After upgrading successfully from 4.4-0 to 5.0-* apps are missing, seam to be newly installed or URL missing and other strange behaviors.
Environment
After Upgrade from 4.4-* to 5.0-*
UCS
UCS@School
Please make sure you have installed the errata 224
Investigation
Your:
docker ps `my-missing-app`
results may looks like **:
docker.software-univention.de/my-missing-app 21.0.7-0 1c36271a798a 7 weeks ago 1.18GB
docker.software-univention.de/my-missing-app 21.0.5-0 1b9c0aa1ff67 2 months ago 1.18GB
In:
/var/log/univention/listener_modules/.log
you might find:
2022-02-02 10:01:48 CRITICAL App not found
Root Cause
When univention-app update is running, the app center cache is invalidated, new metafiles are downloaded and extracted. The first usage of appcenter python library functions finds no cache and rebuilds it. See bug for further details
** See also:
