Empty failed.ldif could not be removed.
For example on a slave you see in
/var/log/univention/listener.log
that you have a failed.ldif
Investigation:
You troubleshoot with
but the failed.ldif is empty and pops up again after removing.
Switch to the mdb backend for ldap, if you are still using the bdb backend.
ucr get ldap/database/type
http://docs.software-univention.de/performance-guide-5.0.html#slapd:bdb
/etc/init.d/slapd stop
slapcat -l ldif
mkdir /var/lib/univention-ldap/ldap.BACKUP
mv /var/lib/univention-ldap/ldap/* /var/lib/univention-ldap/ldap.BACKUP
ucr set ldap/database/type=mdb
slapadd -l ldif
systemctl daemon-reload
/etc/init.d/slapd start
