453 https://download.kopano.io/supported/archiver:/final/Univention_4.3  Release
  401  Unauthorized
Err:454 https://download.kopano.io/supported/webapp:/final/Univention_4.3  Release
  401  Unauthorized
Err:455 https://download.kopano.io/supported/files:/final/Univention_4.3  Release
  401  Unauthorized
Err:456 https://download.kopano.io/supported/mdm:/final/Univention_4.3  Release
  401  Unauthorized
Err:457 https://download.kopano.io/supported/smime:/final/Univention_4.3  Release
  401  Unauthorized
Reading package lists...
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:5 and /etc/apt/sources.list.d/20_ucs-online-component.list:11
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:6 and /etc/apt/sources.list.d/20_ucs-online-component.list:12
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:7 and /etc/apt/sources.list.d/20_ucs-online-component.list:15
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:8 and /etc/apt/sources.list.d/20_ucs-online-component.list:16
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:9 and /etc/apt/sources.list.d/20_ucs-online-component.list:17
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:10 and /etc/apt/sources.list.d/20_ucs-online-component.list:18
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:14 and /etc/apt/sources.list.d/20_ucs-online-component.list:28
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:15 and /etc/apt/sources.list.d/20_ucs-online-component.list:29
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:11 and /etc/apt/sources.list.d/20_ucs-online-component.list:25
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:12 and /etc/apt/sources.list.d/20_ucs-online-component.list:26
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list.d/00_ucs_temporary_installation.list:13 and /etc/apt/sources.list.d/20_ucs-online-component.list:27
E: The repository 'https://download.kopano.io/supported/core:/final/Univention_4.3  Release' does not have a Release file.
E: The repository 'https://download.kopano.io/supported/archiver:/final/Univention_4.3  Release' does not have a Release file.
E: The repository 'https://download.kopano.io/supported/webapp:/final/Univention_4.3  Release' does not have a Release file.
E: The repository 'https://download.kopano.io/supported/files:/final/Univention_4.3  Release' does not have a Release file.
E: The repository 'https://download.kopano.io/supported/mdm:/final/Univention_4.3  Release' does not have a Release file.
E: The repository 'https://download.kopano.io/supported/smime:/final/Univention_4.3  Release' does not have a Release file.
Error: Failed to execute "apt-get update"
My question is how can I fix this issue? It’s my DC, so I can’t update my second server asw ell!
And this is what I found in the /etc/apt/sources.list.d/00_ucs_temporary_installation.list
deb https://updates.software-univention.de/4.4/maintained/ 4.4-7/all/
deb https://updates.software-univention.de/4.4/maintained/ 4.4-7/amd64/
deb https://updates.software-univention.de/4.4/unmaintained/ 4.4-7/all/
deb https://updates.software-univention.de/4.4/unmaintained/ 4.4-7/amd64/
deb https://appcenter.software-univention.de/univention-repository/4.4/maintained/component/ kopano-core_20191114105932/all/
deb https://appcenter.software-univention.de/univention-repository/4.4/maintained/component/ kopano-core_20191114105932/amd64/
deb https://appcenter.software-univention.de/univention-repository/4.4/maintained/component/ kopano-webapp_20200618121103/all/
deb https://appcenter.software-univention.de/univention-repository/4.4/maintained/component/ kopano-webapp_20200618121103/amd64/
deb https://appcenter.software-univention.de/univention-repository/4.4/maintained/component/ ucc_20160811170611/all/
deb https://appcenter.software-univention.de/univention-repository/4.4/maintained/component/ ucc_20160811170611/amd64/
deb https://updates.software-univention.de/4.4/maintained/component/ 4.4-6-errata/all/
deb https://updates.software-univention.de/4.4/maintained/component/ 4.4-6-errata/amd64/
deb https://updates.software-univention.de/4.4/unmaintained/component/ 4.4-6-errata/all/
deb https://appcenter.software-univention.de/univention-repository/4.4/maintained/component/ z-push-kopano_20190426122615/all/
deb https://appcenter.software-univention.de/univention-repository/4.4/maintained/component/ z-push-kopano_20190426122615/amd64/
Hi, i think, your Kopano license has expired; therefore you don’t have access to Kopano’s own repositories anymore. Get a new license or deactivate Kopano’s own repositories.
I never buy, a Kopano license, and I was not aware that this was enabled.
I remove these checkbox, and tried the update again, but it failed again.
Do one off you know, how long it takes when I remove the checkbox, before the system is aware off it?
Or do one of you know how I can solve it on another way?
