Hello!,
UCS 4.4-9 was upgraded to the latest version (5.0.2) via the web UI. On completion, and reboot, I had the following error. This error was seen by increasing the loglevel and including “nosplash” as described here
This machine is running on a kvm virtualised cloud and has an encrypted disk.
I have tried,
- replace RESUME=/dev/mapper/vg_ucs-swap_1 with RESUME=none. Chrooted in to the system to get this done
- To GRUB_CMDLINE_LINUX_DEFAULT adding “noresume”
- To GRUB_CMDLINE_LINUX_DEFAULT adding “acpi=off”
- Boot using other kernels in the advanced section of the grub bootloader 4.9.0-8 (Oldest) kernel with noresume and acpi=off
Unfortunately none of these worked.
Any help would be greatly appreciated
Last lines of the updater.log are shown below
Failed to process Subfile /etc/univention/templates/files/etc/ldap/slapd.conf.d/64univention-ldap-server_acl-master-admin-settings
Not updating appcenter/docker/compose/network
Setting up univention-management-console-module-quota (14.0.1-7A~5.0.0.202105111310) ...
Calling joinscript 35univention-management-console-module-quota.inst ...
2022-09-09 15:02:04.144363622+05:30 (in joinscript_init)
Joinscript 35univention-management-console-module-quota.inst finished with exitcode 1
Setting umc/web/cache_bust
Module: kopano-cfg
File: /var/www/univention/meta.json
Setting up univention-s4-connector (14.0.7-2A~5.0.0.202105041746) ...
Installing new version of config file /etc/univention/registry.info/variables/univention-s4-connector.cfg ...
Installing new version of config file /etc/univention/service.info/services/univention-s4-connector.cfg ...
Installing new version of config file /etc/univention/templates/files/etc/logrotate.d/univention-s4-connector ...
File: /etc/logrotate.d/univention-s4-connector
Not updating connector/s4/listener/dir
Not updating connector/s4/poll/sleep
Calling joinscript 97univention-s4-connector.inst ...
2022-09-09 15:02:06.732422291+05:30 (in joinscript_init)
A system update is currently being performed. The execution of the join script /usr/lib/univention-install/97univention-s4-connector.inst is therefore postponed.
Joinscript 97univention-s4-connector.inst finished with exitcode 1
Restarting univention-s4-connector (via systemctl): univention-s4-connector.service.
Setting up univention-ldap-acl-master (16.0.7-3A~5.0.0.202105171343) ...
Installing new version of config file /etc/univention/templates/files/etc/ldap/slapd.conf.d/70univention-ldap-server_acl-master-end ...
Installing new version of config file /etc/univention/templates/info/univention-ldap-acl-master.info ...
Multifile: /etc/ldap/slapd.conf
Removing obsolete conffile /etc/univention/templates/files/etc/ldap/slapd.conf.d/64univention-ldap-server_acl-master-admin-settings ...
Setting up univention-management-console-module-reboot (9.0.0-1A~5.0.0.202105111342) ...
Calling joinscript 35univention-management-console-module-reboot.inst ...
2022-09-09 15:02:12.186802699+05:30 (in joinscript_init)
Joinscript 35univention-management-console-module-reboot.inst finished with exitcode 1
Module: kopano-cfg
Setting up libgtk-3-0:amd64 (3.24.5-1) ...
Setting up univention-initrd (12.0.0-4A~5.0.0.202103291715) ...
Installing new version of config file /etc/univention/registry.info/variables/univention-initrd.cfg ...
Installing new version of config file /etc/univention/templates/files/etc/initramfs-tools/initramfs.conf ...
Installing new version of config file /etc/univention/templates/info/univention-initrd.info ...
E: your request could not be fulfilled
try `univention-config-registry --help` for more information
Removing obsolete conffile /etc/univention/templates/files/usr/share/initramfs-tools/init ...
recreate initramfs for all available kernels due to changes in unvenition-initrd...
update-initramfs: Generating /boot/initrd.img-4.19.0-21-amd64
update-initramfs: Generating /boot/initrd.img-4.19.0-20-amd64
update-initramfs: Generating /boot/initrd.img-4.19.0-16-amd64
update-initramfs: Generating /boot/initrd.img-4.9.0-8-amd64
done
Setting up univention-management-console-module-admindiary (2.0.3-1A~5.0.0.202105171326) ...
Calling joinscript 35univention-management-console-module-admindiary.inst ...
2022-09-09 15:03:20.764926217+05:30 (in joinscript_init)
Joinscript 35univention-management-console-module-admindiary.inst finished with exitcode 1
Module: kopano-cfg
Setting up univention-management-console-module-printers (13.0.2-10A~5.0.0.202105111423) ...
loaded json file /var/cache/univention-management-console/acls/root
warning: rule printers/* already exists
Calling joinscript 35univention-management-console-module-printers.inst ...
2022-09-09 15:03:22.712467054+05:30 (in joinscript_init)
Joinscript 35univention-management-console-module-printers.inst finished with exitcode 1
Module: kopano-cfg
Setting up univention-management-console-module-passwordchange (5.0.1-1A~5.0.0.202101222023) ...
Not updating umc/web/hooks/univention-management-console-module-passwordchange
Setting up univention-management-console-module-services (9.0.0-6A~5.0.0.202105111345) ...
Calling joinscript 35univention-management-console-module-services.inst ...
2022-09-09 15:03:24.019832988+05:30 (in joinscript_init)
Joinscript 35univention-management-console-module-services.inst finished with exitcode 1
Module: kopano-cfg
Setting up univention-management-console-module-appcenter (9.0.2-45A~5.0.0.202105171344) ...
Calling joinscript 35univention-management-console-module-appcenter.inst ...
2022-09-09 15:03:25.249155926+05:30 (in joinscript_init)
Joinscript 35univention-management-console-module-appcenter.inst finished with exitcode 1
Module: kopano-cfg
Setting up univention-welcome-screen (11.0.0-3A~5.0.0.202102241146) ...
File: /etc/systemd/system/getty@.service.d/nottyreset.conf
Setting up univention-portal (4.0.5-53A~5.0.0.202105201144) ...
Installing new version of config file /etc/univention/registry.info/variables/univention-portal.cfg ...
Installing new version of config file /etc/univention/templates/files/etc/apache2/sites-available/univention-portal.conf ...
Installing new version of config file /etc/univention/templates/files/etc/apache2/ucs-sites.conf.d/univention-portal.conf ...
Installing new version of config file /etc/univention/templates/files/etc/logrotate.d/univention-portal ...
Installing new version of config file /etc/univention/templates/files/usr/share/univention-portal/apps.json ...
Installing new version of config file /etc/univention/templates/info/univention-portal.info ...
Installing new version of config file /etc/univention/templates/modules/univention_blog.py ...
Module: symlink_portal
File: /etc/apache2/ucs-sites.conf.d/univention-portal.conf
File: /etc/apache2/sites-available/univention-portal.conf
Module: kopano-cfg
File: /usr/lib/univention-portal/config/config.json
File: /usr/share/univention-portal/apps.json
Module: univention_blog
Adding blog entry failed: 3: unknown module portals/category.
Available Modules are:
appcenter/app
users/ldap
users/passwd
users/self
users/user
['univention-directory-manager', 'portals/category', 'modify', '--dn', 'cn=domain-admin,cn=category,cn=portals,cn=univention,dc=meraki,dc=intranet', '--ignore_not_exists', '--append', 'entries=cn=univentionblog,cn=entry,cn=portals,cn=univention,dc=meraki,dc=intranet']
File: /etc/logrotate.d/univention-portal
Linking /var/www/univention/portal to portal content...
Linking /var/www/univention/umc to portal content...
Calling joinscript 33univention-portal.inst ...
2022-09-09 15:03:30.182257410+05:30 (in joinscript_init)
A system update is currently being performed. The execution of the join script /usr/lib/univention-install/33univention-portal.inst is therefore postponed.
Joinscript 33univention-portal.inst finished with exitcode 1
Enabling site univention-portal.
To activate the new configuration, you need to run:
systemctl reload apache2
e[32m/usr/share/univention-portal/portals.json writtene[0m
Updating umc
Portal data untouched
Setting up univention-management-console-module-updater (15.0.3-64A~5.0.0.202105251258) ...
Calling joinscript 35univention-management-console-module-updater.inst ...
2022-09-09 15:05:03.002463667+05:30 (in joinscript_init)
Joinscript 35univention-management-console-module-updater.inst finished with exitcode 1
Module: kopano-cfg
Setting up univention-management-console-module-apps (9.0.2-45A~5.0.0.202105171344) ...
Installing new version of config file /etc/univention/templates/files/usr/share/univention-management-console/modules/apps.xml ...
Calling joinscript 36univention-management-console-module-apps.inst ...
2022-09-09 15:05:04.726610718+05:30 (in joinscript_init)
Joinscript 36univention-management-console-module-apps.inst finished with exitcode 1
Module: kopano-cfg
File: /usr/share/univention-management-console/i18n/de/apps.mo
File: /usr/share/univention-management-console/modules/apps.xml
Setting up univention-printserver (13.0.2-10A~5.0.0.202105111423) ...
Installing new version of config file /etc/univention/templates/files/etc/cups/cupsd.conf.d/01cupsd-base ...
Installing new version of config file /etc/univention/templates/files/etc/cups/cupsd.conf.d/02cups-access-limit ...
Installing new version of config file /etc/univention/templates/files/etc/logrotate.d/univention-printserver ...
Not updating cups/server
Not updating cups/admin
Setting cups/policy/default/JobPrivateAccess
Setting cups/policy/default/JobPrivateValues
Module: kopano-cfg
Multifile: /etc/cups/cupsd.conf
Setting security/packetfilter/package/univention-printserver/udp/631/all/en
File: /etc/security/packetfilter.d/10_univention-firewall_start.sh
Module: kopano-cfg
File: /etc/security/packetfilter.d/80_univention-firewall_policy.sh
Calling joinscript 79univention-printserver.inst ...
2022-09-09 15:05:17.477483690+05:30 (in joinscript_init)
A system update is currently being performed. The execution of the join script /usr/lib/univention-install/79univention-printserver.inst is therefore postponed.
Joinscript 79univention-printserver.inst finished with exitcode 1
File: /etc/cups/cups-files.conf
File: /etc/pam.d/cups
File: /etc/logrotate.d/univention-printserver
Restarting cups (via systemctl): cups.service.
Setting up univention-system-setup (13.0.3-29A~5.0.0.202105141118) ...
Installing new version of config file /etc/univention/templates/files/etc/logrotate.d/univention-system-setup ...
File: /etc/apache2/conf-available/univention-system-setup.conf
File: /usr/share/univention-management-console/modules/setup-certificate.xml
File: /etc/logrotate.d/univention-system-setup
Enabling conf univention-system-setup.
Setting up emacs-gtk (1:26.1+1-3.2+deb10u2) ...
update-alternatives: warning: alternative /usr/bin/emacs24-x (part of link group emacs) doesn't exist; removing from list of alternatives
update-alternatives: warning: /etc/alternatives/emacs is dangling; it will be updated with best choice
update-alternatives: using /usr/bin/emacs-gtk to provide /usr/bin/emacs (emacs) in auto mode
Install emacsen-common for emacs
emacsen-common: Handling install of emacsen flavor emacs
Install dictionaries-common for emacs
install/dictionaries-common: Byte-compiling for emacsen flavour emacs
Setting up emacs24 (1:26.1+1-3.2+deb10u2) ...
Setting up firefox-esr (78.10.0esr-1~deb10u1) ...
Setting up univention-directory-manager-rest (10.0.2-1A~5.0.0.202103241045) ...
Installing new version of config file /etc/univention/registry.info/variables/univention-directory-manager-rest.cfg ...
Installing new version of config file /etc/univention/service.info/services/univention-directory-manager-rest.cfg ...
Installing new version of config file /etc/univention/templates/files/etc/apache2/sites-available/univention-udm.conf ...
Installing new version of config file /etc/univention/templates/info/univention-directory-manager-rest.info ...
File: /etc/apache2/sites-available/univention-udm.conf
Site univention-udm already enabled
Calling joinscript 22univention-directory-manager-rest.inst ...
2022-09-09 15:05:22.728615652+05:30 (in joinscript_init)
Joinscript 22univention-directory-manager-rest.inst finished with exitcode 1
Setting up univention-management-console-module-setup (13.0.3-29A~5.0.0.202105141118) ...
Allowing use of questionable username.
The system user `__systemsetup__' already exists. Exiting.
loaded json file /var/cache/univention-management-console/acls/__systemsetup__
warning: rule setup/* already exists
warning: rule lib/server/* already exists
warning: rule sysinfo/* already exists
Not updating umc/web/appliance/fast_setup_mode
Calling joinscript 35univention-management-console-module-setup.inst ...
2022-09-09 15:05:24.551717028+05:30 (in joinscript_init)
Joinscript 35univention-management-console-module-setup.inst finished with exitcode 1
Module: kopano-cfg
Setting up univention-role-common (15.0.4-4A~5.0.0.202105111107) ...
Setting up univention-role-server-common (15.0.4-4A~5.0.0.202105111107) ...
Setting up univention-bind (14.0.1-2A~5.0.0.202104211309) ...
Installing new version of config file /etc/univention/registry.info/variables/univention-bind.cfg ...
Installing new version of config file /etc/univention/templates/files/etc/bind/named.conf.proxy ...
Installing new version of config file /etc/univention/templates/files/etc/bind/named.conf.samba4 ...
Installing new version of config file /etc/univention/templates/files/etc/systemd/system/bind9.service.d/10-configure-backend.conf ...
Installing new version of config file /etc/univention/templates/info/univention-bind.info ...
Installing new version of config file /etc/univention/templates/modules/systemctl_daemon-reload.py ...
Unsetting dns/master/port
Module: kopano-cfg
File: /etc/systemd/system/bind9.service.d/10-configure-backend.conf
File: /etc/bind/named.conf.proxy
File: /etc/network/if-up.d/bind9
File: /etc/network/if-down.d/bind9
File: /etc/bind/named.conf.samba4
Removing obsolete conffile /etc/univention/templates/files/etc/init.d/bind9 ...
Module: kopano-cfg
Not updating bind/autostart
Not updating dns/ipv6
Not updating nameserver/external
Not updating dns/allow/query
Not updating dns/allow/transfer
Not updating dns/dlz/debug/level
Not updating dns/debug/level
Calling joinscript 05univention-bind.inst ...
2022-09-09 15:05:33.313890569+05:30 (in joinscript_init)
Joinscript 05univention-bind.inst finished with exitcode 1
Calling joinscript 90univention-bind-post.inst ...
2022-09-09 15:05:33.421713968+05:30 (in joinscript_init)
Joinscript 90univention-bind-post.inst finished with exitcode 1
Processing triggers for sgml-base (1.29) ...
Setting up python-docutils (0.14+dfsg-4) ...
Setting up python-sphinx (1.8.4-1) ...
update-alternatives: using /usr/share/sphinx/scripts/python2/sphinx-apidoc to provide /usr/bin/sphinx-apidoc (sphinx-apidoc) in auto mode
update-alternatives: using /usr/share/sphinx/scripts/python2/sphinx-autogen to provide /usr/bin/sphinx-autogen (sphinx-autogen) in auto mode
update-alternatives: using /usr/share/sphinx/scripts/python2/sphinx-build to provide /usr/bin/sphinx-build (sphinx-build) in auto mode
update-alternatives: using /usr/share/sphinx/scripts/python2/sphinx-quickstart to provide /usr/bin/sphinx-quickstart (sphinx-quickstart) in auto mode
Setting up python3-docutils (0.14+dfsg-4) ...
Setting up python3-sphinx (1.8.4-1) ...
update-alternatives: using /usr/share/sphinx/scripts/python3/sphinx-apidoc to provide /usr/bin/sphinx-apidoc (sphinx-apidoc) in auto mode
update-alternatives: using /usr/share/sphinx/scripts/python3/sphinx-autogen to provide /usr/bin/sphinx-autogen (sphinx-autogen) in auto mode
update-alternatives: using /usr/share/sphinx/scripts/python3/sphinx-build to provide /usr/bin/sphinx-build (sphinx-build) in auto mode
update-alternatives: using /usr/share/sphinx/scripts/python3/sphinx-quickstart to provide /usr/bin/sphinx-quickstart (sphinx-quickstart) in auto mode
Setting up python3-repoze.who (2.2-3) ...
Setting up python3-pysaml2 (4.5.0-4+deb10u1A~5.0.0.202012081519) ...
Setting up univention-management-console-web-server (12.0.12-3A~5.0.0.202105141118) ...
Installing new version of config file /etc/univention/registry.info/variables/univention-management-console-web-server.cfg ...
Installing new version of config file /etc/univention/templates/files/etc/apache2/sites-available/univention.conf ...
Installing new version of config file /etc/univention/templates/info/univention-management-console-web-server.info ...
Installing new version of config file /etc/univention/templates/modules/setup_saml_sp.py ...
Module: kopano-cfg
File: /etc/apache2/sso-vhost.conf.d/01redirect.conf
File: /etc/apache2/sites-available/univention.conf
Module: setup_saml_sp
Try to download idp metadata (1/60)
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (6) Could not resolve host: ucs-sso.meraki.intranet
Try to download idp metadata (2/60)
Try to download idp metadata (3/60)
Try to download idp metadata (4/60)
Try to download idp metadata (5/60)
Try to download idp metadata (6/60)
Try to download idp metadata (7/60)
Try to download idp metadata (8/60)
Try to download idp metadata (9/60)
Try to download idp metadata (10/60)
Try to download idp metadata (60/60)
univention-management-console-web-server.service is not active, cannot reload.
Multifile: /etc/pam.d/univention-management-console
File: /etc/ldap/sasl2/slapd.conf
Could not download IDP metadata for https://ucs-sso.meraki.intranet/simplesamlphp/saml2/idp/metadata.php
Removing obsolete conffile /etc/univention/templates/files/etc/apache2/sites-available/univention-proxy.conf ...
Module wsgi already enabled
Module proxy already enabled
Considering dependency proxy for proxy_connect:
Module proxy_connect already enabled
Considering dependency proxy for proxy_http:
Module proxy_http already enabled
Module headers already enabled
Considering dependency proxy_balancer for lbmethod_bybusyness:
Considering dependency proxy for proxy_balancer:
Considering dependency alias for proxy_balancer:
Module alias already enabled
Considering dependency slotmem_shm for proxy_balancer:
Module slotmem_shm already enabled
Module proxy_balancer already enabled
Module lbmethod_bybusyness already enabled
Site univention already enabled
httpd (pid 26450) already running
Not updating umc/http/session/timeout
Not updating umc/http/response-timeout
Not updating umc/http/autostart
Not updating umc/http/port
Not updating umc/http/interface
Not updating umc/server/upload/min_free_space
Not updating umc/http/content-security-policy/default-src
Not updating umc/http/content-security-policy/script-src
Not updating umc/http/content-security-policy/object-src
Not updating umc/http/content-security-policy/style-src
Not updating umc/http/content-security-policy/img-src
Not updating umc/http/content-security-policy/media-src
Not updating umc/http/content-security-policy/frame-src
Not updating umc/http/content-security-policy/font-src
Not updating umc/http/content-security-policy/connect-src
Not updating umc/http/content-security-policy/form-action
Not updating umc/http/content-security-policy/frame-ancestors
Not updating umc/login/content-security-policy/frame-ancestors
Calling joinscript 92univention-management-console-web-server.inst ...
2022-09-09 15:06:43.233713623+05:30 (in joinscript_init)
Joinscript 92univention-management-console-web-server.inst finished with exitcode 1
Setting up univention-management-console (12.0.12-3A~5.0.0.202105141118) ...
Setting up univention-server-master (15.0.4-4A~5.0.0.202105111107) ...
Installing new version of config file /etc/univention/templates/files/etc/logrotate.d/univention-server-password-change ...
Setting ldap/server/name
Not updating ldap/server/port
Setting ldap/server/type
Not updating server/password/interval
Setting server/role
Not updating server/password/cron
File: /etc/default/ntpdate
File: /etc/systemd/system/univention-directory-listener.service.d/20_start_order.conf
File: /etc/ldap/ldap.conf
Multifile: /etc/postfix/ldap.external_aliases
Module: kopano-cfg
File: /etc/freeradius/3.0/mods-available/mschap
File: /etc/libnss-ldap.conf
File: /etc/init.d/slapd
Multifile: /etc/samba/smb.conf
Multifile: /etc/postfix/ldap.distlist
Multifile: /etc/postfix/ldap.transport
Multifile: /etc/postfix/ldap.canonicalrecipient
File: /etc/freeradius/3.0/mods-available/ldap
File: /etc/issue.net
File: /etc/cups/client.conf
Multifile: /etc/postfix/ldap.virtual
Multifile: /etc/postfix/ldap.virtual_mailbox
File: /etc/pam_ldap.conf
Multifile: /etc/postfix/ldap.groups
Multifile: /etc/postfix/ldap.sharedfolderlocal
Multifile: /etc/postfix/ldap.canonicalsender
Multifile: /etc/postfix/ldap.virtualwithcanonical
File: /etc/default/univention-directory-listener
Multifile: /etc/postfix/ldap.sharedfolderremote
File: /etc/cron.d/univention-system-stats
File: /etc/ntp.conf
File: /etc/welcome.msg
Multifile: /etc/postfix/ldap.sharedfolderlocal_aliases
Module: self-service-acl
Registering ACL in LDAP
Object exists: cn=ldapacl,cn=univention,dc=meraki,dc=intranet
INFO: No change of core data of object 64selfservice_userattributes.
Object modified: cn=64selfservice_userattributes,cn=ldapacl,cn=univention,dc=meraki,dc=intranet
Waiting for activation of the extension object 64selfservice_userattributes: ............................
Starting univention-upgrade. Current UCS version is 4.4-9 errata0
..........................ERROR
ERROR: Primary Directory Node did not mark the extension object active within 180 seconds.
ucs_registerLDAPExtension: registraton of /usr/share/univention-self-service/64selfservice_userattributes.acl failed.
Multifile: /etc/postfix/ldap.virtualdomains
File: /etc/cron.d/univention-delayed-account-activation
File: /etc/dhcp/dhcpd.conf
File: /etc/krb5.conf
File: /etc/postgresql/pam_ldap.conf
File: /etc/default/heimdal-kdc
File: /etc/freeradius/3.0/radiusd.conf
Multifile: /etc/postfix/ldap.saslusermapping
File: /etc/issue
File: /etc/pam.d/smtp
File: /etc/freeradius/3.0/mods-available/eap
dpkg-query: no packages found matching univention-ox-directory-integration
File: /etc/logrotate.d/univention-server-password-change
File: /etc/cron.d/univention-server-master
Processing triggers for ca-certificates (20200601~deb10u2) ...
Updating certificates in /etc/ssl/certs...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
Processing triggers for dictionaries-common (1.28.1) ...
aspell-autobuildhash: processing: en [en-common].
Processing triggers for initramfs-tools (0.133+deb10u1) ...
Processing triggers for libc-bin (2.28-10) ...
Processing triggers for systemd (241-7~deb10u7A~5.0.0.202104091504) ...
Processing triggers for libapache2-mod-php7.3 (7.3.27-1~deb10u1) ...
Processing triggers for univention-config (15.0.7-8A~5.0.0.202103170934) ...
dpkg-query: no packages found matching ldapacl_66univention-ldap-server_acl-master-uvmm.acl
dpkg-query: no packages found matching ldapacl_66univention-radius.acl
dpkg-query: no packages found matching ldapacl_59univention-radius.acl
dpkg-query: no packages found matching ldapacl_66univention-appcenter_app.acl
Processing triggers for libgdk-pixbuf2.0-0:amd64 (2.38.1+dfsg-1) ...
Errors were encountered while processing:
univention-dhcp
Error: Failed to execute "apt-get -o DPkg::Options::=--force-confold -o DPkg::Options::=--force-overwrite -o DPkg::Options::=--force-overwrite-dir --trivial-only=no --assume-yes --quiet=1 -u dist-upgrade"
