bei mir sieht es so aus:
root@ucs:~# netstat -tulpen | grep gateway
root@ucs:~# netstat -tulpen | grep master
tcp 0 0 0.0.0.0:465 0.0.0.0:* LISTEN 0 93729 16744/master
tcp 0 0 0.0.0.0:25 0.0.0.0:* LISTEN 0 93726 16744/master
tcp 0 0 127.0.0.1:10025 0.0.0.0:* LISTEN 0 100851 16744/master
tcp 0 0 0.0.0.0:587 0.0.0.0:* LISTEN 0 93732 16744/master
root@ucs:~#
Auf “gateway” trifft nichts bei mir nichts zu.
Die Log unter /var/log/kopano/gateway.log sieht wie folgt aus:
Thu Nov 16 17:34:20 2017: [ notice] [14311] Starting kopano-gateway version 8,3,1,35 (35), pid 14311
Thu Nov 16 17:36:07 2017: [ notice] [14311] POP3/IMAP Gateway will now exit
Thu Nov 16 17:36:07 2017: [ notice] [16948] Starting kopano-gateway version 8,3,1,35 (35), pid 16948
Thu Nov 16 18:03:05 2017: [error ] [31026] Client disconnected
Thu Nov 16 18:03:34 2017: [error ] [31031] Client disconnected
Thu Nov 16 18:03:35 2017: [error ] [31032] Client disconnected
Thu Nov 16 18:03:36 2017: [error ] [31033] Client disconnected
Thu Nov 16 18:04:06 2017: [error ] [31040] Client disconnected
Thu Nov 16 18:04:07 2017: [error ] [31041] Client disconnected
Thu Nov 16 18:04:07 2017: [error ] [31042] Client disconnected
Thu Nov 16 18:04:08 2017: [error ] [31043] Client disconnected
Thu Nov 16 18:04:08 2017: [error ] [31044] Client disconnected
Thu Nov 16 18:04:15 2017: [error ] [31045] Client disconnected
Thu Nov 16 18:04:30 2017: [error ] [31049] Client disconnected
Thu Nov 16 19:00:30 2017: [warning] [31052] Unable to create ical object, sending as TNEF
Thu Nov 16 19:05:32 2017: [warning] Previous message logged 2 times
Thu Nov 16 19:05:32 2017: [warning] [ 1840] Unable to create ical object, sending as TNEF
Thu Nov 16 19:08:16 2017: [error ] [31052] Failed to read line: Connection reset by peer
Thu Nov 16 19:20:19 2017: [error ] [ 2944] Client disconnected
Thu Nov 16 19:20:21 2017: [error ] [ 2946] Client disconnected
Thu Nov 16 19:20:21 2017: [error ] [ 2947] Client disconnected
Thu Nov 16 19:20:25 2017: [error ] [ 2948] Client disconnected
Thu Nov 16 19:20:26 2017: [error ] [ 2949] Client disconnected
Thu Nov 16 19:20:26 2017: [error ] [ 2950] Client disconnected
Thu Nov 16 19:20:27 2017: [error ] [ 2951] Client disconnected
Thu Nov 16 19:20:32 2017: [error ] [ 2952] Client disconnected
Thu Nov 16 19:20:33 2017: [error ] [ 2953] Client disconnected
Thu Nov 16 19:20:34 2017: [error ] [ 2954] Client disconnected
Thu Nov 16 19:20:34 2017: [error ] [ 2955] Client disconnected
Thu Nov 16 19:20:35 2017: [error ] [ 2956] Client disconnected
Thu Nov 16 19:20:36 2017: [error ] [ 2957] Client disconnected
Thu Nov 16 19:21:37 2017: [error ] [ 2988] Client disconnected
Thu Nov 16 19:21:38 2017: [error ] [ 2989] Client disconnected
Thu Nov 16 19:21:39 2017: [error ] [ 2990] Client disconnected
Thu Nov 16 19:21:52 2017: [error ] [ 2991] Client disconnected
Thu Nov 16 19:38:20 2017: [error ] [ 1884] Connection closed because of timeout
Thu Nov 16 19:38:27 2017: [error ] [ 1889] Connection closed because of timeout
Thu Nov 16 19:46:17 2017: [error ] [ 1891] Connection closed because of timeout
Thu Nov 16 20:15:45 2017: [error ] [ 5133] Client disconnected
Thu Nov 16 20:15:47 2017: [error ] [ 5136] Client disconnected
