Thanks for your answer.
This is the output
root@worblingen:/var/log/samba# sudo ucr set --force samba/interfaces=“$(ucr get samba/interfaces) lo”
bash: ucr: Kommando nicht gefunden.
Setting samba/interfaces
Multifile: /etc/samba/smb.conf
I was able to login in the admin webinterface of opsi!!!
But i found out, that there is problem with the samba shares.
Connecting in Windows 10 explorer is not possbile. Windows cant find any shares, even not the server itself.
Samba is running.
Here are the logs from samba, - it seems normal for me:
Here the logs from samba (nmbd):
[2023/04/13 00:19:58.217382, 0, pid=1123] …/…/source3/nmbd/nmbd.c:901(main)
nmbd version 4.16.8-Univention started.
Copyright Andrew Tridgell and the Samba Team 1992-2022
[2023/04/13 00:19:58.286165, 0, pid=1147] …/…/source3/nmbd/asyncdns.c:158(start_async_dns)
started asyncdns process 1148
[2023/04/13 00:19:58.287189, 0, pid=1147] …/…/lib/util/become_daemon.c:150(daemon_status)
daemon_status: daemon ‘nmbd’ : No local IPv4 non-loopback interfaces available, waiting for interface …
[2023/04/13 00:19:58.287208, 0, pid=1147] …/…/source3/nmbd/nmbd_subnetdb.c:253(create_subnets)
NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
[2023/04/13 23:33:20.541196, 0, pid=26385] …/…/source3/nmbd/nmbd.c:901(main)
[2023/04/13 23:33:20.544414, 0, pid=26386] …/…/source3/nmbd/asyncdns.c:158(start_async_dns)
started asyncdns process 26387
[2023/04/13 23:33:20.545877, 0, pid=26386] …/…/lib/util/become_daemon.c:150(daemon_status)
[2023/04/13 23:33:20.545917, 0, pid=26386] …/…/source3/nmbd/nmbd_subnetdb.c:253(create_subnets)
[2023/04/13 23:35:49.901580, 0, pid=26754] …/…/source3/nmbd/nmbd.c:901(main)
[2023/04/13 23:35:49.905284, 0, pid=26755] …/…/source3/nmbd/asyncdns.c:158(start_async_dns)
started asyncdns process 26756
[2023/04/13 23:35:49.906591, 0, pid=26755] …/…/lib/util/become_daemon.c:150(daemon_status)
[2023/04/13 23:35:49.906624, 0, pid=26755] …/…/source3/nmbd/nmbd_subnetdb.c:253(create_subnets)
and here log.samba:
[2023/04/13 00:20:02.874735, 0, pid=1163] …/…/source4/samba/server.c:623(binary_smbd_main)
samba version 4.16.8-Univention started.
[2023/04/13 00:20:46.987425, 0, pid=1218] …/…/source4/samba/server.c:897(binary_smbd_main)
binary_smbd_main: samba: using ‘prefork’ process model
[2023/04/13 00:21:02.221578, 1, pid=1646] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
Doing a full scan on DC=ForestDnsZones,DC=ddns-net,DC=intranet and looking for deleted objects
[2023/04/13 00:21:02.877336, 1, pid=1646] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
Doing a full scan on DC=DomainDnsZones,DC=ddns-net,DC=intranet and looking for deleted objects
[2023/04/13 00:21:03.443877, 1, pid=1646] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
Doing a full scan on CN=Configuration,DC=ddns-net,DC=intranet and looking for deleted objects
[2023/04/13 00:21:09.870752, 1, pid=1646] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
Doing a full scan on DC=ddns-net,DC=intranet and looking for deleted objects
[2023/04/13 23:33:21.692271, 0, pid=26413] …/…/source4/samba/server.c:623(binary_smbd_main)
[2023/04/13 23:33:21.941494, 0, pid=26414] …/…/source4/samba/server.c:897(binary_smbd_main)
[2023/04/13 23:33:37.145084, 1, pid=26455] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
[2023/04/13 23:33:37.147139, 1, pid=26455] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
[2023/04/13 23:33:37.150055, 1, pid=26455] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
[2023/04/13 23:33:37.197066, 1, pid=26455] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
[2023/04/13 23:35:51.622441, 0, pid=26791] …/…/source4/samba/server.c:623(binary_smbd_main)
[2023/04/13 23:35:51.925426, 0, pid=26792] …/…/source4/samba/server.c:897(binary_smbd_main)
[2023/04/13 23:36:07.084314, 1, pid=26832] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
[2023/04/13 23:36:07.086573, 1, pid=26832] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
[2023/04/13 23:36:07.089518, 1, pid=26832] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
[2023/04/13 23:36:07.137651, 1, pid=26832] …/…/source4/dsdb/kcc/garbage_collect_tombstones.c:68(garbage_collect_tombstones_part)
I can now login to opsiconfiged, but there is also an error:
2023-04-14 00:02:04.928 – Opsi service error: [JSONDecodeError] Expecting value: line 1 column 2 (char 1)
2023-04-14 00:02:05.014 – JSONReMapper: Exception on reproducing null, java.lang.NullPointerException: Cannot invoke “java.util.List.iterator()” because “” is null
Here is a screenshot:
configed
i dont have any idea
Greetings
Stefan
