Zarafa Upgrade 7.2 -> Zarafa entfernt
habe vorhin das Upgrade von Zarafa 7.1.x auf das aktuelle Zarafa 7.2.x durchgeführt. Auf der Konsole erschien kein Fehler, jedoch ist Zarafa jetzt komplett vom Server deinstalliert worden, nur noch die configs und DB ist vorhanden, ansonsten ist Zarafa komplett weg.
Hier der Auszug aus /var/log/univention/updater.log:
[code]UCS Version is ‘4.1’
Downloading “https://appcenter.software-univention.de/meta-inf/4.1/index.json.gz”…
… Not Modified
Downloading “https://appcenter.software-univention.de/meta-inf/4.1/index.json.gz.gpg”…
… Not Modified
Downloading “https://appcenter.software-univention.de/meta-inf/categories.ini”…
… Not Modified
Downloading “https://appcenter.software-univention.de/meta-inf/rating.ini”…
… Not Modified
Downloading “https://appcenter.software-univention.de/meta-inf/license_types.ini”…
… Not Modified
0 file(s) are new
100
Checking openvpn4ucs=1.1.8
100
100
Calling upgrade
0
Going to upgrade Zarafa Collaboration Platform (7.2.1-51838)
Calling prescript (preinst)
/var/cache/univention-appcenter/zarafa_20160222.preinst does not exist
Calling elinks -dump /var/cache/univention-appcenter/zarafa_20160222.README_UPDATE
See the [1]Zarafa 7.2 Changelog for more details about changes in this
Zarafa release.
                    Zarafa 7.2.1-51838 Update Notes
 * Zarafa4UCS has been updated to Zarafa 7.2 (version of integration
   package is now 7.2.1000)
 * Due to this major upgrade you also need to convert your subscription
   key. This can be done in the [2]Zarafa Portal. For more information
   please refer to the [3]Zarafa Admin manual.
 * Zarafa WebApp has been split up into a separate App. The webinterface
   can now be installed on a separate server than the Zarafa mailserver
   app. Due to the App splitting, an update for zarafa-webapp packages
   will be available after the Zarafa App update
Other notable changes
 * Add sendas dropdown to group objects, making it possible to send mail
   in the name of a group object
 * Fix meeting request attribute handling in listener
 * Add php config file support to UCR module
 * Zarafa WebAccess will not be installed for new installations
                    Zarafa 7.1.14-51822 Update Notes
 * A new metapackage zarafa4ucs-multiserver has been added. It provides
   the infrastructure and configuration options to setup a zarafa
   multiserver environment. Documentation can be found at
   [4]wiki.z-hub.io
 * UCS users can become zarafa-contacts and non-active users / shared
   stores again
 * Zarafa UMC modules are now correctly installed by the zarafa4ucs-udm
   package
 * Allow configuration of mailAlternativeAddress for non-active accounts
 * Add Zarafa ldap attributes to UCRv ldap/index/eq
 * Add zarafa-backup as recommended package
 * Add conflict to package univention-mail-dovecot
 * Remove d-push package recommends
 * Allow udm move of contacts and non-active users
                    Zarafa 7.1.13-51032 Update Notes
See the [5]Zarafa 7.1 Changelog for more details about issues fixed in
Zarafa.
                    Zarafa 7.1.12-49411 Update Notes
Changes
 * A bug in the dagent concerning umlauts has been fixed.
 * A bug in the installation/deinstallation process of the php-mapi
   package has been fixed.
                       Zarafa 7.1.12 Update Notes
Important Changes
 * The update may take a very long time, even in smaller environments.
 * Because user accounts are modified during the update, the server load
   will increase during the update and while replicating the changes to
   all servers in your environment
 * Zarafa contacts are now managed by a dedicated UDM/UMC Module. Zarafa
   contacts thus no longer count towards the user count in the UCS
   domain. See below for information about migrating existing contacts
 * Zarafa shared stores and non-active users are now now managed by a
   dedicated UDM/UMC Module. Zarafa shared stores and non-active users
   thus no longer count towards the user count in the UCS domain. See
   below for information about migrating existing shared stores and
   non-active users
Migrating existing contacts, shared stores and non-active users
The migration of existing objects will be done automatically during the
update by the zarafa4ucs joinscript. To prevent the migration during
joinscript execution, set the UCR variable zarafa/migrateusers to false
before installing the update. If an error is detected the joinscript will
fail before any modifications are done. Check the logfile
/var/log/univention/management-console-module-appcenter.log or call the
migration script in dry-run mode
(/usr/share/zarafa4ucs/zarafa4ucs-migrate-to-separate-udm-modules -d) to
learn more about encountered errors.
 * Zarafa contacts and shared stores/non-active users are now managed in
   separate UDM/UMC modules: udm zarafa/contact and udm zarafa/non-active
 * Starting from this App version, Zarafa Webapp Version 2 is installed
 * Following the Zarafa namingscheme, shared stores are now called
   non-active users.
 * Zarafa contacts and shared stores/non-active users will no longer
   count towards the UCS license
 * If no e-mail address is configured when a user has his role changed to
   any zarafa role, a warning will be shown
 * The package univention-sasl will now be installed when installing
   Zarafa
 * The Zarafa ldap schema has been updated
 * ClamAV is explicitly restarted after installing or updating Zarafa
 * Zarafa is now installable on a UCS member server
 * The Zarafa server restart procedure during the installation has been
   improved
References
Visible links
  1. https://download.zarafa.com/community/final/7.2/final-changelog-7.2.txt
  2. https://portal.zarafa.com/convert_serial
  3. https://documentation.zarafa.com/zcp_administrator_manual/configure_zcp_components.html#configure-the-license-manager
  4. https://wiki.z-hub.io/display/Z4U/Setting+up+Zarafa+Multiserver
  5. http://download.zarafa.com/community/final/7.1/final-changelog-7.1.txt
    Creating data directories for zarafa…
    5
    Registering UCR for zarafa
    Marking zarafa=7.2.1-51838 as installed
    Adding localhost to LDAP object
    Calling /etc/init.d/apache2 reload
    Reloading web server config: apache2.
    /etc/init.d/apache2 returned with 0
    10
    Registering component for zarafa
    Removing repository/online/component/zarafa_20150901
    Removing repository/online/component/zarafa_20150901/localmirror
    Removing repository/online/component/zarafa_20150901/description
    Removing repository/online/component/zarafa_20150901/server
    Removing repository/online/component/zarafa_20150901/version
    Removing repository/online/component/zarafa_20150901/unmaintained
    Adding repository/online/component/zarafa_20160222
    File: /etc/apt/sources.list.d/20_ucs-online-component.list
File: /etc/apt/mirror.list
Module: zarafa-cfg
File: /etc/apt/sources.list.d/15_ucs-online-version.list
Calling /usr/bin/apt-get update
OK http://appcenter.software-univention.de ucc_20150807/all/ Release.gpg
OK http://www.benno-mailarchiv.de Release.gpg
OK http://download.opensuse.org Release.gpg
OK http://appcenter.software-univention.de ucc_20150807/amd64/ Release.gpg
OK http://www.benno-mailarchiv.de Packages
OK http://download.opensuse.org Packages
Holen: 1 http://appcenter.software-univention.de zarafa_20160222/all/ Release.gpg [198 B]
Holen: 2 http://appcenter.software-univention.de zarafa_20160222/amd64/ Release.gpg [198 B]
OK http://appcenter.software-univention.de zmeetings4ucs_20151009/all/ Release.gpg
OK http://appcenter.software-univention.de zmeetings4ucs_20151009/amd64/ Release.gpg
OK https://updates.software-univention.de 4.0-0/all/ Release.gpg
OK https://updates.software-univention.de 4.0-0/amd64/ Release.gpg
OK http://appcenter.software-univention.de dudle_20151113/all/ Release.gpg
OK http://appcenter.software-univention.de openvpn4ucs_20160203/all/ Release.gpg
OK https://updates.software-univention.de 4.0-0/source/ Release.gpg
OK http://appcenter.software-univention.de z-push_20160203/all/ Release.gpg
OK https://updates.software-univention.de 4.0-1/all/ Release.gpg
OK https://updates.software-univention.de 4.0-1/amd64/ Release.gpg
OK http://appcenter.software-univention.de owncloud82_20160125/all/ Release.gpg
OK http://appcenter.software-univention.de owncloud82_20160125/amd64/ Release.gpg
OK https://updates.software-univention.de 4.0-1/source/ Release.gpg
OK https://updates.software-univention.de 4.0-2/all/ Release.gpg
OK https://updates.software-univention.de 4.0-2/amd64/ Release.gpg
OK https://updates.software-univention.de 4.0-2/source/ Release.gpg
Holen: 3 http://appcenter.software-univention.de zarafa_20160222/all/ Release [831 B]
OK https://updates.software-univention.de 4.0-3/all/ Release.gpg
OK https://updates.software-univention.de 4.0-3/amd64/ Release.gpg
Holen: 4 http://appcenter.software-univention.de zarafa_20160222/amd64/ Release [833 B]
OK https://updates.software-univention.de 4.0-3/source/ Release.gpg
OK https://updates.software-univention.de 4.0-4/all/ Release.gpg
OK https://updates.software-univention.de 4.0-4/amd64/ Release.gpg
OK https://updates.software-univention.de 4.0-4/source/ Release.gpg
OK https://updates.software-univention.de 4.1-0/all/ Release.gpg
OK https://updates.software-univention.de 4.1-0/amd64/ Release.gpg
OK https://updates.software-univention.de 4.1-0/source/ Release.gpg
OK https://updates.software-univention.de 4.1-1/all/ Release.gpg
OK http://appcenter.software-univention.de ucc_20150807/all/ Packages
OK https://updates.software-univention.de 4.1-1/amd64/ Release.gpg
OK http://appcenter.software-univention.de ucc_20150807/amd64/ Packages
OK https://updates.software-univention.de 4.1-1/source/ Release.gpg
Holen: 5 http://appcenter.software-univention.de zarafa_20160222/all/ Packages [3.831 B]
OK https://updates.software-univention.de 4.1-1-errata/all/ Release.gpg
Holen: 6 http://appcenter.software-univention.de zarafa_20160222/amd64/ Packages [11,5 kB]
OK https://updates.software-univention.de 4.1-1-errata/amd64/ Release.gpg
Ign https://updates.software-univention.de glibc/all/ Release.gpg
OK http://appcenter.software-univention.de zmeetings4ucs_20151009/all/ Packages
OK http://appcenter.software-univention.de zmeetings4ucs_20151009/amd64/ Packages
OK http://appcenter.software-univention.de dudle_20151113/all/ Packages
OK http://appcenter.software-univention.de openvpn4ucs_20160203/all/ Packages
OK http://appcenter.software-univention.de z-push_20160203/all/ Packages
OK http://appcenter.software-univention.de owncloud82_20160125/all/ Packages
Ign https://updates.software-univention.de glibc/amd64/ Release.gpg
OK http://appcenter.software-univention.de owncloud82_20160125/amd64/ Packages
Ign https://updates.software-univention.de glibc/source/ Release.gpg
OK https://updates.software-univention.de 4.0-4-errata/all/ Release.gpg
OK https://updates.software-univention.de 4.0-4-errata/amd64/ Release.gpg
Ign https://updates.software-univention.de 4.0-4-errata/source/ Release.gpg
OK https://updates.software-univention.de glibc/all/ Release
OK https://updates.software-univention.de glibc/amd64/ Release
OK https://updates.software-univention.de 4.0-0/all/ Packages
OK https://updates.software-univention.de 4.0-0/amd64/ Packages
OK https://updates.software-univention.de 4.0-0/source/ Sources
OK https://updates.software-univention.de 4.0-1/all/ Packages
OK https://updates.software-univention.de 4.0-1/amd64/ Packages
OK https://updates.software-univention.de 4.0-1/source/ Sources
OK https://updates.software-univention.de 4.0-2/all/ Packages
OK https://updates.software-univention.de 4.0-2/amd64/ Packages
OK https://updates.software-univention.de 4.0-2/source/ Sources
OK https://updates.software-univention.de 4.0-3/all/ Packages
OK https://updates.software-univention.de 4.0-3/amd64/ Packages
OK https://updates.software-univention.de 4.0-3/source/ Sources
OK https://updates.software-univention.de 4.0-4/all/ Packages
OK https://updates.software-univention.de 4.0-4/amd64/ Packages
OK https://updates.software-univention.de 4.0-4/source/ Sources
OK https://updates.software-univention.de 4.1-0/all/ Packages
OK https://updates.software-univention.de 4.1-0/amd64/ Packages
OK https://updates.software-univention.de 4.1-0/source/ Sources
OK https://updates.software-univention.de 4.1-1/all/ Packages
OK https://updates.software-univention.de 4.1-1/amd64/ Packages
OK https://updates.software-univention.de 4.1-1/source/ Sources
OK https://updates.software-univention.de 4.1-1-errata/all/ Packages
OK https://updates.software-univention.de 4.1-1-errata/amd64/ Packages
OK https://updates.software-univention.de glibc/all/ Packages
OK https://updates.software-univention.de glibc/amd64/ Packages
OK https://updates.software-univention.de glibc/source/ Sources
OK https://updates.software-univention.de 4.0-4-errata/all/ Packages
OK https://updates.software-univention.de 4.0-4-errata/amd64/ Packages
OK https://updates.software-univention.de 4.0-4-errata/source/ Sources
Es wurden 17,4 kB in 4 s geholt (4.041 B/s).
Paketlisten werden gelesen…
Calling /usr/bin/apt-get -o APT::Status-Fd=1 -o DPkg::Options::=–force-confold --assume-yes --force-yes --auto-remove install zarafa4ucs-udm
Abhängigkeitsbaum wird aufgebaut…
Statusinformationen werden eingelesen…
Die folgenden zusätzlichen Pakete werden installiert:
zarafa4ucs-lib zarafa4ucs-schema
Die folgenden Pakete werden ENTFERNT:
altermime amavisd-new apache2-mod-proxy-wstunnel catdoc clamav-daemon
libarchive-zip-perl libberkeleydb-perl libboost-filesystem1.49.0
libboost-system1.49.0 libconvert-binhex-perl libconvert-tnef-perl
libconvert-uulib-perl libio-multiplex-perl libio-stringy-perl
libkyotocabinet16 libmime-tools-perl libnet-cidr-perl libnet-server-perl
libunix-syslog-perl libvmime0 libxml-dom-perl libxml-perl libxml-regexp-perl
mktemp pax php-gettext php5-enchant php5-mapi python-flask python-jinja2
python-mapi python-sleekxmpp python-werkzeug python-zarafa ripole
univention-antivir-mail univention-sasl univention-spamassassin xsltproc
zarafa zarafa-backup zarafa-client zarafa-common zarafa-contacts
zarafa-dagent zarafa-gateway zarafa-ical zarafa-libarchiver zarafa-libs
zarafa-licensed zarafa-monitor zarafa-presence zarafa-search zarafa-server
zarafa-spooler zarafa-utils zarafa-webaccess zarafa-webaccess-muc
zarafa-webapp zarafa-webapp-clockwidget zarafa-webapp-extbox
zarafa-webapp-files zarafa-webapp-folderwidgets zarafa-webapp-gmaps
zarafa-webapp-pdfbox zarafa-webapp-pimfolder zarafa-webapp-plugins-meetings
zarafa-webapp-plugins-spell zarafa-webapp-plugins-spell-de-de
zarafa-webapp-quickitems zarafa-webapp-webappmanual zarafa-webapp-webodf
zarafa-webmeetings zarafa4ucs zarafa4ucs-webapp zmeetings4ucs
Die folgenden NEUEN Pakete werden installiert:
zarafa4ucs-lib
Die folgenden Pakete werden aktualisiert (Upgrade):
zarafa4ucs-schema zarafa4ucs-udm
2 aktualisiert, 1 neu installiert, 76 zu entfernen und 0 nicht aktualisiert.
Es müssen 39,7 kB an Archiven heruntergeladen werden.
Nach dieser Operation werden 125 MB Plattenplatz freigegeben.
Holen: 1 http://appcenter.software-univention.de/univention-repository/4.1/maintained/component/ zarafa_20160222/all/ zarafa4ucs-lib 7.2.1000-4.107.201603081308 [11,4 kB]
Holen: 2 http://appcenter.software-univention.de/univention-repository/4.1/maintained/component/ zarafa_20160222/all/ zarafa4ucs-udm 7.2.1000-4.107.201603081308 [18,9 kB]
Holen: 3 http://appcenter.software-univention.de/univention-repository/4.1/maintained/component/ zarafa_20160222/all/ zarafa4ucs-schema 7.2.1000-4.107.201603081308 [9.308 B]
Es wurden 39,7 kB in 0 s geholt (362 kB/s).
(Lese Datenbank …
(Lese Datenbank … 5%
(Lese Datenbank … 10%
(Lese Datenbank … 15%
(Lese Datenbank … 20%
(Lese Datenbank … 25%
(Lese Datenbank … 30%
(Lese Datenbank … 35%
(Lese Datenbank … 40%
(Lese Datenbank … 45%
(Lese Datenbank … 50%
(Lese Datenbank … 55%
(Lese Datenbank … 60%
(Lese Datenbank … 65%
(Lese Datenbank … 70%
(Lese Datenbank … 75%
(Lese Datenbank … 80%
(Lese Datenbank … 85%
(Lese Datenbank … 90%
(Lese Datenbank … 95%
(Lese Datenbank … 100%
(Lese Datenbank … 214742 Dateien und Verzeichnisse sind derzeit installiert.)
Entfernen von altermime …
Entfernen von univention-antivir-mail …
Entfernen von amavisd-new …
Stopping amavisd: amavisd-new.
Entfernen von zmeetings4ucs …
ERROR: Site zarafa-presence does not exist!
ERROR: Site zarafa-webmeetings does not exist!
[…] Reloading web server config: apache2e[?25le7 [ FAIL e8e[?12le[?25h failed!
invoke-rc.d: initscript apache2, action “reload” failed.
pmerror:zmeetings4ucs:4.11523:Unterprozess installiertes pre-removal-Skript gab den Fehlerwert 1 zurück
dpkg: Fehler beim Bearbeiten von zmeetings4ucs (–remove):
File: /etc/zarafa/webmeetings.cfg
File: /etc/apache2/sites-available/zarafa-presence
File: /etc/apache2/sites-available/zarafa-webmeetings
File: /etc/zarafa/webapp/config-meetings.php
File: /etc/zarafa/presence.cfg
Not updating zmeetings/sharedsecret_secret
Not updating zmeetings/presence_secret
Not updating zmeetings/plugin/enable
Not updating zmeetings/plugin/auto_start
Not updating zmeetings/plugin/spreed_domain
Not updating zmeetings/plugin/spreed_url
Not updating zmeetings/plugin/webapp_domain
Not updating zmeetings/plugin/webapp_url
Not updating zmeetings/plugin/debug
Not updating zmeetings/plugin/auth_expires
Not updating zmeetings/plugin/require_auth
Not updating zmeetings/plugin/presence_auth_expires
Not updating zmeetings/plugin/turn_use_zarafa_service
Not updating zmeetings/plugin/turn_auth_url
Not updating zmeetings/plugin/turn_auth_user
Not updating zmeetings/plugin/turn_auth_password
Not updating zmeetings/plugin/webauth_code_token_secret
Not updating zmeetings/plugin/webauth_code_token_expires
Not updating zmeetings/plugin/webauth_access_token_secret
Not updating zmeetings/plugin/webauth_access_token_expires
Not updating zmeetings/presence/ip
Not updating zmeetings/presence/port
Not updating zmeetings/presence/loglevel
Not updating zmeetings/spreed/ip
Not updating zmeetings/spreed/port
Not updating zmeetings/spreed/sessionSecret
Not updating zmeetings/spreed/encryptionSecret
Not updating zmeetings/spreed/serverToken
[…] Stopping Zarafa presence: zarafa-presencee[?25le7 [ ok e8e[?12le[?25h.
[…] Starting Zarafa presence: zarafa-presencee[?25le7 [ ok e8e[?12le[?25h.
[…] Restarting Zarafa Webmeetings: zarafa-webmeetingse[?25le7 [ ok e8e[?12le[?25h.
Enabling site zarafa-presence.
To activate the new configuration, you need to run:
service apache2 reload
Enabling site zarafa-webmeetings.
[…] Reloading web server config: apache2e[?25le7 [ ok e8e[?12le[?25h.
Entfernen von zarafa4ucs …
2016-03-28 14:19:50.681832871+02:00 (in joinscript_init)
Object modified: cn=servername,cn=dc,cn=computers,dc=domain,dc=de
Object removed: cn=Zarafa,cn=services,cn=univention,dc=domain,dc=de
Object removed: cn=zarafa-group,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
Object removed: cn=zarafa-group-hidden,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
Object removed: cn=zarafa-role,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
E: object not found
Object removed: cn=SendAsPrivilege,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
Object removed: cn=zarafa-user-hidden,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
Object removed: cn=MRAccept,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
Object removed: cn=MRDeclineConflictingTimes,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
Object removed: cn=MRDeclineRecurringItems,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
Object removed: cn=quotaOverride,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
Object removed: cn=quotaWarn,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
Object removed: cn=quotaSoft,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
Object removed: cn=quotaHard,cn=zarafa,cn=custom attributes,cn=univention,dc=domain,dc=de
Object removed: cn=Zarafa Account,cn=templates,cn=univention,dc=domain,dc=de
Unsetting ucs/web/overview/entries/service/zarafa-webaccess/description/de
Unsetting ucs/web/overview/entries/service/zarafa-webaccess/icon
Unsetting ucs/web/overview/entries/service/zarafa-webaccess/label
Unsetting ucs/web/overview/entries/service/zarafa-webaccess/label/de
Unsetting ucs/web/overview/entries/service/zarafa-webaccess/link
Unsetting ucs/web/overview/entries/service/zarafa-webaccess/priority
File: /var/www/ucs-overview/entries.json
Entfernen von zarafa …
Entfernen von zarafa-search …
[…] Stopping Zarafa search: zarafa-searche[?25le7 [ ok e8e[?12le[?25h.
Entfernen von catdoc …
Entfernen von clamav-daemon …
[…] Stopping ClamAV daemon: clamde[?25le7 [ ok e8e[?12le[?25h.
Entfernen von libarchive-zip-perl …
Entfernen von libberkeleydb-perl …
Entfernen von zarafa-backup …
Entfernen von zarafa-licensed …
[…] Stopping Zarafa licensed: zarafa-licensede[?25le7 [ ok e8e[?12le[?25h.
Entfernen von zarafa-server …
[…] Stopping Zarafa server: zarafa-servere[?25le7 [ ok e8e[?12le[?25h.
Entfernen von zarafa-monitor …
[…] Stopping Zarafa monitor: zarafa-monitore[?25le7 [ ok e8e[?12le[?25h.
Entfernen von zarafa-webapp-folderwidgets …
Entfernen von zarafa-webapp-webodf …
Entfernen von zarafa-webapp-pdfbox …
Entfernen von zarafa-webapp-webappmanual …
Entfernen von zarafa-webapp-files …
Entfernen von zarafa-webapp-extbox …
Entfernen von zarafa-webapp-pimfolder …
Entfernen von zarafa-webapp-plugins-spell-de-de …
Entfernen von zarafa-webapp-plugins-spell …
Entfernen von zarafa-webapp-clockwidget …
Entfernen von zarafa-webapp-quickitems …
Entfernen von zarafa4ucs-webapp …
Unsetting ucs/web/overview/entries/service/zarafa-webapp/description/de
Unsetting ucs/web/overview/entries/service/zarafa-webapp/icon
Unsetting ucs/web/overview/entries/service/zarafa-webapp/label
Unsetting ucs/web/overview/entries/service/zarafa-webapp/label/de
Unsetting ucs/web/overview/entries/service/zarafa-webapp/link
Unsetting ucs/web/overview/entries/service/zarafa-webapp/priority
Entfernen von zarafa-webapp-gmaps …
Entfernen von zarafa-spooler …
[…] Stopping Zarafa spooler: zarafa-spoolere[?25le7 [ ok e8e[?12le[?25h.
Entfernen von zarafa-dagent …
[…] Stopping Zarafa LMTP dagent: zarafa-dagente[?25le7 [ ok e8e[?12le[?25h.
Entfernen von zarafa-utils …
Entfernen von zarafa-libarchiver …
Entfernen von zarafa-webaccess-muc …
Entfernen von zarafa-webaccess …
Site zarafa-webaccess already disabled
Entfernen von zarafa-gateway …
[…] Stopping Zarafa gateway: zarafa-gatewayProgram /usr/bin/zarafa-gateway, 1 process(es), refused to die.
Entfernen von zarafa-ical …
[…] Stopping Zarafa ical gateway: zarafa-icale[?25le7 [ ok e8e[?12le[?25h.
Entfernen von libconvert-tnef-perl …
Entfernen von libmime-tools-perl …
Entfernen von libconvert-binhex-perl …
Entfernen von libconvert-uulib-perl …
Entfernen von libnet-server-perl …
Entfernen von libio-multiplex-perl …
Entfernen von libio-stringy-perl …
Entfernen von libkyotocabinet16 …
Entfernen von libnet-cidr-perl …
Entfernen von libunix-syslog-perl …
Entfernen von libxml-dom-perl …
Entfernen von libxml-perl …
Entfernen von libxml-regexp-perl …
Entfernen von mktemp …
Entfernen von pax …
Entfernen von php5-enchant …
Entfernen von ripole …
Entfernen von univention-sasl …
Entfernen von univention-spamassassin …
Unsetting mail/antivir/spam
Multifile: /etc/postfix/main.cf
Multifile: /etc/postfix/master.cf
Entfernen von xsltproc …
Entfernen von zarafa-common …
dpkg: python-werkzeug: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfernt:
python-flask hängt ab von python-werkzeug (>= 0.8).
Entfernen von python-werkzeug …
dpkg: zarafa-webmeetings: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfernt:
zmeetings4ucs hängt ab von zarafa-webmeetings.
Entfernen von zarafa-webmeetings …
dpkg: apache2-mod-proxy-wstunnel: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfernt:
zmeetings4ucs hängt ab von apache2-mod-proxy-wstunnel.
Entfernen von apache2-mod-proxy-wstunnel …
Module proxy_wstunnel disabled.
service apache2 restart
[…] Restarting web server: apache2 … waiting e[?25le7 [ ok e8e[?12le[?25h.
dpkg: zarafa-webapp-plugins-meetings: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfernt:
zmeetings4ucs hängt ab von zarafa-webapp-plugins-meetings; aber:
Paket zarafa-webapp-plugins-meetings soll entfernt werden.
Entfernen von zarafa-webapp-plugins-meetings …
dpkg: zarafa-webapp: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfernt:
zmeetings4ucs hängt ab von zarafa-webapp.
Entfernen von zarafa-webapp …
ERROR: Site zarafa-webapp does not exist!
Entfernen von zarafa-contacts …
Entfernen von php5-mapi …
dpkg: zarafa-presence: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfernt:
zmeetings4ucs hängt ab von zarafa-presence.
Entfernen von zarafa-presence …
Entfernen von python-zarafa …
Entfernen von python-mapi …
Entfernen von zarafa-libs …
Entfernen von zarafa-client …
Entfernen von libboost-filesystem1.49.0 …
Entfernen von libboost-system1.49.0 …
Entfernen von libvmime0 …
Entfernen von php-gettext …
Entfernen von python-flask …
Entfernen von python-jinja2 …
Entfernen von python-sleekxmpp …
Trigger für man-db werden verarbeitet …
Trigger für univention-config werden verarbeitet …
dpkg-query: Kein Paket gefunden, das auf ldapacl_66univention-appcenter_app.acl passt
dpkg-query: Kein Paket gefunden, das auf ldapacl_63openvpn-sitetosite.acl passt
Trigger für mime-support werden verarbeitet …
Trigger für desktop-file-utils werden verarbeitet …
Trigger für libapache2-mod-php5 werden verarbeitet …
Action ‘configtest’ failed.
The Apache error log may have more information.
Your apache2 configuration is broken, so we’re not restarting it for you.
Trigger für php5-fpm werden verarbeitet …
[…] Restarting PHP5 FastCGI Process Manager: php5-fpme[?25le7 [ ok e8e[?12le[?25h.
Trigger für python-support werden verarbeitet …
zmeetings4ucs
Calling /usr/bin/apt-get -o APT::Status-Fd=1 -o DPkg::Options::=–force-confold --assume-yes --force-yes --auto-remove dist-upgrade
Probieren Sie »apt-get -f install«, um dies zu korrigieren.
Die folgenden Pakete haben unerfüllte Abhängigkeiten:
zmeetings4ucs : Hängt ab von: zarafa-presence ist aber nicht installiert
Hängt ab von: zarafa-webapp ist aber nicht installierbar
Hängt ab von: apache2-mod-proxy-wstunnel ist aber nicht installiert
Hängt ab von: zarafa-webapp-plugins-meetings ist aber nicht installiert
Hängt ab von: zarafa-webmeetings ist aber nicht installiert
E: Unerfüllte Abhängigkeiten. Versuchen Sie, -f zu benutzen.
Probieren Sie »apt-get -f install«, um dies zu korrigieren:
zarafa4ucs : Hängt ab von: zarafa4ucs-udm (= 7.2.1000-4.107.201603081308) aber 7.1.3000-15.100.201510271233 soll installiert werden
Hängt ab von: zarafa4ucs-schema (= 7.2.1000-4.107.201603081308) aber 7.1.3000-15.100.201510271233 soll installiert werden
Hängt ab von: zarafa (>= 7.2) soll aber nicht installiert werden
Hängt ab von: zarafa-licensed (>= 7.2) soll aber nicht installiert werden
Hängt ab von: libxml-dom-perl soll aber nicht installiert werden
Hängt ab von: univention-sasl soll aber nicht installiert werden
Hängt ab von: zarafa-contacts soll aber nicht installiert werden
Hängt ab von: zarafa4ucs-lib soll aber nicht installiert werden
Empfiehlt: univention-spamassassin soll aber nicht installiert werden
Empfiehlt: univention-antivir-mail soll aber nicht installiert werden
Empfiehlt: zarafa-backup (>= 7.2) soll aber nicht installiert werden
zmeetings4ucs : Hängt ab von: zarafa-presence soll aber nicht installiert werden
Hängt ab von: apache2-mod-proxy-wstunnel soll aber nicht installiert werden
Hängt ab von: zarafa-webapp-plugins-meetings soll aber nicht installiert werden
Hängt ab von: zarafa-webmeetings soll aber nicht installiert werden
E: Unerfüllte Abhängigkeiten. Versuchen Sie »apt-get -f install« ohne Angabe eines Pakets (oder geben Sie eine Lösung an).
Failed to install the App packages
Aborting…
Calling start
0
zarafa is not installed
100
upgrade zarafa: 401
File: /usr/share/univention-management-console/modules/apps.xml
File: /usr/share/univention-management-console/i18n/de/apps.mo
File: /etc/apt/apt.conf.d/55user_agent
Calling upgrade-search
0
Calling update
0
… Not Modified
… Not Modified
… Not Modified
… Not Modified
… Not Modified
0 file(s) are new
100
Checking zarafa=7.2.1-51838
100
100
Calling upgrade
0
Going to upgrade Zarafa web meetings (1.2)
(must_have_no_unmet_dependencies) The application requires the following applications: [{‘in_domain’: False, ‘id’: ‘zarafa’, ‘name’: ‘Zarafa Collaboration Platform’}]
Unable to upgrade zmeetings4ucs. Aborting…
100
ERROR: app upgrade failed. Please check /var/log/univention/updater.log
[/code]
Man erkennt, dass alle zarafa* Packages entfernt wurden, aber man sieht nirgendwo die Installation von neuen…
Was ist da los?
Vielen Dank schon mal und viele Grüße
T0mcat
Konnte herausfinden, dass das deinstallieren des Paketes zmeetings4ucs fehlgeschlagen ist, was den gesamten Upgrade Prozess beendet hat.
Genauer gesagt ist der apache reload nach dem deaktivieren des Apache sites fehlgeschlagen (was ich nicht ganz nachvollziehen kann; ein händischer reload funktioniert immer). Nachdem der apache reload im dpkg-script auskommentiert wurde, wurde das Paket entfernt und Zarafa konnte neu installiert werden.
