Problems with Freeradius auth after upgrading to 5.2.0
I recently (yesterday) upgraded from UCS 5.0.9 to 5.2.0 and since then freeradius seems to have some problem.
When freeradius is started via systemd (or the WebUI) and I try to authenticate a wireless device, I get the following error in the radius.log:
*Sun Feb 23 17:24:53 2025 : ERROR: (33) mschap: ERROR: Program returned code (1) and output ''*
*Sun Feb 23 17:24:53 2025 : Auth: (33)   Login incorrect (mschap: Program returned code (1) and output ''): [username/<via Auth-Type = eap>] (from client AP_name port 0 via TLS tunnel)*
*Sun Feb 23 17:24:53 2025 : Auth: (34) Login incorrect (eap_peap: The users session was previously rejected: returning reject (again.)): [username/<via Auth-Type = eap>] (from client AP_name port 1 cli 80-86-D9-4B-F8-16)*
(username and AP_name are vars for the obfuscated original values)
When I stop freeradius (via systemd) and start it manually by freeradius -f,
everything works like a charm and all my clients are authenticated.
When freeradius is started (doesn’t matter which way), I get the following output:
ber_get_next failed, errno=11.
When starting with systemd, the output of systemctl status freeradius.service looks like:
â—Ź freeradius.service - FreeRADIUS multi-protocol policy server
     Loaded: loaded (/lib/systemd/system/freeradius.service; enabled; preset: enabled)
     Active: active (running) since Sun 2025-02-23 17:33:50 CET; 5min ago
       Docs: man:radiusd(8)
             man:radiusd.conf(5)
             http://wiki.freeradius.org/
             http://networkradius.com/doc/
    Process: 630277 ExecStartPre=/usr/sbin/freeradius $FREERADIUS_OPTIONS -Cx -lstdout (code=exited, status=0/SUCCESS)
   Main PID: 630278 (freeradius)
     Status: "Processing requests"
      Tasks: 6 (limit: 9432)
     Memory: 89.2M (limit: 2.0G)
        CPU: 1.217s
     CGroup: /system.slice/freeradius.service
             └─630278 /usr/sbin/freeradius -f
Feb 23 17:33:50 hostname freeradius[630277]: Compiling Post-Auth-Type REJECT for attr Post-Auth-Type
Feb 23 17:33:50 hostname freeradius[630277]: Compiling Autz-Type Status-Server for attr Autz-Type
Feb 23 17:33:50 hostname freeradius[630277]: radiusd: #### Skipping IP addresses and Ports ####
Feb 23 17:33:50 hostname freeradius[630277]: Configuration appears to be OK
Feb 23 17:33:50 hostname freeradius[630278]: ber_get_next failed, errno=11.
Feb 23 17:33:50 hostname systemd[1]: Started freeradius.service - FreeRADIUS multi-protocol policy server.
As a workaround (in order to keep my users connected) I start freeradius manually by issuing: freeradius -f &
This way everything seems to work.
The problem appeared after the upgrade to 5.2.0. All packages are up2date.
Maybe someone got similar problems and has a hint for me.
Thanks in advance.
Thanks for your solution with the start mode of freeradius.
I can confirm the same behaviour here, connecting isn’t possible, but when freeradius is started manually from the CLI freeradius -f & it works.
Error log:
Mon Feb 10 08:35:35 2025 : ERROR: (1664) mschap: ERROR: Program returned code (1) and output ''
Mon Feb 10 08:35:35 2025 : Auth: (1664)   Login incorrect (mschap: Program returned code (1) and output ''): [USERNAME/<via Auth-Type = eap>] (from client zar2 port 0 via TLS tunnel)
Mon Feb 10 08:35:35 2025 : Auth: (1665) Login incorrect (eap_peap: The users session was previously rejected: returning reject (again.)): [USERNAME/<via Auth-Type = eap>] (from client zar2 port 406115 cli 2c-33-58-4e-12-95)
Hallo!
Wir haben das selbe Problem, es scheint an einem Schutzmechnismus von der systemd Unit-File zu liegen. Ich bin jetzt leider nicht dazugekommen, herauszubekommen, welcher oder warum - aber hier unser Workaround:
  • systemctl edit freeradius
### Anything between here and the comment below will become the new contents of the file"
[Service]
NoNewPrivileges=false
PrivateTmp=false
ProtectControlGroups=false
ProtectKernelModules=false
ProtectKernelTunables=false
SystemCallArchitectures=
ReadOnlyDirectories=
ReadWriteDirectories=
AmbientCapabilities=
MemoryLimit=infinity
### Lines below this comment will be discarded
  • systemctl stop freeradius.service && systemctl start freeradius
Das ganze sollte natĂĽrlich wieder entfernt werden, sobald das Problem richtig von Univention addressiert wurde - aber aktuell funktioniert es zumindest fĂĽr uns.
LG
Thank you for your hint.
I’ve tested a bit with the different options and values and came to the conclusion, that already
AmbientCapabilities=CAP_DAC_OVERRIDE
solves the problem. So the rest of the options could be left with default settings.
So it could be a permission problem when starting freeradius via systemd.
During various service-restarts I noticed the following messages:
Mär 17 12:08:51 hostname freeradius[2606397]: Configuration appears to be OK
Mär 17 12:08:51 hostname freeradius[2606398]: ber_get_next failed, errno=11.
Mär 17 12:08:51 hostname systemd[1]: Started freeradius.service - FreeRADIUS multi-protocol policy server.
and
Unit uses MemoryLimit=; please use MemoryMax= instead. Support for MemoryLimit= will be removed soon.
The first one showed up even if freeradius was started manually. The seconed one is more of an information about an upcoming change.
So both of them shouldn’t have to do with the problem itself.
Könnte es vielleicht sein, dass dem User freerad nicht erlaubt ist anfragen zu stellen?
Sonst wĂĽrde ja die Nutzung im Debug-Modus ja auch nicht funktionieren!
Habe das selbe Problem nach dem Update auf die neueste Version.
LG
Der Dienst läuft über systemd mit dem User freerad.
:~# ps axu | grep radius
freerad   520400  0.0  1.4 524860 115028 ?       Ssl  05:55   0:00 /usr/sbin/freeradius -f
Da es mit der oben beschriebenen Änderung
mittles systemctl edit freeradius funktioniert, scheint es sich um ein Berechtigungsproblem (Zugriff auf bestimmte Dateien) zu handeln.
Welche Dateien das genau sind könnte man evtl. mittels aktivem auditd versuchen zu ermitteln.
Da fĂĽr mich der beschriebene Workaround funktioniert, habe ich vorerst nicht weiter geforscht. Ich hoffe erstmal weiterhin auf einen Fix seitens UCS :crossed_fingers:
I just experienced this problem after updating. For me in the /etc/freeradius/3.0/ directory some files, directories, symlinks had had their permissions updated to root:root instead of the freeradius user and group which explains why running freeradius -X works as root but not as the freeradius service/user.
I CD’d to that directory and just ran chown freerad:freerad on each file and directory that was set up with root as owner or group and then restarted freeradius and that solved my problem.
Same issue here :frowning_face:
Changing freeradius.service with
fixed the issue.
I have just updated to UCS version is 5.2-1 errata107
And can indeed confirm this breaks radius.
Your workarround works perfectly, thanks for suggesting that !
freeradius -f &
All the best from Australia
A change to the service is not normally necessary. I checked the file permissions. One file had incorrect permissions. After correcting this, radius worked normally again.
-rw------- 1 root nogroup 537 26. Dez 2023  /etc/freeradius/3.0/ldap-groups-attrs.conf
chgrp freerad /etc/freeradius/3.0/ldap-groups-attrs.conf
chmod 640 /etc/freeradius/3.0/ldap-groups-attrs.conf
systemctl start freeradius.service
I don’t have this file /etc/freeradius/3.0/ldap-groups-attrs.conf and therefore I can’t confirm that this solves the problem too. But for sure it’s a permission problem (AmbientCapabilities=CAP_DAC_OVERRIDE should allow ignoring the permissions - for this reason it works if set, even if the permissions are not set correctly).
Could anyone show up, what the permissions for the files in the folder
/etc/freeradius/3.0/ should be?
My folder looks like this:
:~# ls -l /etc/freeradius/3.0/
insgesamt 208
drwxr-xr-x  2 freerad freerad  4096 22. Feb 17:45 certs
-rw-r-----  1 freerad freerad  8010 23. Feb 16:52 clients.conf
-rw-r-----  1 freerad freerad  8323 19. Aug 2023  clients.conf.dpkg-dist
-rw-r--r--  1 root    root     1408 27. Feb 2019  clients.conf.example
-rw-------  1 freerad root      361 22. Feb 18:01 clients.univention.conf
-rw-r-----  1 freerad freerad  1420 19. Aug 2023  dictionary
-rw-r-----  1 freerad freerad  2661 27. Nov 2017  experimental.conf
lrwxrwxrwx  1 root    root       28 19. Aug 2023  hints -> mods-config/preprocess/hints
lrwxrwxrwx  1 root    root       33 19. Aug 2023  huntgroups -> mods-config/preprocess/huntgroups
drwxr-xr-x  2 freerad freerad  4096 25. Mai 05:55 mods-available
drwxr-xr-x 11 freerad freerad  4096 22. Feb 17:45 mods-config
drwxr-xr-x  2 freerad freerad  4096  8. Mär 11:23 mods-enabled
-rw-r-----  1 freerad freerad    52 27. Nov 2017  panic.gdb
drwxr-xr-x  2 freerad freerad  4096 22. Feb 17:51 policy.d
-rw-r-----  1 root    freerad   488 22. Feb 17:51 proxy.conf
-rw-r-----  1 freerad freerad 29206 19. Aug 2023  proxy.conf.debian
-rw-r-----  1 root    freerad 31470 22. Feb 18:01 radiusd.conf
-rw-r-----  1 freerad freerad 30773 19. Aug 2023  radiusd.conf.debian
-rw-r-----  1 freerad freerad 20754 19. Aug 2023  README.rst
drwxr-xr-x  2 freerad freerad  4096 22. Feb 17:51 sites-available
drwxr-xr-x  2 freerad freerad  4096 22. Feb 17:44 sites-enabled
-rw-r-----  1 freerad freerad  3470 27. Nov 2017  templates.conf
-rw-r-----  1 freerad freerad  8536 27. Nov 2017  trigger.conf
lrwxrwxrwx  1 root    root       27 19. Aug 2023  users -> mods-config/files/authorize
Had to do this this morning too. Wi-Fi wasn’t working for any users. Must be a cache or something that expired… Strange.
Hello everyone,
We have received new information regarding the described error and its behavior.
Would it be possible for you to provide the output of the following command from the system where the error occurred on UCS 5.2?
ls -la /etc/freeradius.secret
Many thanks and best regards,
MiracErde
Univention Support
on my system (5.2) it looks like this:
# ls -la /etc/freeradius.secret
-r--r----- 1 freerad freerad 20 16. Jun 01:08 /etc/freeradius.secret
Regards,
Thomas
Hi!
Thank you for the information. The permissions of this file are updated every 21 days (every time the server credentials are automatically rotated). You posted your listing of /etc/freeradius/3.0/ 24 days ago, so it may have already taken care of itself. Do you have the ability to repeat the test without the workaround (i.e. remove the capability)?
Please note: We are still unable to reproduce the bug on our test machines and are looking for any clues we can get.
Many greetings
Sönke (Univention Development)
I did the following:
  • disable “AmbientCapabilities=CAP_DAC_OVERRIDE” (systemctl edit freeradius.service)
  • systemctl daemon-reload
  • systemctl restart freeradius.service
    as soon as I try to connect to my WiFi from a device, I get the following output in the radius.log-file (/var/log/freeradius/radius.log)
Sat Jun 21 10:56:27 2025 : ERROR: (8) mschap: ERROR: Program returned code (1) and output ''
Sat Jun 21 10:56:27 2025 : Auth: (8)   Login incorrect (mschap: Program returned code (1) and output ''): [*myusername*/<via Auth-Type = eap>] (from client *accesspointname* port 0 via TLS tunnel)
Sat Jun 21 10:56:27 2025 : Auth: (9) Login incorrect (eap_peap: The users session was previously rejected: returning reject (again.)): [*myusername*/<via Auth-Type = eap>] (from client *accesspointname* port 1 cli 80-86-D9-77-7A-16)
Restoring the previous option in the systemd unit-file resolves the problem again.
Here an actual output of the folder-permissions:
:~# ls -la /etc/freeradius
insgesamt 32
drwxr-s---   4 freerad freerad  4096 11. Feb 2020  .
drwxr-xr-x 147 root    root    20480 16. Jun 01:08 ..
drwxr-xr-x   9 freerad freerad  4096 23. Feb 16:52 3.0
drwxr-sr-x   2 root    freerad  4096 22. Feb 18:01 ssl
:~# ls -la /etc/freeradius/3.0/
insgesamt 216
drwxr-xr-x  9 freerad freerad  4096 23. Feb 16:52 .
drwxr-s---  4 freerad freerad  4096 11. Feb 2020  ..
drwxr-xr-x  2 freerad freerad  4096 21. Jun 05:55 mods-available
Let me know if I can provide more infos.
Just a guess - til now it looks like to be a problem when upgrading to 5.2. None of the comments here spoke about a fresh install (didn’t try this for myself).
Kind regrads,
Thomas
Same problem over here, since upgrade to UCS 5.2-2 from latest 5.0 (4 days ago).
The problem started today at 00:01 which may be a hint to a rotated file, maybe in conjuntion with caches.
The suggested workaround by editing the systemd unit file resolved the problem.
Current permissions:
# ls -lah /etc/freeradius.secret
-r--r----- 1 freerad freerad 20 19. Jun 13:22 /etc/freeradius.secret
# ls -lah /etc/freeradius/*
/etc/freeradius/3.0:
insgesamt 208K
drwxr-xr-x  9 freerad freerad 4,0K 20. Jun 21:49 .
drwxr-s---  4 freerad freerad 4,0K 19. Jun 13:22 ..
-rw-r-----  1 freerad freerad  21K 19. Aug 2023  README.rst
drwxr-xr-x  2 freerad freerad 4,0K 19. Jun 13:22 certs
-rw-r-----  1 freerad freerad 8,2K 19. Aug 2023  clients.conf
-rw-r-----  1 freerad freerad 1,4K  8. Apr 2024  clients.conf.example
-rw-------  1 freerad root     950 20. Jun 21:49 clients.univention.conf
-rw-r-----  1 freerad freerad 1,4K 19. Aug 2023  dictionary
-rw-r-----  1 freerad freerad 2,6K 19. Aug 2023  experimental.conf
lrwxrwxrwx  1 freerad freerad   28 19. Aug 2023  hints -> mods-config/preprocess/hints
lrwxrwxrwx  1 freerad freerad   33 19. Aug 2023  huntgroups -> mods-config/preprocess/huntgroups
drwxr-xr-x  2 freerad freerad 4,0K 22. Jun 05:55 mods-available
drwxr-xr-x 10 freerad freerad 4,0K 19. Jun 13:22 mods-config
drwxr-xr-x  2 freerad freerad 4,0K 19. Jun 13:22 mods-enabled
-rw-r-----  1 freerad freerad   52 19. Aug 2023  panic.gdb
drwxr-xr-x  2 freerad freerad 4,0K 19. Jun 13:22 policy.d
-rw-r-----  1 root    freerad  482 20. Jun 10:41 proxy.conf
-rw-r-----  1 freerad freerad  29K 19. Aug 2023  proxy.conf.debian
-rw-r-----  1 root    freerad  31K 20. Jun 18:09 radiusd.conf
-rw-r-----  1 root    freerad  31K 19. Jun 13:22 radiusd.conf.debian
drwxr-xr-x  2 freerad freerad 4,0K 20. Jun 10:42 sites-available
drwxr-xr-x  2 freerad freerad 4,0K 19. Jun 13:22 sites-enabled
-rw-r-----  1 freerad freerad 3,4K 19. Aug 2023  templates.conf
-rw-r-----  1 freerad freerad 8,4K 19. Aug 2023  trigger.conf
lrwxrwxrwx  1 freerad freerad   27 19. Aug 2023  users -> mods-config/files/authorize
/etc/freeradius/ssl:
insgesamt 24K
drwxr-sr-x 2 root    freerad 4,0K 19. Jun 13:22 .
-r--r--r-- 1 root    freerad 5,7K 19. Jun 13:22 cert.pem
-r--r--r-- 1 root    freerad  245 19. Jun 13:22 dh
-r--r----- 1 root    freerad 1,7K 19. Jun 13:22 private.key
Nothing helpful in /valog/freeradius/radius.log
Only this error is logged:
Sat Jun 21 00:01:25 2025 : Debug: (2026)     modsingle[authorize]: returned from ntdomain (rlm_realm)
Sat Jun 21 00:01:25 2025 : Debug: (2026)     [ntdomain] = noop
Sat Jun 21 00:01:25 2025 : Debug: (2026)     policy user_name_is_mac {
Sat Jun 21 00:01:25 2025 : Debug: (2026)       if (&User-Name && (&User-Name =~ /^([0-9a-f]{2})[^0-9a-f]?([0-9a-f]{2})[^0-9a-f]?([0-9a-f]{2})[^0-9a-f]?([0-9a-f]{2})[^0-9a-f]?([0-9a-f]{2})[^0-9a-f]?([0-9a-f]{2})$/i)) {
Sat Jun 21 00:01:25 2025 : Debug: Clearing 7 old matches
Sat Jun 21 00:01:25 2025 : Debug: (2026)       if (&User-Name && (&User-Name =~ /^([0-9a-f]{2})[^0-9a-f]?([0-9a-f]{2})[^0-9a-f]?([0-9a-f]{2})[^0-9a-f]?([0-9a-f]{2})[^0-9a-f]?([0-9a-f]{2})[^0-9a-f]?([0-9a-f]{2})$/i))  -> FALSE
Sat Jun 21 00:01:25 2025 : Debug: (2026)       else {
Sat Jun 21 00:01:25 2025 : Debug: (2026)         modsingle[authorize]: calling noop (rlm_always)
Sat Jun 21 00:01:25 2025 : Debug: (2026)         modsingle[authorize]: returned from noop (rlm_always)
Sat Jun 21 00:01:25 2025 : Debug: (2026)         [noop] = noop
Sat Jun 21 00:01:25 2025 : Debug: (2026)       } # else = noop
Sat Jun 21 00:01:25 2025 : Debug: (2026)     } # policy user_name_is_mac = noop
Sat Jun 21 00:01:25 2025 : Debug: (2026)     if (control:Auth-Type == "CSID" && EAP-Message ) {
Sat Jun 21 00:01:25 2025 : ERROR: (2026)     Failed retrieving values required to evaluate condition
Sat Jun 21 00:01:25 2025 : Debug: (2026)     modsingle[authorize]: calling eap (rlm_eap)
Sat Jun 21 00:01:25 2025 : Debug: (2026) eap: Peer sent EAP Response (code 2) ID 110 length 24
Sat Jun 21 00:01:25 2025 : Debug: (2026) eap: EAP-Identity reply, returning 'ok' so we can short-circuit the rest of authorize
Sat Jun 21 00:01:25 2025 : Debug: (2026)     modsingle[authorize]: returned from eap (rlm_eap)
Sat Jun 21 00:01:25 2025 : Debug: (2026)     [eap] = ok
Sat Jun 21 00:01:25 2025 : Debug: (2026)   } # authorize = ok
Sat Jun 21 00:01:25 2025 : Debug: (2026) Found Auth-Type = eap
Sat Jun 21 00:01:25 2025 : Debug: (2026) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
Sat Jun 21 00:01:25 2025 : Debug: (2026)   Auth-Type eap {
Sat Jun 21 00:01:25 2025 : Debug: (2026)     modsingle[authenticate]: calling eap (rlm_eap)
Sat Jun 21 00:01:25 2025 : Debug: (2026) eap: Peer sent packet with method EAP Identity (1)
Sat Jun 21 00:01:25 2025 : Debug: (2026) eap: Calling submodule eap_peap to process data
Sat Jun 21 00:01:25 2025 : Debug: (2026) eap_peap: (TLS) Initiating new session
Sat Jun 21 00:01:25 2025 : Debug: (2026) eap_peap: [eaptls start] = request
Hi @chris.g
Hi @dWc
Thanks a lot for the information! We’re now able to reproduce the problem.
Yes, you are right.
The fix should be:
  • chown freerad:freerad /var/log/univention/radius_ntlm_auth.log
  • ucr set logrotate/radius_ntlm_auth/create="644 freerad freerad"
Would be nice, if you can verify if this fixes the problem. We’re currently preparing an automatic fix via an errata update.
:warning: If you have implemented the workaround from Problem: Radius - Since upgrading to 5.2-x login to Radius fails - mschap: Program returned code (1), you have to remove AmbientCapabilities=CAP_DAC_OVERRIDE manually to prevent security problems on the long term.
Greetings,
Sönke
Hello again,
here the permissions before the manual fix
:~# ls -l /var/log/univention/radius_ntlm_auth.log
-rw-r--r-- 1 root freerad 7007 23. Jun 12:33 /var/log/univention/radius_ntlm_auth.log
:~# ucr get logrotate/radius_ntlm_auth/create
644 root freerad
and after the fix:
-rw-r--r-- 1 freerad freerad 7007 23. Jun 12:33 /var/log/univention/radius_ntlm_auth.log
644 freerad freerad
Now it looks like that it works again as it should (removed the AmbientCapabilities=CAP_DAC_OVERRIDE and restartet freeradius):
Mon Jun 23 13:02:20 2025 : Auth: (12)   Login OK: [*myusername*] (from client *accesspointname* port 0 via TLS tunnel)
Mon Jun 23 13:02:20 2025 : Auth: (13) Login OK: [*myusername*] (from client *accesspointname* port 1 cli 80-86-D9-77-7A-16)
Thank you very much
Kind regards,
Thomas
I can confirm that the proposed fix works.
Thanks!
