How-to: Create own directory reports
How to Create own directory reports
Environment
  1. UCS 4.4-x (should work also on lower & higher(UCS5.0) versions)
Preparing
Step 1: Create a directory for own report templates
root@ucs:~# mkdir /etc/univention/directory/reports/custom/
Step 2: Create a template file
root@ucs:~# vi /etc/univention/directory/reports/custom/expire.csv
You could use subfolder de_DE or en_US if you want to create mutlilingual versions of the report.
In the header you can write anything you want; it should describe the column. You can define the seperator; I use a semicolon, you can use TAB or comma.
The attributes must match the udm property name. Here is an example:
<@header@>
User name;Last name;First name;Password expiry date
<@/header@>
<@attribute name="username"@>;<@attribute name="lastname"@>;<@attribute name="firstname"@>;<@attribute name="passwordexpiry" default="Not set"@>
<@footer@>
<@/footer@>
Step 3: Define the configuration via UCR variable
root@ucs:~# ucr set directory/reports/templates/csv/userexpire='users/user "EXPIRE" /etc/univention/directory/reports/custom/expire.csv'
Important: The name (here EXPIRE) must be unique.
Step 3: Run the report via command line
This command will generate a report of all Users in the domain:
root@ucs:~# univention-directory-reports -m users/user -r "EXPIRE" $(udm users/user list | sed -ne 's/^DN: //p')
You can also run it via Webinterface UMC → Users → User → Select users → more → create report → choose Report (in this example EXPIRE)
Have fun with your own reports.
Thanks to Moritz_Bunkus who explained that in this help discussion (german language):
