During the upgrade from UCS 5 to 5.2 there were some errors reported and the upgrade failed:
Processing triggers for univention-config (16.0.6) ...
dpkg-query: no packages found matching ldapacl_66univention-appcenter_app.acl
dpkg-query: no packages found matching messages_en.properties
dpkg-query: no packages found matching ldapacl_62univention-monitoring.acl
dpkg-query: no packages found matching ldapacl_58openid-connect-provider.ldapacl
dpkg-query: no packages found matching univention-keycloak
dpkg-query: no packages found matching ldapacl_61guardian.acl
dpkg-query: no packages found matching ldapacl_62univention-portal.acl
dpkg-query: no packages found matching ldapacl_59univention-radius.acl
dpkg-query: no packages found matching messages_de.properties
dpkg-query: no packages found matching ldapacl_67keycloak.acl
dpkg-query: no packages found matching ldapacl_66univention-radius.acl
dpkg-query: no packages found matching 50-keycloak
Errors were encountered while processing:
univention-dhcp
WARNING: database "pkgdb" has a collation version mismatch
DETAIL: The database was created using collation version 2.28, but the operating system provides version 2.31.
HINT: Rebuild all objects in this database that use the default collation and run ALTER DATABASE pkgdb REFRESH COLLATION VERSION, or build PostgreSQL with the right library version.
Reading package lists... 0%
Reading package lists... Done
Building dependency tree... 0%
Building dependency tree... Done
Reading state information... 0%
Reading state information... Done
Error: Failed to execute "apt-get -o DPkg::Options::=--force-confold -o DPkg::Options::=--force-overwrite -o DPkg::Options::=--force-overwrite-dir --trivial-only=no --assume-yes --quiet=1 dist-upgrade"
Cause
The issue seems to be related to the univention-dhcp package. During the upgrade process, certain package references and triggers fail, which prevents apt from completing the upgrade
To resolve the problem, temporarily removing the univention-dhcp package before continuing with the upgrade helped.
Remove the problematic package:
apt remove univention-dhcp -
Proceed with the UCS upgrade to version 5.2-0.
After the system has been successfully upgraded, reinstall the DHCP package:
apt install univention-dhcp
