I tried to install UCS many times, but results the same…
Can’t add to domain in installation… always looking for first installed USC server (was deleted) and then … re-configuring or finish. After finish can’t connect to UCS with local or domain credentials…The way to make USC server domain member is install server and choose new UCS domain same like in your organisation, and the use Active directory connection.
When USC added to ad, there is no all users. My account is simple user in domain, I can see that in Microsoft AD, but not in UCS lists.
I’m trying to use cloud service with ad. The problems everywhere: ownCloud, NextCloud problems to join AD. In UCS in domain scripts the state - pending - no change. OX drive looks like working, but can’t connect from application… SSL/TLS problems, good idea to write that need to import root sertificate from ucs server to local workstation, it solve the problem…
When server shutting down always stuck on Reloading bind9 Domain Name server (DNS)
People, who knows how to win in this battle?
