Problem: New errata updates are not shown:
You have a message in your
/etc/apt/sources.list.d/20_ucs-online-component.list
# Configuration error: component not found: 4.1-5-errata
Or no further repositories are shown
#Warning: This file is auto-generated and might be overwritten by
# univention-config-registry.
# Please edit the following file(s) instead:
#Warnung: Diese Datei wurde automatisch generiert und kann durch
# univention-config-registry ueberschrieben werden.
# Bitte bearbeiten Sie an Stelle dessen die folgende(n) Datei(en):
# /etc/univention/templates/files/etc/apt/sources.list.d/20_ucs-online-component.list
deb https://updates.software-univention.de/4.3/maintained/component/ 4.3-2-errata/all/
deb https://updates.software-univention.de/4.3/maintained/component/ 4.3-2-errata/i386/
deb https://updates.software-univention.de/4.3/maintained/component/ 4.3-2-errata/amd64/
deb https://updates.software-univention.de/4.2/maintained/component/ 4.2-4-errata/all/
deb https://updates.software-univention.de/4.2/maintained/component/ 4.2-4-errata/i386/
deb https://updates.software-univention.de/4.2/maintained/component/ 4.2-4-errata/amd64/
Check your Key ID on our Webserver:
http://updates.software-univention.de/4.2/maintained/component/4.2-5-errata/
You will be asked to login. You can use the output of
ucr get uuid/license
as username and password.
If this is not working, or you do not have an output from the variable you have to make sure you have installed your licence correctly. If your license is very old it is probably not associated with the contract number. The Key ID then is not recognized in our repo system.
If you cannot login with the key, you should get in contact with our sales team.
Investigation
- Which UCS components do you not have access to?
- Have you imported the license file supplied by Univention Sales into your UCS domain?
- What output does
ucr get uuid/licensedeliver?
e922929e-59ea-40be-ac1d-910a189fe477
- Which version is shown by
udm settings/license list?
DN: cn=admin,cn=license,cn=univention,dc=schein,dc=ig
base: dc=schein,dc=ig
corporateclients: unlimited
expires: unlimited
keyID: e922929e-59ea-40be-ac1d-910a189fe477
managedclients: unlimited
premiumsupport: 0
servers: unlimited
signature: gJOhQ59k4c1eXmf4DxPZFldBguDxUa3h6bm00zLn0b+ShsiUJJTGRadU2/fnFM8VtTHN+OEzZyOp6R+e2v2FQO7c7F683N5X8ZUgTTRVGUsjGu+Dd9SzEuK8R3kffdJvSq7Hxe+BJBAj8KE8gKBcyKvU+u9Fi9svl4ZYPaJiyVuEV6VOfYaC8z/z82oe7kYPNerXBPiVZHyXIu8Z4r1otc8yiR4b0jRbW3YkUlo2KWTptCGthu21/2c/H9V961PAqKR6uoAXntcHMv3eUpBLQK6g4S/aXxXFXYf/Unlv645An2Z7zh3Eg9ET3MF1Rdm8ZFRsQ7OBmOtjJXAfFo9VIA==
support: 0
users: unlimited
version: 2
virtualdesktopclients: 0
virtualdesktopusers: 0
