A system does not boot and seems to freeze at bootsplash.
It is possbile to edit the boot options for the UCS system within GRUB. You can disable the splashscreen and raise the loglevel - by that you can see what happens when the system freezes:
- Press button “e” in GRUB bootloader
- Find the follwing line:
linux ... /vmlinuz-... ... ro quiet loglevel=0 rootdelay=5 splash - Edit the line: Remove
quietand changeslpashtonosplash- also setloglevelto5
the line should now look like this:
linux ... /vmlinuz-... ... ro loglevel=5 nosplash - Boot by pressing F10
These changes are temporaliy and are re-set at next boot. You can make that change permanent by booting into the working UCS system, logging in as root, and setting the following UCR variables:
ucr set grub/bootsplash=nosplash grub/quiet=no grub/loglevel=5
Advanced options:
The default text console only has 80 columns and 25 rows, so some important output might scroll of. You can configure a serial console to capture that output.
Many USB serial converters don’t work reliably.
Many high-end servers support serial console re-direction over network, for example over IPMI. See How to do remote server administration over IPMI
Many virtual machines provide virtual serial interfaces, which can also be used:
For Qemu/KVM/Xen-HVM
adding a<console/> or <serial/>element to the VM definition and usettyS0 -
Xen-PV
Usehvc0as the serial device name .
The console can be accessed by running
virsh console "\$VM"
As an alternative the output can be logged into a file on the host by using something like
<serial type='file'>source path='/tmp/$VM.log' append='on'/></serial>
in the VM definition. The virsh conole-command must be kept running as otherwise all output is lost.
- Configuring the boot-loader GRUB to use a serial console is described in How to configure grub serial access.
- The Linux kernel can also be instructed to redirect its output to a serial console:
ucr set grub/append='console=tty0 console=ttyS0,115200,8,N,1'
This makes the serial console the default console (/dev/console), as ttyS0 is given last. By moving console=tty0 to the end, the VGA console will remain the main console. - Start a login getty on the serial console:
- Before UCS-4.2 with SysV-init
sed -i -re '/^#?T0:/s/#//' /etc/inittab;telinit Q - Since UCS-4.2 with systemd
systemctl enable getty@ttyS0.service;systemctl start getty@ttyS0.service
