IPP Printer on UCS 5
Hi@all,
I am having problems connecting a Kyocera network printer under UCS 5.0.1. I have initially configured the device as an IP client. It has:
Hostname: m5526cdw
IP: 192.168.83.35
and is reachable under it. I copied the PPD file from Kyocera to the directory on the server:
root ✗ srv01:/usr/share/ppd ls -l
insgesamt 60
drwxr-xr-x 2 root root     4096 Feb 15 22:52 cupsfilters
drwxrwsr-t 2 root lpadmin  4096 Mär 11 10:15 custom
drwxr-xr-x 3 root root     4096 Feb 15 22:52 hplip
drwxr-xr-x 3 root root     4096 Feb 15 22:52 hp-ppd
-rw-r--r-- 1 root root    42529 Feb 28 14:02 Kyocera-ECOSYS_M5526cdw.ppd
And via the LDAP container → univention → cups → Kyocera added the corresponding entry:
Then created the printer in the UMC.
Windows Name: M5526cdw
Print server: srv01.example.com
Protocol: ipp://
Destination: 192.168.83.35/ipp/lp
Manufacturer: Kyocera
Printer model: Kyocera M5526cdw
I tried first with socket://192.168.83.35:9100 and since this did not work with ipp://
Now when I try to print a test page in the Cups web interface (https://hostname:631) nothing happens.
When I restart the CUPSD on the server I find some messages in the logfile. Among other things also one which refers to the first attempt with socket://.
Mär 11 11:50:19 srv01 systemd[1]: Stopping Make remote CUPS printers available locally...
Mär 11 11:50:29 srv01 CRON[3275]: pam_unix(cron:session): session closed for user root
Mär 11 11:50:30 srv01 systemd[1]: cups-browsed.service: Succeeded.
Mär 11 11:50:30 srv01 systemd[1]: Stopped Make remote CUPS printers available locally.
Mär 11 11:50:30 srv01 systemd[1]: Stopping CUPS Scheduler...
Mär 11 11:50:30 srv01 systemd[1]: cups.service: Succeeded.
Mär 11 11:50:30 srv01 systemd[1]: Stopped CUPS Scheduler.
Mär 11 11:50:30 srv01 systemd[1]: cups.socket: Succeeded.
Mär 11 11:50:30 srv01 systemd[1]: Closed CUPS Scheduler.
Mär 11 11:50:30 srv01 systemd[1]: Listening on CUPS Scheduler.
Mär 11 11:50:30 srv01 systemd[1]: cups.path: Succeeded.
Mär 11 11:50:30 srv01 systemd[1]: Started CUPS Scheduler.
Mär 11 11:50:30 srv01 systemd[1]: Starting CUPS Scheduler...
Mär 11 11:50:30 srv01 univention-cups-init[3368]: execute /var/cache/univention-printserver/1646992259.823827.sh
Mär 11 11:50:30 srv01 colord[1172]: failed to get session [pid 3367]: Keine Daten verfügbar
Mär 11 11:50:30 srv01 univention-cups-init[3368]: lpadmin: Ungültige Geräte-URI"socket://socket://192.168.83.35:9100".
Mär 11 11:50:30 srv01 univention-cups-init[3368]: The command "/usr/sbin/lpadmin -u allow:all -o auth-info-required=none -p M5526cdw -v socket://socket://192.168.83.35:9100 -E -h localhost" returned 1
Mär 11 11:50:30 srv01 systemd[1]: Started Make remote CUPS printers available locally.
Does anyone have a tip for me on how to connect the printer?
with best
sven
I also tried with the URI: ipp://192.168.83.35/printers/m5526cdw. But the messages remain the same. In the logfile it still says that it tries to socket:// ..... :9100 to connect. In the Cups WebUI:
“The printer configuration is incorrect or the printer no longer exists.”
Hi @pixel
Unfortunately, I don’t have a solution for your question, but I will join this thread as we probably we could do with an intervention from UCS :slight_smile:.
The subject of printing in UCS has been mentioned on many occasions, with no proper resolution. It looks as if people are finding ways to make their printers to work, but it is very inconsistent.
@system
I spent a few “minutes” reading about the CUPS project which, with version 3, plans to turn towards IPP Everywhere printing (only).
There seems to be some difference between UCS 5.0 and CUPS 2.2 configuration where not all the generic drivers are listed nor accepted. CUPS has many generic drivers available (including IPP Everywhere):
The USC printer GUI shows/accepts only selection of them:
I wonder, could syncing the drivers from CUPS to USC resolve printing issues? From what I know, most printers accept ipp:// protocol in which case we could almost lose all the bespoke vendor drivers listed in LDAP.
Noted that the UCS 5.2 has updated CUPS to 2.4.2… which could change things too.
We integratet an older kyocera fs 3920dn
We enabled “ipp” in the webinterface of the printer.
Printing only worked after setting “socket” and not “ipp”
