Bind forgets to forward
i have something crazy, i dont get what is the reason…
my local dns server 192.168.200.2 should forward all not known entrys to 192.168.62.1, so i set it as forwarder…
it works without any problems BUT after sometime it dont forward any more… after a restart of the bind service it works again:
grafik
what the hell could cause this issue?
Thx!
Erik
sounds indeed weird. I guess replication got stuck for some reason. Check here.
And/ or check your DNS/Bind log entries. Be aware when using LDAP as backend there is a second bind-process running!
My recommendation is to use the Samba backend on all UCS using Samba and only change to LDAP where Samba is not installed!
/KNEBB
hey,
we still have this issue… we have a currently a workaround that we restart ucs dns server every 30 minutes… quiet stupid i know.
i also set dns loglevel to 11, have massive logs… but nothing that could explain why it stopped forwarding request for a specifc domain…
and of course we use every where samba backend.
maybe you have a other idea?
thank you very much!
Mastodon
