I want to enforce the use of OTP for special clients, even if the user is already authenticated at Keycloak.
Answer:
You can create an additional authentication flow in keycloak to always require OTP. For clients where OTP should be enforced, you can set this flow as the default flow.
- Open the Keycloak administration console and select the
ucsrealm - Go to
Authentication→ you will see some build-in flows. The standard flow for browser authentication is calledbrowser. See also How to change the defaut authentication flow in keycloak - Create a new flow by clicking
Create flow. Give it a name like2fa-browserorforceOTP. - By default the new flow is empty, first you need to create a
sub-flowcalledmain(the name is freely selectable) . - Now we add the actual authentication steps to the
mainsub-flow.- Click the
+symbol of themainflow andAdd step, selectCookieand clickAdd - Repeat and add
Kerberos(if you are using kerberos for authentication) - Repeat and add
Identity Provider Redirector - We need another sub-flow in the main sub-flow for the username/password authentication
- Click the
+symbol of themainflow andAdd sub-flow, the name is freely selectable, we usemain sub-flow - Click the
+symbol of themain sub-flowsub-flow andAdd stepsand addUsername Password Form
- Click the
- Click the
- Not in the
mainsub flow, but in the top level of our flow we add theOTPauthentication step. Click the blueAdd stepbutton and addOTP form. - Nearly done, now we have to configure the
Requirementin our authentication flow.
main→Required-
Cookie→Alternative -
Kerberos→Alternative -
Identity Provider Redirector→Alternative -
main sub-flow→Alternative
OTP Form→Required
In the end the flow should look like this,
or in the diagram view:
What this means is that authentication is successful …
IF ( Cookie OR Kerberos OR Identity Provider Redirector OR Username Password Form ) AND OTP Form
You can now link this new flow to clients, for which you always want OTP authentication step.
- Go to
clientsin theManagemenu on the left - Open your client and navigate to the tab
Advanced - In
Authentication flow overridesyou can select your new flow and save
