I have installed for a first test the OPSI Package on my UCS 4.1. The setup is finished, but I cannot login.
Which are the credentials of the Opsi Config Editor?
How can i force a new installation of OPSI4 UCS? I think (i have several install / deinstall the package via the App Center) that something is going wrong. In the LDAP i missing the mentioned user “pcpatch” or group “opsiadmin”
By the first try to login - before i deinstall and do some much more - the user “Administrator” was in group “opsiadmin”. I create a new user in the domain and add them to the group too, but no login was possible.
My current state: I have remove UCS from the App Center. Now only “opsiconfd” and “opsipxeconfd” are still there and cannot remove:
Löschen der Konfigurationsdateien von opsipxeconfd ...
Removing any system startup links for /etc/init.d/opsipxeconfd ...
dpkg: Fehler beim Bearbeiten von opsipxeconfd (--purge):
Unterprozess installiertes post-removal-Skript gab den Fehlerwert 1 zurück
opsipxeconfd
W: Can not find PkgVer for 'opsipxeconfd'
Then I go to Domain Settings and rerun the 99opsi4ucs Join-Script. Now all users/groups again available I check, that the “Administrator”-Account is in group “opsiadmin”
Then I restart the server and try again to login. When I use the account “Administrator” or another user then I cant login. But when i use “root” with the password of the administrator, then i can login - but i have some errors:
Okt 12 17:02:51.450 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'config_updateObjects' denied for user 'root': Backend permission denied error: Access denied
Okt 12 17:02:51.515 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'config_updateObjects' denied for user 'root': Backend permission denied error: Access denied
Okt 12 17:02:51.811 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'group_getObjects' denied for user 'root'
Okt 12 17:02:52.064 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'objectToGroup_getObjects' denied for user 'root'
Okt 12 17:02:52.135 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'config_updateObjects' denied for user 'root': Backend permission denied error: Access denied
Okt 12 17:03:10.120 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'configState_getObjects' denied for user 'root'
Okt 12 17:03:10.123 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Okt 12 17:03:10.134 2017 -- Nicht erwarteter Fehler 6
Bitte die Logdatei einsehen
Okt 12 17:03:11.290 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'config_updateObjects' denied for user 'root': Backend permission denied error: Access denied
Okt 12 17:03:11.377 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'config_updateObjects' denied for user 'root': Backend permission denied error: Access denied
Okt 12 17:03:12.445 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'product_getObjects' denied for user 'root'
Okt 12 17:03:12.448 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Okt 12 17:03:12.524 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'productOnDepot_getObjects' denied for user 'root'
Okt 12 17:03:12.526 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Okt 12 17:03:12.601 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'config_getObjects' denied for user 'root'
Okt 12 17:03:12.669 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'productProperty_getObjects' denied for user 'root'
Okt 12 17:03:12.673 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Okt 12 17:03:13.092 2017 -- Opsi service error: [BackendPermissionDeniedError] Backend permission denied error: Access to method 'config_getObjects' denied for user 'root'
MySQL is disabled as general backend. It is free however to use it for inventory data and should be configured to do so. Please look at this chapter in the getting started for more information about the backends.
The message about the missing /etc/opsi/modules file can be ignored.
OK - thanks for this informations. I try it again with the new User. The User is in group “opsiadmin” and “opsifileadmin”. I try again to login, but no success.
The user credentials are correct. There no special characters or something. Only a word with small characters
BTW: Should a open a question in the german opsi-forum? My first language is german - but can i put in questions about Opsi4Ucs?
