Letsencrypt Certificate REnewal ISRG Rootx1
After the Let’s Encrypt Root Expiry at the 30th of Sept. “Change from DST Root CA X3 to IRSG Root X1”, my UCS Server has a SSL Certificate failure and the described solution in SSL Renewal didn’t help, in the contrary I got more errors after applying the solution.
Can anyone help
This has solved my problem.
Mastodon
