Problem: 92univention-management-console-web-server.inst fails with Could not connect to keycloak server
ERROR: Could not connect to keycloak server on https://ucs-sso-ng.univention-school.intranet/:
        HTTPSConnectionPool(host='ucs-sso-ng.univention-school.intranet', port=443): Max retries exceeded with url: // (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate in certificate chain (_ssl.c:992)')))
Please check the UCR settings for keycloak/server/sso/fqdn and keycloak/server/sso/path,
on the Keycloak App server and check that it matches the UCR setting for ucs/server/sso/uri on this host.
Make sure that keycloak and apache are running on the keycloak server!
  1. Make sure keycloak/server/sso/fqdn is set correctly on the server.
  2. Check the certificates are present in /usr/local/share/ca-certificates/
  3. Make sure the certificates are PEM Certificates and not text
    file /usr/local/share/ca-certificates/MyOwnRootCA.crt
    /usr/local/share/ca-certificates/MyOwnRootCA.crt: Unicode text, UTF-8 text
    → :negative_squared_cross_mark:
    file /etc/ssl/certs/MyOwnSubCA1.pem
    /etc/ssl/certs/MyOwnSubCA1.pem: PEM certificate
    → :white_check_mark:
  4. univention-keycloak get-keycloak-base-url
  5. Check there is no policy setting the old saml path to umc/saml/idp-server
    umc/saml/idp-server is overridden by scope "ldap"
    ucr set umc/saml/idp-server='https://ucs-sso-ng.univention-school.intranet/realms/ucs/protocol/saml/descriptor'
Investigation:
openssl s_client -connect ucs-sso-ng.univention-school.intranet:443 -showcerts
should show all certificates. It validates the certificates different then curl -v !
univention-keycloak get-keycloak-base-url should work on the server. This should work in order to fisnish the joinscript.
HTTPSConnectionPool(host='ucs-sso-ng.univention-school.intranet', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection
object at 0x7f8f17f8a0b8>: Failed to establish a new connection: [Errno -2] Name or service not known'))
nection object at 0x7f8f17f8a0b8>: Failed to establish a new connection: [Errno -2] Name or service not known'))
and make sure that keycloak and apache are running on the keycloak server!
If you are using your own certificates, check this article starting with step4a
