Hi Bernd,
many thanks.
Here’s the output of ‘ucr search --brief jitsi’:
apache2/vhosts/jitsi.univention.myserver.org/443/aliases:
apache2/vhosts/jitsi.univention.myserver.org/443/enabled: true
apache2/vhosts/jitsi.univention.myserver.org/443/files: /var/lib/univention-appcenter/apps/jitsimeet/config/vhost.conf
apache2/vhosts/jitsi.univention.myserver.org/443/ssl/ca: /etc/univention/ssl/ucsCA/CAcert.pem
apache2/vhosts/jitsi.univention.myserver.org/443/ssl/certificate: /etc/univention/ssl/*.univention.myserver.org/cert.pem
apache2/vhosts/jitsi.univention.myserver.org/443/ssl/key: /etc/univention/ssl/*.univention.myserver.org/private.key
appcenter/apps/jitsimeet/container: 69428d8f34f8a68d405bda6c5a88f8d43c70aa711a2252c6217c297a7f3532ed
appcenter/apps/jitsimeet/hostdn: cn=jitsi-08555794,cn=memberserver,cn=computers,dc=myserver,dc=org
appcenter/apps/jitsimeet/ports/10000: 10000
appcenter/apps/jitsimeet/ports/4443: 4443
appcenter/apps/jitsimeet/status: installed
appcenter/apps/jitsimeet/ucs: 4.4
appcenter/apps/jitsimeet/version: stable-6726-2
jitsimeet/autostart: yes
jitsimeet/docker/host/address: 192.168.115.119
jitsimeet/enable/auth: false
jitsimeet/enable/guests: true
jitsimeet/ldap/filter: (&(uid=%u)(jitsimeetActivated=TRUE))
security/packetfilter/package/jitsimeet/tcp/10000/all/en: for RTP media over UDP
security/packetfilter/package/jitsimeet/tcp/10000/all: ACCEPT
security/packetfilter/package/jitsimeet/tcp/4443/all/en: for RTP media over TCP
security/packetfilter/package/jitsimeet/tcp/4443/all: ACCEPT
security/packetfilter/package/jitsimeet/udp/10000/all/en: for RTP media over UDP
security/packetfilter/package/jitsimeet/udp/10000/all: ACCEPT
Any hint? I’m not an expert as you can imagine…
