Let's encrypt issues
The bigger question for me is: what is Thunderbird requesting on the domain controller? I was not able to find out so far.
Plus, the request is made for domain, not a specific server, e.g. domain.example (without any servername). I am not even sure it is possible to request such a certificate from letsencrypt.
Hi @riess82,
Yes that seems very strange, I’m still looking for a solution to replace the Domain Controller Certificates.
Just didn’t have a lot of time the past 4 days.
Ok, I found a solution,
I set up a separate VM with certbot installed and requested new certificates for my domain.
This assumes that you have a DNS record publicly set up. I use Cloudflare for this.
On Debian/Ubuntu system use:
sudo apt install certbot
Then request the certificates for you domain (example.com << use your domain here)
sudo certbot --manual --preferred-challenges dns certonly -d example.com
Follow the instructions. Make sure to create a new TXT record in Cloudflare when prompted during the certbot request:
_acme-challenge.example.com
The new certificates can be found in the
/etc/letsencrypt/archive/example.com/cert1.pem
/etc/letsencrypt/archive/example.com/chain1.pem
/etc/letsencrypt/archive/example.com/fullchain1.pem
/etc/letsencrypt/archive/example.com/privkey1.pem
I copied the fullchain1.pem and privkey1.pem to a custom directory I created on my Univention server:
/etc/myssl/fullchain1.pem
/etc/myssl/privkey1.pem
Please note that the certificates will be renewed automatically but not copied to the Univention server. Perhaps a script can automate this process. Should I find a solution then I will update this post. If someone else has a better solution or a script please feel free to post it here :slight_smile:
With the certificates in place I followed this forum post:
Ensure you change the name of your certificate if needed.
Dovecot
Dovecot is the default IMAP server since UCS 4.0-2 and supersedes Cyrus.
The UCR variables mail/dovecot/ssl/certificate and mail/dovecot/ssl/key must be set for Dovecot:
ucr set mail/dovecot/ssl/certificate="/etc/myssl/fullchain1.pem"
ucr set mail/dovecot/ssl/key="/etc/myssl/privkey1.pem"
Then restart the daemon:
service dovecot restart
Postfix:
The UCR variables mail/postfix/ssl/certificate and mail/postfix/ssl/key need to be configured:
ucr set mail/postfix/ssl/certificate="/etc/myssl/fullchain1.pem"
ucr set mail/postfix/ssl/key="/etc/myssl/privkey1.pem"
Then the mail server has to be restarted:
service postfix restart
I want to thank everyone for your help and I hope this guide helps others which are in the same situation where http-01 challenges are not an option.
I hope Univention will add DNS challenges in the future.
