A failed.ldif is found on your server. You may know this article from the past.
Since the introduction of systemd, there might be complications following the article from above.
So try the following steps to reread the failed.ldif
Step 1
Check the slapd status
systemctl status slapd.service
If this looks like this: Active: active (running)
root@master:~# systemctl status slapd.service
● slapd.service - LSB: OpenLDAP standalone server (Lightweight Directory Access Protocol)
Loaded: loaded (/etc/init.d/slapd; generated; vendor preset: enabled)
Active: active (running) since Wed 2019-05-08 11:25:08 CEST; 1h 4min ago
Process: 752 ExecStart=/etc/init.d/slapd start (code=exited, status=0/SUCCESS)
Main PID: 1379 (slapd)
Tasks: 7 (limit: 4915)
Memory: 16.0M
CPU: 5.837s
CGroup: /system.slice/slapd.service
└─1379 /usr/sbin/slapd -h ldapi:/// ldap://:7389/ ldaps://:7636/
You an try the reread via systemctl restart slapd.service or /etc/init.d/slapd restart
Step 2
If the import/reread fails, then systemctl status from systemd may looks like this:
systemctl status slapd.service·
Active: failed (Result: timeout) since Mon 2019-04-15 15:26:58 CEST; 20min ago
Process: 29566 ExecStop=/etc/init.d/slapd stop (code=exited, status=0/SUCCESS)
Process: 3654 ExecStart=/etc/init.d/slapd start (code=exited, status=0/SUCCESS)
Main PID: 15274 (code=exited, status=0/SUCCESS)
Tasks: 4 (limit: 4915)
Memory: 12.1M
CPU: 2.966s
└─3093 /usr/sbin/slapd -h ldapi:/// ldap://:7389/ ldaps://:7636/
Here you see Active: failed (Result: ) but there is a process3093 /usr/sbin/slapd -h ldapi:/// ldap://:7389/ ldaps://:7636/running.
So systemd does not show and therefor does not stop this process next time. Systemd does not feel responsible anymore.
Step 3
You can now kill this process via pkill slapd
If you want to retry the failed.ldif import you can start and stop slapd without systemd like this;
SYSTEMCTL_SKIP_REDIRECT=1 /etc/init.d/slapd start
Step 4a
If the import of the failed.ldif went well, you have to check if the listener is still running.
ps aufx |grep listener
root 516 0.0 0.0 4048 0 ? Ss 11:24 0:00 \_ runsv univention-directory-listener
root 19574 0.0 0.0 14320 968 pts/1 S+ 12:20 0:00 | \_ grep listener
The listener is not running!
It should look like this:
listener 1740 0.0 0.0 2893420 960 ? S 11:25 0:02 | \_ /usr/sbin/univention-directory-listener -F -d 2 -b dc=schein,dc=me -m /usr/lib/univention-directory-listener/system -c /var/lib/univention-directory-listener -ZZ -x -D cn=admin,dc=schein,dc=me -y /etc/ldap.secret
You can start the listener via
systemctl restart univention-directory-listener.service
Step 4b
If the import did not succeed remove the failed.ldif file and restart the LDAP-Server (slapd) with Step 3.
mv /var/lib/univention-directory-replication/failed.ldif ~
Step 5
It the failed.ldif has been moved and the slapd still does not start with the same reason (failed.ldif exists) the slapd has an issue with starting. Use this article to troubleshoot this:
