Configuring the Exam Cleanup Script to Target Only Running Exams
We configured the cleanup cron job as described in the following link: Problem: Students Hang in Exam Mode.
The cleanup script currently removes all exams, not just the running ones. Are there any options to configure the script to clean only the running exams?
Kind regards
Howdy, the help of these two scripts only present this options:
usage: exam-and-room-cleanup [-h] [-n] [-d] [--skip-exam-shutdown]
                             [--skip-exam-user-removal]
                             [--skip-exam-computer-removal]
                             [--skip-ucr-cleanup] [--skip-exam-cleanup]
                             [--skip-room-cleanup]
This script stops currently running exams and purges all remaining settings
for exams and computer rooms. WARNING: if a running exam cannot be shutdown
cleanly, data in the home directory may be lost. This script redirects all
output to /var/log/univention/ucs-school-exam-cleanup.log.
optional arguments:
  -h, --help            show this help message and exit
  -n, --dry-run         do not change anything
  -d, --debug           write additional debug output to logfile
  --skip-exam-shutdown  do not try to shutdown running exams gracefully
                        do not remove all existing exam users (only on Primary
                        Directory Node / Backup Directory Node)
                        do not remove all existing exam computers (only on
                        Primary Directory Node / Backup Directory Node)
  --skip-ucr-cleanup    do not purge exam/room related UCR variables
  --skip-exam-cleanup   do not purge exam data/metadata files
  --skip-room-cleanup   do not purge room metadata files
So the opposite is possible. Keep actual running.
