Everything was OK for me to upgrade to 5.2 except keycloak, I just need it for nextcloud, bur anyway,
I installed Keycloak for compatibility to upgrade to 5.2 but the install failed and I have lose the web interface, because apache2.service do not start because of a missing certificate.
I tried to generate the missing certificate with this
univention-certificate new -name ucs-sso-ng.domain.pf
Now I’m stuck
the /var/log/apache2/error.log says
[Thu Mar 06 10:05:19.805750 2025] [ssl:emerg] [pid 1356] AH02572: Failed to configure at least one certificate and key for ucs-sso-ng.domain.pf:443
[Thu Mar 06 10:05:19.810768 2025] [ssl:emerg] [pid 1356] SSL Library Error: error:140A80B1:SSL routines:SSL_CTX_check_private_key:no certificate assigned
[Thu Mar 06 10:05:19.810810 2025] [ssl:emerg] [pid 1356] AH02312: Fatal error initialising mod_ssl, exiting.
AH00016: Configuration Failed
I did a Rollback anyway.
every times I install Keycloak, I can not log in as admin on ucs-sso-ng.domain/admin
is there a password reset, or what am I missing ?
for my part, Yes I did (follow either of the guides). but there is always something that do not work in the process, and I am not sure it’s on my side…
I have same issue. Also after i maualy uninstall keycloak form cli i can not start apache, there is an issue with the cert form a lingering apache config. so when i remove the keycloke apache config it works
I am working on a testinstall winth only one server, using the letencrypy for certs.
My question is should i setup a domain for keycloak woth certs?
