Implementing DKIM in UCS does not work
Hello everyone,
I have tried to implement DKIM in my mail server (for neukamp.de) according to the detailed instructions:
https://help.univention.com/t/how-to-kopano-ucs-4-4-latest-install-dkim-support/11725
I use UCS V 8.09 / Kopano Version 5.0-5.
If I test the implementation with:
opendkim-testkey -d neukamp.de -s mail -vvv
everything seems to work:
opendkim-testkey: using default configfile /etc/opendkim.conf
opendkim-testkey: checking key ‘mail._domainkey.neukamp.de’
opendkim-testkey: key not secure
opendkim-testkey: key OK
In postfix main.cf the required options are also set:
milter_default_action = accept
milter_protocol = 6
smtpd_milters = inet:localhost:12301
non_smtpd_milters = inet:localhost:12301
I have also entered the public DKIM key on my DNS server, the test on “Check a DKIM Core Key” showed: “This is a valid DKIM key record”
I completely restarted the server, so everything seems to be ok.
But when I test my implementation on
https://dkimvalidator.com/
I get the information that my mail does not contain a DKIM key:
DKIM Information:
DKIM Signature
This message does not contain a DKIM Signature
I checked everything multiple times and can’t find an error. What am I doing wrong, have I forgotten something?
I would be very grateful for any tips on how to proceed.
Best regards,
Gerd-Uwe
Hello everyone,
I have just been able to solve the problem by myself. In the instructions on:
the DKIM configuration in the file “/etc/default/opendkim” is edited. This does not work in my case. However, if I copy the entries there into the file “/etc/default/opendkim”, it now works.
