Hi everbody,
I am currently at new newst public availabe UCS and openproject version. It could be that - with some update - my openproject sopped working. Sadly I noticed that a little bit too late.
When I click on Openproject in the UCS website then the only thing I get is an URL was not found error site… :-/
Has anybody an idea?
Thank You!
please send output from:
univention-app info
ps auwx |grep openproject
grep openproj /var/log/univention/system-stats.log |tail -n 20
ucr dump |grep openproject
Thanks
Sure. Thank you very much for your help!
root@ucs:~# univention-app info
UCS: 5.0-1 errata203
Installed: letsencrypt=2.0.0-2 radius=5.0 4.4/openid-connect-provider=2.2-konnect-0.33.11-2 4.4/owncloud=10.7.0
Upgradable:
root@ucs:~# ps auwx |grep openproject
systemm+ 5957 0.0 2.0 591840 332140 ? Sl Feb03 1:13 /opt/openproject/vendor/bundle/ruby/2.7.0/bin/rake jobs:work
postgres 6560 0.0 0.1 207848 21244 ? Ss Feb03 0:26 postgres: openproject openproject 172.17.0.4(54634) idle
root 59515 0.0 0.0 6552 828 pts/0 S+ 20:53 0:00 grep openproject
root@ucs:~# grep openproj /var/log/univention/system-stats.log |tail -n 20
systemm+ 5957 0.0 2.0 591840 332140 ? Sl Feb03 1:02 | | \_ /opt/openproject/vendor/bundle/ruby/2.7.0/bin/rake jobs:work
postgres 6560 0.0 0.1 207848 21116 ? Ss Feb03 0:21 \_ postgres: openproject openproject 172.17.0.4(54634) idle
systemm+ 5957 0.0 2.0 591840 332140 ? Sl Feb03 1:04 | | \_ /opt/openproject/vendor/bundle/ruby/2.7.0/bin/rake jobs:work
postgres 6560 0.0 0.1 207848 21180 ? Ss Feb03 0:22 \_ postgres: openproject openproject 172.17.0.4(54634) idle
systemm+ 5957 0.0 2.0 591840 332140 ? Sl Feb03 1:05 | | \_ /opt/openproject/vendor/bundle/ruby/2.7.0/bin/rake jobs:work
systemm+ 5957 0.0 2.0 591840 332140 ? Sl Feb03 1:06 | | \_ /opt/openproject/vendor/bundle/ruby/2.7.0/bin/rake jobs:work
postgres 6560 0.0 0.1 207848 21180 ? Ss Feb03 0:23 \_ postgres: openproject openproject 172.17.0.4(54634) idle
systemm+ 5957 0.0 2.0 591840 332140 ? Sl Feb03 1:07 | | \_ /opt/openproject/vendor/bundle/ruby/2.7.0/bin/rake jobs:work
postgres 6560 0.0 0.1 207848 21244 ? Ss Feb03 0:23 \_ postgres: openproject openproject 172.17.0.4(54634) idle
systemm+ 5957 0.0 2.0 591840 332140 ? Sl Feb03 1:08 | | \_ /opt/openproject/vendor/bundle/ruby/2.7.0/bin/rake jobs:work
postgres 6560 0.0 0.1 207848 21244 ? Ss Feb03 0:24 \_ postgres: openproject openproject 172.17.0.4(54634) idle
systemm+ 5957 0.0 2.0 591840 332140 ? Sl Feb03 1:09 | | \_ /opt/openproject/vendor/bundle/ruby/2.7.0/bin/rake jobs:work
systemm+ 5957 0.0 2.0 591840 332140 ? Sl Feb03 1:10 | | \_ /opt/openproject/vendor/bundle/ruby/2.7.0/bin/rake jobs:work
postgres 6560 0.0 0.1 207848 21244 ? Ss Feb03 0:25 \_ postgres: openproject openproject 172.17.0.4(54634) idle
systemm+ 5957 0.0 2.0 591840 332140 ? Sl Feb03 1:11 | | \_ /opt/openproject/vendor/bundle/ruby/2.7.0/bin/rake jobs:work
systemm+ 5957 0.0 2.0 591840 332140 ? Sl Feb03 1:12 | | \_ /opt/openproject/vendor/bundle/ruby/2.7.0/bin/rake jobs:work
postgres 6560 0.0 0.1 207848 21244 ? Ss Feb03 0:26 \_ postgres: openproject openproject 172.17.0.4(54634) idle
root@ucs:~# ucr dump |grep openproject
appcenter/apps/openproject/container: df3d47d7acfabb5b487dd1514dd0c57b352632a0ffc358b0b2f5fb991316a226
appcenter/apps/openproject/hostdn: cn=openp-09389662,cn=memberserver,cn=computers,dc=smart-networks-braunschweig,dc=de
appcenter/apps/openproject/image: docker.software-univention.de/ucs-appbox-amd64:4.3-3
appcenter/apps/openproject/ip: 172.17.0.4
appcenter/apps/openproject/ports/80: 40002
appcenter/apps/openproject/status: installed
appcenter/apps/openproject/ucs: 4.3
appcenter/apps/openproject/version: 11.3.2
openproject/autostart: yes
ucs/web/overview/entries/service/openproject/description/de: Open Source Projekt-Management Software und Team Kollaboration
ucs/web/overview/entries/service/openproject/description: Open Source Project Management. Powerful. Easy-to-use. Enterprise class.
ucs/web/overview/entries/service/openproject/icon: /univention/js/dijit/themes/umc/icons/scalable/apps-openproject_20210705143001.svg
ucs/web/overview/entries/service/openproject/label/de: OpenProject
ucs/web/overview/entries/service/openproject/label: OpenProject
ucs/web/overview/entries/service/openproject/link-target: newwindow
ucs/web/overview/entries/service/openproject/link: /openproject/
ucs/web/overview/entries/service/openproject/port_http: 80
ucs/web/overview/entries/service/openproject/port_https: 443
Hello
Which was your first Version you´ve installed and how did you upgrade? Interface or CLI? Please send also:
zgrep -C230 -w -i TypeError /var/log/univention/appcenter.log*
Hi
There is no output with the command
I upgraded the easy way via GUI.
Thanks @vanhaakonnen, what was your eldest UCS Version? Is this an upgrade from 4.4-* ?
Yes. It was upgraded from the 4 train
I’ve been looking into this error would you mind to post me your:
univention-app info
Thanks ahead.
Hello @vanhaakonnen please check if you can fix this with this article or please wait till we publish an errata update and check then.
Helle @vanhaakonnen the errata has been published.
I hope it helps
I have to bring this up again…
The errata doesn´t help. where can i find the data from the openproject container? If it will not funcion I will check the files manually. Are there any automatically created backups where i can look for the project files?
