Hello, everyone,
I’m trying to install UCS 4.4 on my hardware. However, the installation interface is not displayed, but the grub console with the message is displayed directly:
"Minimal BASH-like line editing is supported. For the first word, TAB lists possible command completions. Anywhere else TAB lists possible device or file completions.
I tried DVD as well, with the same issue. I burned it on Kubuntu with the included tool K3b. Should I try another burning tool?
To create the USB Stick I tried dd and the so called start up disk creator under kubuntu and the windows tools unetbootin, rufus, Win32DiskImager, Universal-USB-Installer, all with the same issue.
I installed UCS as VM using VirtualBox, the installation runs as expected without problems.
just for clearance: You are getting the Grub prompt when booting? Or after installation went fine an re-booting?
It this is a VM just attach the ISO to the VM and boot from there- no need to burn it physically.
I stumbled across some other posts and bug reports describing this issue. It seems I’m not the only one having this one, is there any solution already?
thanks for your feedback.
By now I dont think it’s a hardware problem in my case. Successfully I installed ubuntu server, CentOS, even Debian wasn’t a problem. I suspect a component used by UCS to be the origin of the cause.
Right, the problem is UCS, in that I wasn’t able to do a UEFI install. Like you, I was able to successfully install Ubuntu on the Beelink. I had to work around the bug by buying new hardware that supported non-UEFI installation.
