When running univention-run-join-scripts a script return an error code:
Running 03univention-directory-listener.inst failed (exitcode: 1)
Environment
Additional scripts failing with errorcode 1 are:
20univention-directory-policy.inst
30univention-appcenter.inst
Other scripts show status “done”.
In /var/log/univention/join.log you will see:
05.10.18 10:56:28.138 LDAP ( ERROR ) : ldap_simple_bind: Invalid credentials
05.10.18 10:56:28.138 LISTENER ( WARN ) : can not connect to LDAP server master.domain.com:7389
05.10.18 10:56:28.138 LISTENER ( ERROR ) : can not connect any server, exit
“Invalid credentials” is referring to the machine account credentials. There is a mismatch between the stored credentials and the one noted in the LDAP directory on the master server.
Reset the machine account password by the following steps.
Step 1
Identify the distinguished name for the server to be joined
root@backup:~# ucr get ldap/hostdn
cn=backup,cn=dc,cn=computers,dc=domain,dc=intranet
Step 2
Check the the role and the password currently stored on the server to be joined
root@backup:~# ucr get server/role
domaincontroller_backup
root@backup:~# cat /etc/machine.secret
KUXmzDFwBMW4V1oAudiC7root@backup:~#
Step 3 (on the master)
Set the password in LDAP on the master to match the locally stored one
udm computers/domaincontroller_backup modify --dn="cn=backup,cn=dc,cn=computers,dc=domain,dc=intranet" --set password="<PASSWORD FROM machine.secret>"
Note: Replace the “domaincontroller_backup” in the above command by the value of server/role from Step 2.
Now, the 03univention-directory-listener.inst should not report any wrong credentials.
