Univention Management Console (UMC) complains about missing default values and informs to set them as shown in the following screenshot:
The following empty properties were set to default values in the form.
These values will be applied when saving.
* Account .....
Create and execute the following Python script. It will set all empty attributes to the default values; this can be done for users as well as for groups and computers.
Users
#!/usr/bin/python2
import univention.admin.modules as modules
from univention.admin.uldap import getAdminConnection
FILTER_STRING = ''
modules.update()
lo,po=getAdminConnection()
user_mod = modules.get('users/user')
modules.init(lo,po,user_mod)
users = user_mod.lookup(None, lo, FILTER_STRING)
for user in users:
user.open()
print("Setting default values for user '{}'".format(user['username']))
user.set_defaults = 1
user.set_default_values()
user.modify()
Groups
You can do this similar with groups
#!/usr/bin/python2
FILTER_STRING = ''
modules.update()
group_mod = modules.get('groups/group')
modules.init(lo,po,group_mod)
groups = group_mod.lookup(None, lo, FILTER_STRING)
for group in groups:
group.open()
print("Setting default values for group '{}'".format(group['name']))
group.set_defaults = 1
group.set_default_values()
group.modify()
Computers
The following snippet sets the default values only for windows computers (computers/windows). Its also possible to replace the UDM windows computer module name with another UDM computer module, e.g. computers/linux.
#!/usr/bin/python2
FILTER_STRING = ''
modules.update()
lo, po = getAdminConnection()
computer_mod = modules.get('computers/windows')
modules.init(lo, po, computer_mod)
computers = computer_mod.lookup(None, lo, FILTER_STRING)
for computer in computers:
computer.open()
print("Setting default values for computer '{}'".format(computer['name']))
computer.set_defaults = 1
computer.set_default_values()
computer.modify()
