Display settings
Hi all. I downloaded and installed UCS in VirtualBox, because it seems very promising. I have come across an issue however. I do not seem to be able to change the screen resulution in the settings menu. Whenever I click on the “default” item for screen settings, nothing happens.
Any help is appreciated.
Greetings,
Richard
though I am doing all UCS-tests on Virtualbox I never tried to use the X-Windows on the system directly on the server during the last years.
Your problem might be related to the missing GuestAdditions. On other systems one would probably try to “insert Guest additions” and run the installer. This needs some preparation on UCS, see UCS 4.1 als VirtualBox Guest: VBoxLinuxAdditions hinzufügen (german) and the generic advisory from https://virtualboxes.org/doc/installing-guest-additions-on-debian/.
Best Regards,
Dirk
