After the upgrade to UCS 5.2-x, errors occur in /var/log/freeradius/radius.log and the login to the radius server is fails. The following error message is logged.
Mon Apr 28 10:28:22 2025 : Auth: (108612) Login incorrect (mschap: Program returned code (1) and output ''): [atv.s2845/<via Auth-Type = eap>] (from client external_uni_02 port 0 via TLS tunnel)
Mon Apr 28 10:28:22 2025 : Auth: (108627) Login incorrect (eap_peap: The users session was previously rejected: returning reject (again.)): [atv.s2845/<via Auth-Type = eap>] (from client external_uni_02 port 1 cli C0-95-6D-00-00-00)
Mon Apr 28 10:28:22 2025 : ERROR: (108618) mschap: ERROR: Program returned code (1) and output ''
Mon Apr 28 10:28:22 2025 : Auth: (108618) Login incorrect (mschap: Program returned code (1) and output ''): [ipd.s2848/<via Auth-Type = eap>] (from client external_uni_02 port 0 via TLS tunnel)
Mon Apr 28 10:28:22 2025 : Auth: (108630) Login incorrect (eap_peap: The users session was previously rejected: returning reject (again.)): [ipd.s2848/<via Auth-Type = eap>] (from client external_uni_02 port 1 cli 7C-61-30-00-00-00)
Root Cause Bug 58132
Fixed with Erratum 127
- Check if all join scripts have been called. Especially the join script of
univention-radiushas to be run successfully.
univention-check-join-status
- Check the permisions of
/etc/freeradius.secretand/var/log/univention/radius_ntlm_auth.log. If in doubt, just reset it.
ls -lah /etc/freeradius.secretchown freerad:freerad /etc/freeradius.secretchmod 440 /etc/freeradius.secretchown freerad:freerad /var/log/univention/radius_ntlm_auth.logchmod 644 /var/log/univention/radius_ntlm_auth.log
- If not already set by the latest
univention-radiuspackage, adapt the logrotate settings:
ucr set logrotate/radius_ntlm_auth/create="644 freerad freerad"
- Restart the Service for the Radius Server and check the
/var/log/freeradius/radius.logif the issue is solved.
systemctl restart freeradius.service
5. Check if the steps 1 - 4 were already sufficient to fix the problem. Do not continue, if your problem is fixed!
Hint
The permissions of the two file are updated every 21 days (every time the server credentials are automatically rotated) resp. nightly:
Correct permissions:
-r--r----- 1 freerad freerad 20 Jun 16 12:40 /etc/freeradius.secret
-rw-r--r-- 1 freerad freerad 0 Jun 22 00:00 /var/log/univention/radius_ntlm_auth.log
Workaround:
If the problem persists, try the following workaround.
You have to stop the Radius server
systemctl stop freeradius.service -
Get into the edit mode for the Radius service
systemctl edit freeradius -
Add this to the systemd service and save.
### Anything between here and the comment below will become the new contents of the file"
[Service]
AmbientCapabilities=CAP_DAC_OVERRIDE
- Start the Radius service
systemctl start freeradius.service
