I’m new to UCS so my apologies for a question that may have been answered already (I looked online for hours at at this point).
I installed the lets encrypt plugin but seem to have issues getting a certificate.
I’m running OPNSense which has a Port Forward rule to allow TCP 80 traffic to my UCS server.
I’m using Cloudflare to route DNS traffic to my Public IP.
When running the Lets Encrypt script from the Web Gui I’m receiving an error
Hi Steven,
As stated it is a firewall problem. Are you able to open http://mydomain.com/.well-known/acme-challenge/ from public?
You need to have open http port.
If applicable check your geo location configuration on your firewall.
Check your firewall logs…
If https://domain.com is working, then just double check all your settings that relate to the port 443 on cloudflare and your firewall/router and make sure you also have opened/forwarded/have duplicated port 80 in all those places as well. It should work. If it doesn’t then there is something else involved in the equation that I am missing from the information included in your posts.
A record for my domain that points to my public IP address
Type: A
Content: xxx.xxx.xxx.xxx (Public IP address of my router OPNSense)
OPNSense:
NAT Port forward Rule on WAN that allows HTTP/HTTPS traffic from anywhere to my UCS server
Interface: WAN
TCP/IP Version: IPV4
Protocol: TCP/UDP
Source: ANY
Source port range: ANY
Destination: WAN Address
Destination port range: HTTP TO HTTPS
Redirect target IP: xxx.xxx.xxx.xxx (UCS internal Server IP)
Redirect target port: HTTP
Proxmox:
No Firewall rules on the VM
Like i mentioned i’m able to access the UCS WebGUI externally (tested via VPN).
However it looks like the http://domain.com/.well-known/acme-challenge/ does not work.
I’m not sure if I have to add another record to Cloudlfare or on my UCS server.
I’m using ACME on OPNSense and have no problems getting Certs.
One thing to note is that I use DNS-Challenges not HTTP-01. So it looks like something is not configured correctly for HTTP-01 challenges. If you have more insight into HTTP-01 challenges that would help.
Sounds like an OPNSense config issue. Port range of http to https doesn’t make sense to me, although I don’t know that it is the issue. I would not want to blanket forward 80-443. Regardless, make sure to double check both NAT and Firewall rules in OPNSense. IIRC they can be out of sync depending on how things are setup.
Also, it’s been a while since I ran ACME on OPNSense, but I would test with it off just to make sure there is no conflict there.
The most likely issue is that something is using port 80 on the OPNSense install.
I used to run OPNSense with UCS behind it along with a second webserver. I ran haproxy on OPNSense as well. Not being able to schedule NAT rule changes so my Let’s Encrypt clients could all update their certs at different times is the only reason I moved off it. Overall I liked it quite a bit, but that one issue really got old having to manually manipulate the NAT rules to renew certs every few months.
I looked at all my NAT/WAN rules again and cannot find the issue.
No matter how I adjust the rules I can only get to the webgui via HTTP.
For some reason OPNSense won’t let me open Port 80.
I disabled all my plugins just to make sure nothing is running on Port 80 but no luck.
When you say you can only get to the webgui via http, do you mean the opnsense web gui?
If so then you might need to change that port to something else first. I think it might also be possible to insert a NAT rule higher in the rules list to redirect the port first, but it’s been a while since I’ve used it, and that might not be the case any more. I do remember being surprised that I could get my setup working the way I did, just needing to toggle one NAT rule on and off when renewing a cert. I know it took me a bit of trial and error to get it that way though.
Thank you for your reply, my port is on a different port already
I’m able to connect to all my services via HTTPS from outside my network but for some reason I’m not able to get port 80 to work.
I turned of Caddy off just to make sure I’m not hogging port 80 but no luck.
Would anyone know how to install the lets encrypt certificates manually?
I can just grab them from OPNSense and upload them to my UCS server right?
You can use the certificate fom your sense. Inside the acme client / automation you can copy the certificate with sftp to your server, but you have to use the right ssh key, he is inside /var/etc/acme-client/sftp-config/
and here is a helpful script so copy the key to your server
I didn’t realize there was a Caddy plugin for OPNSense. It wasn’t available last time I used it. I see in the docs there appears to be support for redirecting Let’s Encrypt to internal servers. Did you check the docs here?
So it turns out my ISP is blocking port 80 and there’s nothing I can do to open it, which is quite the bummer. @Kevo, I already setup Caddy to forward HTTP-01 challenges I found the same guide . But still without port 80 no go. Unfortunately I have to do this one manually for now until UCS adds DNS challenge support.
Would you guys know which certificates are needed?
I copied over the private.key and cert.pem from OPNSense location:
/var/etc/acme-client/keys/private.key
/var/etc/acme-client/certs/cert.pem
To UCS location:
/etc/univention/letsencrypt/cert.pem
/etc/univention/letsencrypt/private.key
And updated the config files for postfix and dovecot.
But I’m still getting a certificate error when setting up Thunderbird.
I just wanted to say I really appreciate the help here, I’m not well versed when it comes to certificates yet.
I did that I used the ucs set command to update the dovecot and postfix config files.
But it looks like I’m importing the wrong certificates.
When trying to setup a mail account in Thunderbird I’m still getting an error that the cert is not trusted.
Looking at the cert it’s still the self signed one that UCS created.
Would you happen to know if I’m missing something?
Hi
I don´t know Caddy, but if you read the post from Pixel and if you use the way via sftp copy from your sense, you will get the right certificate. I do this in this way and it works perfekt. The sftp copy from the automation inside the acme client will copy the right certificate to your server. Try this way
I tried with a test account here. Thunderbird does something seemingly strange in the background. When setting up the account, right after successfully creating the account, Thunderbird connects to a domain controller, which is possibly different than the mailserver. There I get a request to manually permit a wrong certificate.
The certificates from postfix and dovecot seem okay in my test.
Yes that seems to be the issue, it keeps pulling the self signed certificate from the domain controller itself, not the sense certs installed specifically for dovecote and postfix. Would it be possible to replace the initial certs created by univention and use them for the mail server?
Also there are a lot of different certificate types: .pem, .cert, .key.
Which ones are needed?
If someone would have more knowledge about how to manage certificates on Linux that would help.
I’m at the end of my knowledge at this point.
As a side note, I set up a brand new server with only certbot installed and installed the certificates I got from Lets Encrypt but it’s still the same problem. It keeps pulling the default self signed certificates from the UCS Domain Controller.
