We’re using UCS@school together with the Nextcloud app. Everything works fine except for one point. The Nextcloud sync app (on Windows) shows its URL without a trailing slash, i.e. “https://my.domain.com/nextcloud”. Additionally this behaviour doesn’t change when inputting the server address with a trailing slash while configuring an account to use with the Nextcloud app.
If you then click on this URL you’ll get a 404 from Apache. Only if you append the trailing slash to the URL the Nextcloud website is shown.
What’s the Univention way to amend the UCS Apache config to treat a hit on “/nextcloud” the same as a hit on “/nextcloud/”?
So I fixed the linking error and I can access nextcloud from ucs but the fix above still does not work, meaning when you go to the domain assigned to ucs it still goes to ucs portal not directly to nextcloud
